Tune Up - BMW M5 Forum and M6 Forums
Old 7th September 2008, 00:10   #1
dmack4646
Garage: m5 silverstone
Tune Up
My beast has done 36,000 miles , (2002) model and has only had an oil service - is there anything to be gained by replacing plugs , air filter etc at this stage ?
dmack4646 is offline   Reply With Quote
Old 7th September 2008, 02:43   #2
JohnAnthony
JohnAnthony's Avatar
Garage: Silverstone
you're kidding right...and i hope you mean services[PLURAL]
it's NOT a MODEL T...these cars need to have the freshest parts, it's like your tires you don't wait until ALL the thread is gone, you change them out when the depth is no longer adequate
you'll be looking at more serious repairs if you don't...especially after 50k miles...
edit:
also the car is 6yrs old i'm pretty sure the manual suggest those things be changed by now regardless of mileage
JohnAnthony is offline   Reply With Quote
Old 7th September 2008, 03:52   #3
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
I'd wait to replace the plugs until Service II (approx. 55 K miles). Your car should have had Service I by now, which includes new air filters. If it has not had Service I yet, I'd look into it. Hopefully you have service records.
Most of us change the oil twice as frequently as the lights tell us to, or about every 7500 miles.
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
The Following User Says Thank You to KevinM For This Useful Post:
dmack4646 (7th September 2008)
Old 7th September 2008, 12:21   #4
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Plugs, maf's, pre cat o2 sensors, air filters, injection clearner, check the battery.
andy777 is offline   Reply With Quote
Old 7th September 2008, 15:57   #5
azaytsev
azaytsev's Avatar
Garage: 996 C4S 6MT
Why would you change Maf's and pre-O2 sensors at 36K mi??? This is tooooooo early.
___________________
BMW CCA MEMBER#409490
Previous BMWs
2001 M5
1997 528i
1990 535i
1977 320i
azaytsev is offline   Reply With Quote
Old 7th September 2008, 16:20   #6
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
almost +1
36k miles you say?
your plugs are functional, but way off peak efficiency...if not at end of useful life.
your MAFs are functional, but not running at peak effeciency.
your O2 sensors are probably still pretty good, but at 36K they're probably getting "lazy."
you should be changing your air intake filters yearly. more frequently if you live in a dusty/etc. environment.
fuel injector cleaning also a good idea.
a battery strength test also a good idea.
you should also be changing your cabin air filters yearly unless you like bad outdoor smells, pollen, and a musty HVAC system.
at 36k I'd also be seriously looking into changing my fuel filter. I'm sure she's cloggin up by now and stressing your fuel pump.
be advised that all of the parts needed to do the above (besides FI cleaning and battery) can be had online...well in USA anyway...for $270 and can all be DIY'd.
Erase the BMW service interval recommendations from your mind.
TMcNasty is offline   Reply With Quote
The Following User Says Thank You to TMcNasty For This Useful Post:
Old 7th September 2008, 17:25   #7
ard
Super Moderator
ard's Avatar
Originally Posted by TMcNasty View Post
almost +1
36k miles you say?
++1
I change air filter every other oil change (oil at 5k-7500, air filter 10-15k). Definitely needs it. This WILL impact engine performance.
A
New way to tune your M5 boostedbimmer E39 M5 and E52 Z8 Discussion 16 16th November 2008 04:58
How to 'tune' a BT?? B9 boy ALPINABoard.com | BMW Alpina Discussion 102 31st July 2008 21:21
90k tune up bobsalotto E39 M5 and E52 Z8 Discussion 1 28th February 2008 01:54
My first tune up djtroy E39 M5 and E52 Z8 Discussion 7 14th July 2006 21:37
where to TUNE, and what to get? E39 M5 and E52 Z8 Discussion 4 19th July 2001 05:23
