Old 31st July 2008, 19:43   #1
EricM5
EricM5's Avatar
Garage: E39 M5 CarbonBlack
Valve cover gasket oil leak ??
Does this look like a valve cover gasket faillure ??
If so there are some nice threads about fixing it. But i'm not 100% sure it's the valve cover gasket. Anybody who has seen this before ??
400hp = 40 doubledecker busses
EricM5 is offline
Old 31st July 2008, 19:57   #2
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
hard to tell did someone spill oil as they were toping her off i would clean t off and keep an eye on it
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 31st July 2008, 20:03   #3
EricM5
EricM5's Avatar
Good tip,
The car just had a service but no leaks when I got the car back. After a while it showed this oil leakage. I cleaned it, and now it shows again. I'm afraid no oil spill. But I will clean it once again and hopefully it stays away now
EricM5 is offline
Old 31st July 2008, 20:09   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
no, it looks like the little rubber grommets that surround the bolts are leaking. Very common, get a handful of each (there are two different grommets) and your dealer and replace them one at a time as they start leaking. Becareful not to overtighten the bolts and strip them.
Note: the one bolt that holds the ribbed cover should not be leaking, that covers the coils. If you have oil coming out of there you have some bigger problems!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
The Following User Says Thank You to mottati For This Useful Post:
ard (1st August 2008)
Old 31st July 2008, 20:53   #5
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
While you're replacing the grommets, might as well replace the valve cover gasket.
everycredit is offline
Old 31st July 2008, 20:59   #6
EricM5
EricM5's Avatar
Nope I just cleaned it again and those are nice and dry
EricM5 is offline
Old 31st July 2008, 21:15   #7
mottati
mottati's Avatar
i don't know, the grommets are easy, do them one at a time and you're have no issues. I wouldn't go to the trouble of replacing a non leaking valve cover gasket.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 31st July 2008, 21:48   #8
EricM5
EricM5's Avatar
Oke great stuff guys thanks verry much.
I will watch the leak closely and post a new pic in a few days. If it still leaks, I think the 'mottati' option is the best one
EricM5 is offline
Old 1st August 2008, 17:50   #9
ard
ard's Avatar
Some folks forget to change the grommets when they re-do the valve cover gasket. New grommets every time.
Agree that changing the grommets is WAY easier than doing the whole thing. Worth a try.
ard is offline
Old 1st August 2008, 19:45   #10
EricM5
EricM5's Avatar
I just checked it again and there is a leak at the bold next to the oil cap.
So new grommets at the next service.
EricM5 is offline
New valve cover gasket leaking, help! topper E39 M5 and E52 Z8 Discussion 7 25th July 2008 22:05
Oil change andy777 E39 M5 and E52 Z8 Discussion 14 18th February 2008 04:28
Oil Filter Leak, Anyone? Venom77 E60 M5 and E61 M5 Touring Discussion 3 29th January 2008 10:47
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
Page generated in 0.14577 seconds with 11 queries
