Old 2nd August 2008, 07:21   #1
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S
How loud is your cooling fan?
Here's the deal. For two years my car has run at slightly below 210 degF, right near midpoint. Recently my fan belt broke and was replaced. Now the car consistently runs cooler than it did, even during the most hot and humid period we've had in years. It's about a 1/4 section lower than original.
But, the cooling fan noise is now very pronounced under acceleration and the frequency is in line with the rpm. Almost sounds like someone slipped in a supercharger when I wasn't looking. Unfortunately the additional HP is not there to match the sound. The fan sound now is almost as pronounced as the engine sound.
The dealer kept the car two days, drove it and said it's the aux fan and there's no problem at all. My question is whether I had a problem before and now the car is sounding like it is suppose to; or whether there is indeed a problem that is causing the difference in pitch? Is there a way I can confirm it is indeed the aux fan making the difference in pitch?
2003 Titanium Silver M5
1996 Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
bimmernut1 is offline
Old 2nd August 2008, 08:20   #2
HOVO
HOVO's Avatar
Garage: Titanium
well i can tell you that the aux fan is pretty load, whenever I turn on the A/C, the fans starts, the higher the ac setting is, the loader the noise gets.. sometimes its really bad if the A/C is blasting, I can hear it inside the car but people have stopped me and asked me what the turbine noise is in the car. also ive seen other people have this problem of the fan being really load.
bottom line, get used to it. aux fans are really load
2002 Titanium M5.
HOVO is offline
Old 2nd August 2008, 16:42   #3
EricM5
EricM5's Avatar
Garage: E39 M5 CarbonBlack
I have the same. The fan turns faster when the engine makes more rpm's.
My Jaguar XJR did the same thing, but did have a supercharger.
I haven't tested it with or without AC on or whatever. But I'll figure it out tonight
400hp = 40 doubledecker busses
EricM5 is offline
Old 2nd August 2008, 17:11   #4
SSense
SSense's Avatar
Garage: '03 M5 Blue Water Metallic
Its totally normal for the fan to be loud, when the A/C is on it rotates at its max speed, which keeps it loud.
/// M5 ’03 - Blue Water Metallic
SSense is offline
Old 2nd August 2008, 22:04   #5
Vason
Vason's Avatar
Garage: '03 M5 - Carbon Black/Caramel
Sales Feedback: (4)
I've had a few aux fan issues in the past and I can for certainty tell you all is normal. At times I wish it wasn't so loud but I have gotten used to it.
'03 M5 Carbon Black/Caramel
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
Old 4th August 2008, 02:56   #6
bimmernut1
bimmernut1's Avatar
Thanks guys. I'll just try to ignore it. I just found it strange that ithe car decided to get loud after 2 years. Like other enthusiasts, I tend to pay close attention to the sounds my car makes.
Old 4th August 2008, 08:46   #7
RemBrant
RemBrant's Avatar
Garage: 2003 M5 Carbon Black Met.
Sales Feedback: (17)
Fan noise with engine RPM?
I'd be checking the fan clutch on the main cooling fan. You should be able to turn it by hand with the engine off/cool with minor resistance. If the fan clutch is starting to go it will be very stiff to turn the fan, and it will whine up to a certain RPM, which will climb as it degrades, until it doesn't disengage at all. There have been several members who have had the plastic fan explode due to overrevving, and high RPM and do major damage to the enginebay, hood, components. All have commented on the whining sound, or turbine sound before it happened.
Also if the clutch is not disengaging it will be constantly turning at whatever RPM the engine is at and cooling which may explain the lower overall temps.
I replaced my fan clutch in about 15 minutes with an exact replacement clutch. Before I changed it it would whine to about 4500-5000rpm before kicking out. After I replaced it whine goes to a much more sensible 3000rpm, and only when it's 20+C outside.
Just some thoughts...
2003 M5 Carbon Black Met.(416/9)
Silverstone-Blk Sport/Alum Int, Rear Sunshade
Valentine V1 1.8 POP2
BMW Bluetooth gen 10 upgrade
Hella Euro Headlight upgrade (Lamin-X protected)
Hoen Xenonmatch 9006 Fogs (Lamin-X protected)
Hoen Xenonmatch H7 High Beam
Pedator ICE upgrade
Charcoal 35% tint all around
TEC Ultimate cupholders x2
Blacked-out Kidney grills
Bilstein PSS9 Coilovers
BREMBO GT 4-piston cross-drilled F-355mm,R-345mm
275/30ZR19 Toyo T1R's (Street)
Beyern Mesh 19x9.5's (3" lip) (Street)
TC Design Rear Swaybar Brackets
Cosmos Racing Front Strut Bar
Tubi Rumore CatBack Exhaust
Magnaflow 14815 Mufflers
AA CAI Kit
IATS Relocate kit
5mm Wheel spacers all around
See my gallery for pics
RemBrant is offline
Old 4th August 2008, 16:59   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
But, the cooling fan noise is now very pronounced under acceleration and the frequency is in line with the rpm. Almost sounds like someone slipped in a supercharger when I wasn't looking?
I woud also check the tension on the fan belt, make sure it is not too tight.
gsfent is offline
Old 4th August 2008, 18:47   #9
ard
ard's Avatar
1. When a thermostat fails it can stick OPEN and you will run cooler.
2. As mentioned by ONE poster, a failing fan clutch will allow the fan to run at engine rpm (it is supposed to slip at high rpm so it will run slower). If locked to engine RPM it can explode, taking oit hoses AND your hood. Search...
A
ard is offline
Old 6th August 2008, 00:48   #10
bimmernut1
bimmernut1's Avatar
Thanks for the most recent suggestions. I'll specifically take a look at the fan clutch when I return. I do remember it being hard to move but I'll pay closer attention when I retest it. I'll also check the thermostat and belt tension.
My gut feeling was that something is different but I just could not put my finger on the problem. At least I have some items to check now.
Troubleshooting loud aux fan? 00imolaM5 E39 M5 and E52 Z8 Discussion 7 6th September 2007 02:46
aux fan or dme? ccm241 E39 M5 and E52 Z8 Discussion 1 31st August 2007 00:00
Loud fan noise from launch nixter E34 M5 Discussion 5 17th May 2006 02:46
Aux fan problem Mr. J E34 M5 Discussion 9 25th July 2005 11:34
electric cooling fan Yves E34 M5 Discussion 0 23rd April 2000 01:07
Page generated in 0.15270 seconds with 12 queries
