Old 14th August 2008, 03:14   #31
vitacura
vitacura's Avatar
Garage: 2002 M5
Great info! I see my next little project.
vitacura is offline
Old 15th August 2008, 02:28   #32
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Originally Posted by ard View Post
So $160 is a bargain.
Have you done the MAF airflow test yet? You should.
Oh I agree about the bargain. I meant for it to sound sarcastic, but I guess I didn't type it right.
My MAF's reading was pretty good b4 the work, but I've been meaning to redo it. Still have 2 O2's to put in first.
TMcNasty is offline
Old 17th August 2008, 21:27   #33
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
didn't someone on here tell me that the fuel filter didn't have an element, but was rather just more like a percolator or something...?
good to see it's actually got an element, i thought it'd have to have one. hence "filter"
Lancefitzgiben is offline
Old 18th August 2008, 21:34   #34
lednuor
Thank you for the heads-up re the fuel filter.
I notice that BMW recommends a change at 100 K miles- which sounds a bit too round and, of course, is well outside even an extended service plan.
I just had the dealer change mine and asked for the old filter. I did not bother cutting it open as the gas the flowed out the intake looked like black ink and there was a also a pinch of small black particles in the mix.
lednuor is offline
Old 18th August 2008, 22:16   #35
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
Maybe finding a large Rigid pipe cutter would help open the filters up.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
Old 19th August 2008, 02:00   #36
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
When I changed mine last weekend I let it drain into my measuring cup thinking I might put the spent fuel into my beetle, it not being too choosy about its fuel as the ///M is. But the black particulate that was draining into the container got to be so thick that I just stopped and capped the filter. Then I had to wait for a day for it to settle enough to pour the clear fuel into the beetle's tank. The black residue leftover was pretty considerable. Nice that it's not restricting my fuel flow any more...
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 25th August 2008, 09:15   #37
jks540i
Garage: 00' 540i Biarritz Blue Metallic
Originally Posted by REKIII View Post
There are a couple other threads that recomend replacing the pump as well when doing this. THe theory is that the pump had to work extra hard to pump through a clogged filter, so it's probably hurt a little too.
Probably over kill, but I thought I'd mention it.
Bob.
were they just going on a theory or did they confirm that the fuel pressure and volume were below spec?
jks540i is offline
Old 25th August 2008, 11:00   #38
Alin10123
Alin10123's Avatar
Garage: 06 e60 M5 Black
Wow... dang...
Alin10123 is offline
Old 25th August 2008, 23:51   #39
jks540i
you might as well do all 8 injectors while you're at it in case the clogged filter affected them as well :p
jks540i is offline
Old 9th October 2008, 00:25   #40
gavinp
Garage: M5 e34 LE 9/50
Just replaced the fuel filter on my 2001 M5
For all you fellow Right Hand Drivers, the fuel filter is under the passenger side of car.
Straight forward enough once I had worked out where to put the axle supports as the panel to remove tucks under the N/S/F jacking point.
Also replaced the 2 vent hoses from heads to seperators and cleaned out the air filter boxes and checked tightness of all visible hose clamps.
Took for a spin, and whether placebo affect or not, the car felt sharper !
gavinp is offline
How to avoid paying $118 for a Fuel Filter? 00m5 E39 M5 and E52 Z8 Discussion 11 29th November 2005 19:47
Has anyone ever experimented with additives....... FAST 5 Off Topic Forum 15 20th September 2005 03:48
Straight from BMW on recent delays Gustav E60 M5 and E61 M5 Touring Discussion 37 4th July 2005 19:52
Fuel Filter Replacement M5Pageco E39 M5 and E52 Z8 Discussion 2 3rd July 2005 18:23
Fuel Line Replacement de Witt E28 M5 Discussion 4 6th August 2002 17:03
Page generated in 0.20375 seconds with 12 queries
