Rear sway bar bracket: Stronger OEM part found - BMW M5 Forum and M6 Forums
Like Tree4Likes
Old 22nd August 2008, 16:06   #1
rassi
rassi's Avatar
Garage: '11 Mercedes C300 CDI 4Matic
Having just realised that my left rear sway bar bracket had broken off, I was about to get the very well made (but expensive) Beastpower brackets but thanks to a tip from member Frits (www.performance-shop-geel.be) I found out that there is actually a stronger OEM part available
The E36 M3 one is identical but made in STEEL rather than the flimsy aluminium of the E39.
The part number I have is 33 50 6 779 734, though I can't find this one on realoem, but it does pop up here: Support Bracket for Sway Bar Mounting Bushing - RM European Auto Parts
Think this would also be the same as this one # 31351124995 RealOEM.COM * BMW E36 M3 STABILIZER, REAR but no guarantee that this is the same as the # 33 50 6 779 734 that I know works and is made of steel.
Replaced both my brackets for very little €
Anders
'08 BMW M5 (Silverstone II / Black merino leather)
ex '08 BMW X3 xDrive 35d (Titan silver / Nevada beige leather)
ex '09 Mercedes C220T CDI Avantgarde (black / black leather)
ex '02 BMW M5 (Carbon black / black leather)
ex '95 BMW 320i Touring (black / black cloth)
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline   Reply With Quote
The Following 13 Users Say Thank You to rassi For This Useful Post:
-BEASTMW- (11th April 2009), cura (4th April 2013), Frye (29th August 2009), JDMM5 (5th November 2011), jer23 (5th October 2008), JL21ah (21st May 2010), M5 Fan (22nd August 2008), nerio02 (22nd August 2008), Old4thWardM5 (16th October 2009), plking (29th August 2009), Super-saloon (23rd August 2008), Terabass (28th January 2009), V8 empowered (27th January 2009)
Old 22nd August 2008, 16:21   #2
zarnd
zarnd's Avatar
Garage: 2002 Le Mans BLue M5
nice tip, thanks! I will be looking into upgrading these next time they break. Bought the car a year ago and it already had new ones fitted, so no point in changing them yet!
cheers
Alex
2007 Land Rover Discovery 3 TDV6 HSE
2005 Mini Cooper S
2002 M5 - TotalBMW Feature car September 2008
1989 VW Golf GTI - Race car
zarnd is offline   Reply With Quote
Old 22nd August 2008, 17:12   #3
labenzm5
Garage: 2001 m5 Lemans Blue
thank you for the info. Just ordered a set!
labenzm5 is offline   Reply With Quote
Old 22nd August 2008, 21:27   #4
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
rassi did you actually install them yet...or just ordered them? Can you confirm they definately fit?
I wonder if they ship to !!!
edit: nevermind they're a US company! I suppose these aren't the same as the ones get from a BMW dealer for the E39 M5?
TMcNasty is offline   Reply With Quote
Old 22nd August 2008, 21:47   #5
Hawkwind
Hawkwind's Avatar
Garage: 2003 M5 Sterling Gray
The non-M5 E39 brackets are also steel and probably less brittle than the aluminum ones.
Hawkwind is offline   Reply With Quote
The Following 3 Users Say Thank You to Hawkwind For This Useful Post:
jclyman (28th January 2009), KLehmann (16th May 2009), V8 empowered (27th January 2009)
Old 22nd August 2008, 21:52   #6
bwilly
bwilly's Avatar
Garage: 2001 LMB M5
Did the E36 have an aluminum sub-frame like our E39s? If not, you might not want a steel bracket against the aluminum. I think the reason they used an aluminum bracket in the first place was because of the issues with mixing materials (corrosion?).
Maybe somebody on here with a better understanding of this can chime in here?
I just wish that BMW had used a sturdier aluminum bracket or that the Beastpower ones were cheaper.
bwilly is offline   Reply With Quote
Old 22nd August 2008, 22:21   #7
TMcNasty
TMcNasty's Avatar
u prolly have a point. i'd bet there's something that would prevent corrosion though...a lubricant/grease or a piece of gasket material could be cut to fit.
Old 23rd August 2008, 02:24   #8
Need4Spd
Need4Spd's Avatar
Steel plus aluminum are a well-known galvanic couple. Google it. I personally would not use steel brackets on an aluminum frame member.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline   Reply With Quote
The Following User Says Thank You to Need4Spd For This Useful Post:
Old 23rd August 2008, 04:33   #9
Hawkwind
Hawkwind's Avatar
So what kind of bolts do you use in aluminum?
Here's one google result:
Myths About Aluminum Body Tubs
1. There is one common myth about aluminum body tubs: Where aluminum and steel meet, electrolysis will occur and weaken the metals. It is scientifically true that electrolysis will occur between different metals, but it's only a significant factor in marine construction where the metals are immersed in water over a long period of time. These conditions simply don't occur on a vehicle. The fact is, it's not going to happen in a motor vehicle with an aluminum body. Think about the ways aluminum and steel have been successfully used together for many years. Most aircraft, for example, combine aluminum and steel. In automobiles, the legendary Shelby AC Cobra has an aluminum body and a steel chassis. Chevrolet's new Corvette, the new Audi A8 (see AutoWeek Sept. 2, 2002 issue), the new 2003 Jaguar XJ8 sports an all aluminum body (see AutoWeek Dec. 23, 2002 issue), and even the noble Bentleys and Rolls Royces of today, (see AutoWeek April 21, 2003 for the new Aluminum Rolls Royce Phantom), and yesteryear, have been crafted of aluminum and steel in happy combination. The Ferrari Modena 360, Acura NXS, and Aston Martin Vanquish all use aluminum to enhance vehicle performance. The auto industry is becoming "bullish" on aluminunm and it's use for body parts. In summary, don't worry about electrolysis. It occurs, but so slowly and minutely that it's almost like watching the wind erode the Great Pyramids.
jclyman (28th January 2009), Need4Spd (23rd August 2008), Super-saloon (23rd August 2008)
Old 23rd August 2008, 05:05   #10
TMcNasty
TMcNasty's Avatar
plus like I said...just grease it all up a bit...the grease will put a barrier between all the dissimilar metals.
What you need to know about your suspension palantirion E39 M5 and E52 Z8 Discussion 24 17th July 2012 09:50
FS: E39 M5 OEM rear sway bar Vason Parts / Other For Sale or Wanted 2 23rd June 2007 22:15
Dinan rear sway bar bracket reinforcement kit RoundelM5 Parts / Other For Sale or Wanted 2 20th May 2007 21:27
Renn-Sport Front and rear Sway Bar Impressions Bigtime007 E39 M5 and E52 Z8 Discussion 9 29th May 2003 23:29
