Old 19th September 2008, 13:10   #1
Apeman
Garage: E39 M5 '01 Carbon Black
Low-end torque missing, troubleshooting help requested
I had the car dynoed yesterday and this confirmed what my "butt-dyno" had been telling me: a substantial amount of low end torque and some top end power is missing. Adjusted readings are: 265lb/ft at 1500rpm (should be 295), 275lb/ft at 2000rpm (should be 360). 2000rpm is where the biggest difference is compared to reference values. From there the engine slowly picks up and then there is a significant shift at 3200-3400rpm. At 3400rpm the torque is 369lb/ft which is pretty much what it should be. Top end power is down by 5-10%.
The mechanic running the dyno test thought the torque curve suggested a camshaft position issue. He also noted that the car was running lean at lower rpms. Based on the car's test mode I've also noticed that it seems to run lean at the top end, max readings are 115-120l/h (they were 139l/h a year ago).
The fact that the car is running as it should at around 3500-4500rpm might suggest that there are no significant long term fuel trim issues due to e.g. bad O2 sensors? Any thoughts?
Some background information:
MAF:s are more or less new (VAG Bosch sensors, didn't really make much of a difference when I installed them). Low end torque issues were there both before and after installation.
The fuel pump has been changed recently, but the fuel filter hasn't.
O2 sensors have not been changed as far as I know. CO2 readings were mostly fine, and O2 readings through the OBD corresponded well with the exhaust values.
Cats are functional but the mechanic noted that it took quite a while for them to get heated up.
Inspection II was done a year ago (new plugs, filters etc.), the car has run ~8k miles since then. I haven't checked the condition of the plugs though.
The engine has never thrown any fault codes and it runs ok; it just feels (and is) weak at lower rpms. Idle is steady, the only symptom of something being slightly off (besides the power loss) is that the engine is twitching slightly under light throttle for a couple of minutes after a cold start. Also, the engine vibrates a bit, perhaps more than it should, but this could be due to some more physical issues like e.g. bad exhaust mounts or a tired flywheel?
Apeman is offline
Old 19th September 2008, 13:29   #2
jclyman
jclyman's Avatar
I would change the fuel filter first and see if anything changes.
- Daniel Boorstin
jclyman is offline
Old 19th September 2008, 18:01   #3
TopEnd
TopEnd's Avatar
Garage: 2005 M.Benz E55 AMG
STUPID BUT VALID QUESTION....
When you turn your ignition to position 2 (engine not running), Does the SES light come on? I'm curious to know if the SES light bulb is working....
TopEnd is offline
Old 19th September 2008, 18:16   #4
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Rough idle and lack of low end torque sounds like a cam position issue, but I'd start with JClyman's idea and look at other contributing items as well. My suspicion is that there is nothing wrong with your VANOS, but rather that some combination of sensors is sending inaccurate data to the DME and is causing the DME to call for inappropriate cam positions.
What codes were you able to pull from the car? Reset, wait a week, and pull again. Post those and we'll be able to help more. Pretty much guaranteed that you have them, even with no SES (mostly triggered by emissions in the states).
d-
DouglasABaker is offline
Old 19th September 2008, 18:23   #5
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
How many miles on your car?
If I were you I'd change the fuel filter. There was another recent post where a guy got an extra ~20L/hr just by doing that. And you just got a new pump...there is a chance that is died early due to stress! I got one online for $23.
Don't underestime the ability of lazy pre-cat O2's to f with your power. I saw you keeping up w/ SleeperE39's power loss thread. Granted he had exhaust cracks so his sensors may have been okay, but it still proves that bad readings from the O2's can rob the power. I got a set from Amazon for $110 shipped a month ago.
8k on air filters? Not too high, but for the price of new why not toss a set in...just to see results.
Were the proper NGK plugs installed at inspection II?
Does your car pass the onboard test for the thermostat operation?
Another recent topic was the power robbing effects of a stuck cooling fan because of a defective fan clutch. Is your fan clutch ok? Search for threads.
TMcNasty is offline
The Following User Says Thank You to TMcNasty For This Useful Post:
jclyman (19th September 2008)
Old 19th September 2008, 18:31   #6
TMcNasty
TMcNasty's Avatar
d-
Good catch d...didn't see he was in Finland. Do euro cars have no SES light...or is it just much harder to get it to come on?
TMcNasty is offline
Old 19th September 2008, 18:53   #7
ard
ard's Avatar
Remember, this is not a USA model so CEL will not be set like it will over there. (Edit: TM- almost any code in USA will set the light, only a few codes set the CEL in EU)
To the OP- you are pulling codes using the OBD port, correct? There are none?
How about any GT1 results?
Definitely reolace the fuel filter, assume air filter is new?.... then look at GT1/other results for o2 and fuel trim.
A
ard is offline
Old 19th September 2008, 19:30   #8
Apeman
Thanks for all the comments. The SES light is working, and as I said the car has never thrown any codes (checked with two types of readers including GT1 at main BMW dealer). The last check was after the dyno test, not with GT1 but still through the OBD port.
O2 sensor adaption values were -2.1% and 0%, doesn't sound that alarming to me. Other O2 readings seemed fine as well, basically just what would be expected (pre- and post cat O2 sensors correlated well, no real variation between left/right sensors and and exhaust analysis confirmed the readings). That said, I might still change the O2 sensors if I don't find any other clear causes.
Inspection II was performed at the main official BMW dealer in Finland, so I assume they put in the correct plugs.
Thermostat test has not been run (don't know the procedure), but I get the same readings from the dashboard and from the OBC.
The cooling fan is not stuck as far as I know. Definitely not running all the time and it seems to run as expected when the engine/air is hot.
The car has run 72k miles. Air filters and oil filter have run 8k. I have a time booked next Thursday at the official dealer, so I hope to find out more then. I will definitely have the fuel filter changed, and I've also requested that the vanos solenoid O-rings be changed even if there are no clear indications of malfunction.
Apeman is offline
Old 19th September 2008, 20:15   #9
ard
ard's Avatar
You should ask them to run a full VANOS test. Make sure you are getting appropriate actuation across the full RPM band.
I really HATE suggesting this, but I wonder if you want to look at your CPS sensors. There are SOME reports that these can start to fail and NOT throw codes, yet have symptoms..... worth thinking about I guess.
A
ard is offline
Old 19th September 2008, 20:17   #10
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
CPS Sensors....
2000 Silverstone M5 extended Leather
BBS LMs 19s ,StopTech BBK,Dinan Headers Dinan CF -CAI,Dinan light weight flywheel,Dinan stage 3 suspension, Dinan stage 4 software ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
2009 135 Space gray Black Boston Extended Leather
mods-
Bmw Performance Black kidney grills
Dinan Stage 2 software(to be installed in April after winter)
1988 10th anniversary Rx7 turbo-mods... 93 rotors 3mm seals streetported lapped and balanced 6 puck non organic clutch Turbo back exhaust blah blah blah
1972 Corvette Stingray 454 4 speed man. Show car condition Frame off Restoration -FOR SALE make offer...
http://www.brecus.com/
mfizzlenyc is offline
INCREASE BOTTOM END TORQUE? justblaze E60 M5 and E61 M5 Touring Discussion 23 11th September 2008 01:52
Just intalled Sec 1&2 MST GT Exhaust -Loss of low end torque? Rated///M E60 M5 and E61 M5 Touring Discussion 14 29th August 2008 09:16
Troubleshooting missing under full throttle/SES light? 12sec4dr E39 M5 and E52 Z8 Discussion 1 29th September 2006 20:56
E60 M5 and low end torque greer E60 M5 and E61 M5 Touring Discussion 11 31st August 2006 07:02
low end torque ajinfante E34 M5 Discussion 10 20th June 2006 14:48
Page generated in 0.18205 seconds with 11 queries
