Old 28th July 2008, 11:59   #1
FitForFives
FitForFives's Avatar
Garage: E34 M5/E39 M5
Troubleshooting Engine & Electric Cut Off?
Hello everyone. I am a fairly recent member in need of help.
I was driving the E39 today and when I stopped at an intersection the electronics flashed quickly and then the motor and electric cut out. I got out of the car, waved the traffic to pass (no hazard lights) and the cabin lights popped on. The engine started and I drove away with no further problems.
About a month earlier I ran into the store and left my girlfriend in the car. When I came out the engine wouldn't start and there was no electric. I got out of the car hit the keyless entry, after a minute i noticed the cabin lights turn on. Stupidly I supposed it might have something to do with the security system which it clearly does not. It happened another time when I was parked and the engine was running. Same result, a minute later the electric kicked back on. Finally the day before yesterday coming off of a highway going about 40 MPH the lights flickered and I thought the engine was going to go, but it did not and I finished the drive without incident.
Clearly I was foolish not to address this problem earlier. The next time I drive the E39 will be to the mechanic. I would appreciate any information or similar experiences.
FitForFives is offline
Old 28th July 2008, 12:57   #2
Alin10123
Alin10123's Avatar
Garage: 03 LMB M5, 05 TSX
Sounds electrical. Check the easy stuff first. How is your battery?
Alin10123 is offline
Old 28th July 2008, 12:58   #3
SSense
SSense's Avatar
Garage: '03 M5 Blue Water Metallic
The wires on the battery could be loose , thats one reason why engine could go off. Dont depend on my reply, wait for our other M5 experts to post their replies too, im sure you'll get a solution, dont worry.
/// M5 ’03 - Blue Water Metallic
SSense is offline
Old 28th July 2008, 14:21   #4
kees
Administrator
Garage: magic moderator wand
Start with the cheap stuff:
- check the battery connections are tight and clean
- replace the battery
kees is offline
Old 28th July 2008, 16:24   #5
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
i would ck your connections to battery and the connections on the power block on the passenger right side behind the compartment in the trunk from there i would ck all your grounds
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 28th July 2008, 16:49   #6
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Loose battery connections will not stop an engine from running, but that and a faulty Unloader Relay are about the only thing that will cause you to lose all power to the car. A faulty unloader relay could also cause your vehicle to lose all power while driving (and cut out the engine in the process).
For reference, the unloader relay is how BMW turns off all the electrics when you start the car. I would posit that yours is going bad and needs to be replaced ASAP - all relays go bad over time (did you know the circuit breakers in your house need to be replaced about every 20 years or so?), so don't let it give you any pause about the roadworthiness of your beast...
d-
DouglasABaker is offline
Old 28th July 2008, 18:05   #7
m5 deamon
m5 deamon's Avatar
doug i was waiting for him to ck what i wrote and i was going to state the samething you did about the main realy
Supersprint X pipe
Dinan rear sway bar
Tc swaybar brackets
PS2 tires
Euro head lights
DDM xenon fog lamps
Solaris amber bulbs
v1 hardwire
Old 28th July 2008, 23:45   #8
DouglasABaker
Great minds think alike
(written as I sit here stuck at LGA waiting for the next shuttle to Boston in 2 freakin' hours...)
d-
Old 28th July 2008, 23:50   #9
FitForFives
Thanks for all of the suggestions. Just brought it to the mechanic, so hopefully it works out.
Old 30th July 2008, 23:01   #10
FitForFives
Got my beast back form the mechanic. They replaced the ignition switch. They said that this is a common problem in E39, E46, and other models from the 2000s. So far so good, but I guess only time will tell.
TECH: How to accurately compression test an S62 engine DavidS E39 M5 and E52 Z8 Discussion 18 1st March 2007 02:34
M5/M6 V10 a success in Australia Just_me E60 M5 and E61 M5 Touring Discussion 1 16th November 2006 00:53
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Page generated in 0.14050 seconds with 11 queries
