Old 20th September 2008, 19:55   #1
GeneralLea
Garage: E39 M5 Dark Gray
First Tech Question: ABS Sensor, OBD2 and Speedo
I knew this before I bought the car that it has an electrical fault that kills the DSC, ABS and Speedo.... Read on this forums using many searches that it must be one of the ABS sensors is dead.
So to find out which one I just need to the OBD2, I've found the port under the steering wheel and so I just need to hook up this: OBD2 Code Readers for DiY vehicle diagnostics using Code Scanners for DTC
That should be the correct thing? I believe that the car is actually from the USA not Europe.. Does that mean I can get just any old OBD2 thing or should I still get the BMW one?
PS I plan on doing most things on the car myself so this will be the first post of many!
Also I read that particular ABS sensors report different things to the ECU so is it for example, the rear right sensor that has failed as that is the one that controls the Speedo?
Cheers for the help!
Tom.
GeneralLea is offline
Old 20th September 2008, 21:45   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Tom.
I think they are technically called Pulse Generators. I'd suspect you'll probably need a GT-1 to diagnose as i don't think an OBD2 or a Peake will give you a specific enough code. In any case, Peake gives a more specific version of OBD, so try a Peake first, and if that doesn't work you can take the car to a dealer for a GT1 reading.
d-
DouglasABaker is offline
Old 20th September 2008, 23:45   #3
GeneralLea
So if these are using a pulse... Is it possible to be able read this with an Oscilloscope? Are these sensors reasonably easily accessible? Can anyone point me to a diagram....?
Old 21st September 2008, 01:42   #4
DouglasABaker
Front - Part #7
Rear - Part #24
I can safely say I have no idea what type of pulse is generated - could be an electrical pulse or could be an Ibus communication. I would imagine it has to be electrical and therefore should be visible with an oscilloscope. This still leaves you with the issue of not knowing what to expect.
d-
Old 21st September 2008, 16:51   #5
GeneralLea
From using the search quite a lot I found that many people say it is the rear left that is linked to the speedo... Maybe a visual inspection will turn up something but I doubt it......I have got the Carsoft program installed on a laptop, so all I need is the OBD2 -> USB connector to get much more detailed information..? Or will it just be the same codes as the Peake reader and therefor not worth it?
I really appreciate all the help everyone, thank you.
Old 21st September 2008, 21:28   #6
DouglasABaker
OBD is a generic set of codes that apply to all brands of vehicles. Peake readers provide the BMW specific codes. Hooking up and OBD2 reader will give you LESS information than a Peake.
Doug
Old 22nd September 2008, 04:45   #7
jks540i
Garage: 00' 540i Biarritz Blue Metallic
Originally Posted by DouglasABaker View Post
Front - Part #7
Rear - Part #24
d-
they generate ac voltage. put a meter on it and spin the wheel and see if anything happens.
jks540i is offline
Old 22nd September 2008, 18:36   #8
DouglasABaker
Great! What is "normal" voltage?
d-
Old 22nd September 2008, 19:12   #9
Redneck M5
Garage: 2002 M5 Imola Red
Sometimes the wheel sensors get dirty or the sensor cables get worn out. It's a high failure item. I recommend doing a visual inspection of them. Just one screw each to remove.
Also check the final drive sensor and cable.
Redneck M5 is offline
Old 23rd September 2008, 14:21   #10
Ladykats
Ladykats's Avatar
Garage: M5 Lemans Blue
Doug
Actually, P0*** are generic codes through OBDII connection, P1*** and P2*** are manufacturer specific. I don't use a peake reader, but instead use Modis with German vehicles. ABS, Transmission, Body and Air Bag modules have different entrances to their faults and can't not always be read through an OBD system. Newer vehicle will have CAN communication and can't be read with an OBDII scanner.
Ladykats is offline
DIY on ABS sensor?FIXED THANKS TO DOUGLAS! aguita E39 M5 and E52 Z8 Discussion 3 17th March 2008 15:36
abs/dsc wheel sensor problem nerio02 E39 M5 and E52 Z8 Discussion 0 5th July 2007 03:12
ABS/BRAKE/DSC lights on, tire monitor inactive, speedo not registering HDClown E39 M5 and E52 Z8 Discussion 7 12th May 2007 21:29
No speedo, ABS, Break, DSC lights ON - Wheel sensor?? CWY_M5 E39 M5 and E52 Z8 Discussion 0 27th March 2006 10:49
abs sensor ej_vicious E34 M5 Discussion 0 17th September 2001 19:21
Page generated in 0.16930 seconds with 11 queries
