Old 1st August 2008, 13:06   #1
j1o2x3
Garage: 2001 carbon black m5
lights on rev meter?
Iv done a search with no results.
The red lights that light up on the revometer and go out as the car warms up do not all go out on my 2001 car. are all these lights supposed to go out?
if so any ideas what may be the problem?
The majority of the lights go out except the last 2, the final one i think is the permanent red line but id have thought the others should all go out.
I know this is not the clearest post but i hope you understand.
j1o2x3 is offline
Old 1st August 2008, 13:15   #2
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
No the last orange light stays on with the red light at 7000rpm being the limit.
andy777 is offline
Old 1st August 2008, 13:35   #3
SSense
SSense's Avatar
Garage: '03 M5 Blue Water Metallic
+1 Totally agree with andy and this is how it looks like (normal)
/// M5 ’03 - Blue Water Metallic
SSense is offline
Old 1st August 2008, 13:50   #4
j1o2x3
thanks, thats exactly whats on my car. no need to worry then
j1o2x3 is offline
Old 1st August 2008, 14:16   #5
SSense
SSense's Avatar
You're Welcome
SSense is offline
Old 1st August 2008, 19:37   #6
jclyman
jclyman's Avatar
Absolutely normal.
Redline is 6,800 RPM in 5th (direct drive) and 6,500 RPM in 6th. (Tach needle is usually a little slow in getting there.)
I would NEVER rely on the lights. I wait until the oil temp is close to normal before I begin to drive mine as BMW intended the car be driven.
Also, I would check the oil level at least once every two weeks. The oil level sensor actually doesn't measure the oil level. It measures temperature differences on a probe. Very sophisticated, but not too accurate.
- Daniel Boorstin
jclyman is offline
Old 2nd August 2008, 00:03   #7
jjc1843
jjc1843's Avatar
Garage: 2000 M5 Carbon Black
Send a message via AIM to jjc1843
+1--what jcl said. Water, Oil and drive train compnents should all be up to T° prior to running it hard.
Drive easily until everything is warmed.
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
'95 525i Black/Parchment 195K Eibach/Billstien/Power Chip [Sold!!!!]
jjc1843 is offline
M5 Fog Lights jemmie E39 M5 and E52 Z8 Discussion 17 23rd September 2006 00:07
3 warning lights came on today! willm5ad E39 M5 and E52 Z8 Discussion 12 7th June 2006 19:49
Lights ON Warning Fails vadas1 E34 M5 Discussion 2 21st September 2003 14:43
2001 lights on y2k M5 steveB E39 M5 and E52 Z8 Discussion 6 31st October 2000 03:48
Page generated in 0.11000 seconds with 12 queries
