Old 20th September 2008, 02:33   #1
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S
Found my exhaust rattle-it's the suspension
I thought one of the restraints on my exhaust had come loose but when I got under the car I found the sway bar hitting against metal. Bracket is broken and it pulled from the drop link. Luckily I'm still under extended and CPO warranty so it goes in on Monday. The first shot is of the failed driver side. The second is how it should look.
2003 Titanium Silver M5
1996 Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
bimmernut1 is offline
Old 20th September 2008, 03:30   #2
Olyar15
Garage: 2003 Carbon Black M5
Probably a better idea to get the stronger TCD brackets rather than replacing with the OEM that will end up breaking again in the future.
Charles
Carbon Black/Champagne Individual interior '03 M5 - Tubi exhaust, SS headers, CNS Racing clutch, Fikse FM/5 18" wheels, Bluetooth retrofit.
'09 Honda Fit "dogmobile"/daily driver
'04 supercharged Acura NSX, 385RWHP
Olyar15 is offline
Old 20th September 2008, 04:04   #3
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
This is how it should look...
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 20th September 2008, 04:12   #4
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
...I guess those endlinks do go bad sometimes. How many miles on your car bimmernut?
edit: What model year is it? Noticed 2003 in sig.
TMcNasty is offline
Old 20th September 2008, 04:15   #5
ECB
ECB's Avatar
Sway bar brackets. Very common failure with these cars.
ECB is offline
Old 20th September 2008, 04:17   #6
TMcNasty
TMcNasty's Avatar
Originally Posted by Olyar15 View Post
get the stronger TCD brackets...
x2. Just got my set yesterday bimmer...and I'm under CPO as well.
BeastPower Motorsports, Inc. (5-series store) - BMW M5 (e12, e28, e34, e39, e60, e61): BeastPower Rear Sway Bar Brackets by TC Design for the BMW 5-series (e39) - 1 Set (2 brackets)
Of course it looks like your endlink failed in this case so go to BMW for that, but look into the upgraded brackets as well.
TMcNasty is offline
Old 20th September 2008, 04:18   #7
TMcNasty
TMcNasty's Avatar
If I was under your car and dropped a sandwich and somehow it floated up and landed on your car I'd eat it EVEN AFTER the 5 second rule!
TMcNasty is offline
Old 20th September 2008, 05:37   #8
TurboCarrera
Garage: 00 M5 Silver
It would be cheaper in the long run to buy good aftermarket brackets. Under warranty, BMW is just going to replace the broken $10 bracket again with another $10 OEM bracket, which will break soon enough. It's really a waste of your time.
I went thru three of them before I wised up and bought some good ones, which are about $100.
Steve
00 M5
TurboCarrera is offline
Old 20th September 2008, 06:52   #9
bimmernut1
bimmernut1's Avatar
You guys are right, I know I should buy the stronger brackets. This will be my third one in 2+ years. However, this is the first time it also took out the drop link. Up to now it's just cracked, not sheared off completely . I've held off buying the stronger ones for two reasons. First they've been replaced under warranty, but I agree there is a cost as far as my time. Second, I'm proving a point to BMW (not that they will listen). I've told them on several occasions that this piece is a weak link in their design that they should address. Since I'm already scheduled to take the car in on Monday, I'll go OEM one last time. I'll just order the stronger ones and have them available and change them out myself this Fall.
Anyone know if the issue was fixed on the e60's or do they suffer the same failures with their stock unit?
TMcNasty, your car looks brand new. Great work getting it to look like that. I'm at about 81k on my car by the way.
Old 20th September 2008, 15:18   #10
Ladykats
Ladykats's Avatar
Garage: M5 Lemans Blue
Hmmmm, that ECB's M5 that you can eat off of. I don't think he drives her often or cleans her every time he brings her in. Damn that is a pretty picture.
Ladykats is offline
Diagnosing exhaust rattle? greg E39 M5 and E52 Z8 Discussion 7 30th December 2006 19:27
Found my rattle Hogie E60 M5 and E61 M5 Touring Discussion 6 17th June 2006 01:50
Exhaust Rattle Steve Morling E39 M5 and E52 Z8 Discussion 1 5th October 2002 17:31
Suspension Rattle M5 powered E34 M5 Discussion 6 1st April 2002 20:46
found it! (a short rattle story)... Paul S E39 M5 and E52 Z8 Discussion 4 20th January 2002 22:26
Page generated in 0.14219 seconds with 12 queries
