Old 7th August 2008, 20:39   #1
Dr Pooface
Dr Pooface's Avatar
Garage: Silver 95 M3, Silver 01 M5
HVAC only blows hot air
Even when I have the temp down at the lowest setting. The AC works but it's only chilly, not super cold, and then when I turn it off FOG CITY. I think the ac is cooling hot air as well. Fan works fine. Any ideas...?
Dr Pooface is offline
Old 7th August 2008, 20:50   #2
jjc1843
jjc1843's Avatar
Garage: 2000 M5 Carbon Black
Send a message via AIM to jjc1843
You are low on freon. R134A. Get a can system from local Auto Store, recharge it yourself. Save $$ from stealer.
The fill valve is locatednext to the valave cover on the right hand side.
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
'95 525i Black/Parchment 195K Eibach/Billstien/Power Chip [Sold!!!!]
jjc1843 is offline
Old 7th August 2008, 20:51   #3
DRM
DRM's Avatar
Garage: 2002 M5 (Chiaretto Red Metallic)
Read this thread....
Advice on intermittent AC issue?
Dan
______________________________________________
Daily Driver
'02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
The "Predator"
'02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
EVOMS Stage 4 (640hp/615tq)
PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
Sachs clutch and Porsche SSK
Toyo RA-1's 245/18 fronts; 305/18 rears
DRM is offline
Old 7th August 2008, 20:54   #4
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
have you checked your electrical fan (aux fan) in front off the car , iff its doing its thing??
most off the time iff the ac dont blow cold air its because the aux fan dont work...
just start your car, put the ac on and go check in front off the car iff the aux fan runs... you can see it thru the kidney grills.
maybe its that.. any way you dont have to unbold something or get under the car, so its a easy little check up
nerio02 is offline
Old 7th August 2008, 20:59   #5
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
do you know if your FSU is bad? i THINK thats what causes this, im not sure though. id do a search on the FSu and see if its that.
razahyde is offline
Old 7th August 2008, 21:08   #6
nerio02
nerio02's Avatar
Fsu normally controlles the speed off the fan inside not the temprature i think; fsu work on data taken from a tempsensor in the dasch..
so iff no irratic speed off the fan i would doubt its the fsu.
offcourse i can be wrong.
aux fan or freon will be it .i can feel it,got cold feet (j/k)
with kind regardes
nerio02/dominique
nerio02 is offline
Old 7th August 2008, 22:47   #7
2002alpine
Garage: 2002 M5 Alpine White/Caramel
low on freon would be my guess had the same problem in my M3
2002alpine is offline
Old 7th August 2008, 23:48   #8
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
A few months ago my a/c quit cooling (suddenly) although the fan worked normally - changing the FSR solved the problem.
BKH is offline
Old 8th August 2008, 01:55   #9
Dr Pooface
Dr Pooface's Avatar
OK, you guys don't understand.
My HVAC only blows hot air. When the AC is OFF. At the coolest setting whith the AC OFF it should blow cool ambiant outside air. It blows MAX HOT AIR all the time. Changing the temp setting has no affect, it's always at max hot.
This is not an AC issue. The AC works fine.
Old 8th August 2008, 05:53   #10
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Does it blow the same temperature air out of every vent (dash, floor, defrost)? Or are they different temperatures?
The immediate fogging leads me to suspect your recirc valve - can you hear a change in the fan when you turn recirc on and off manually?
The only other thought I have on the subject is that it might be your heater control is stuck in the on position, which is to say that your FSU is shot.
d-
DouglasABaker is offline
M3 worst nigthmare is here; BMW 1xx tii Concept Just_me E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 29 24th February 2008 20:16
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Hot weather, Air con? plisken E34 M5 Discussion 13 28th April 2004 11:00
Air temps - I'm instrumented and ready to test greg E39 M5 and E52 Z8 Discussion 27 13th September 2003 02:24
Page generated in 0.14167 seconds with 11 queries
