Old 22nd July 2008, 20:58   #1
topper
Garage: 1999 M5 (Silverstone)
Valve cover bolt torque
I'm hoping to get the valve covers on tonight. I can't find any torque setting in the TIS, or a web search. Anyone got a clue?
Useful BMW E39 M5 part numbers: http://topperdoggle.blogspot.com/200...t-numbers.html
topper is offline
Old 22nd July 2008, 21:56   #2
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
yes just snug them up good and you will be fine
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 23rd July 2008, 02:38   #3
topper
Thanks, they're back on. I don't think I overtightened anything, although one of the bolts at the vanos end was a close thing - I felt it /just/ start to give, so left well alone.
What amazes me is how people say they know they have / had a leak from the half-moons. It's almost impossible to get round there, especially on the right hand side.
I tried to feel to make sure the new gaskets were well-placed at the half-moons, but I'd be lying if I said I was 100% sure. I'm definitely partly relying on the fact that they were carefully fitted. I'll just cross my fingers.
topper is offline
Old 23rd July 2008, 17:04   #4
m5 deamon
m5 deamon's Avatar
the tric to that is to use some high temp rtv silcone on the half moons and use a mirror to ck if they seated correctly. but if you stick your hand back there and they are dry you should be fine
Supersprint X pipe
Dinan rear sway bar
Tc swaybar brackets
PS2 tires
Euro head lights
DDM xenon fog lamps
Solaris amber bulbs
v1 hardwire
Old 23rd July 2008, 20:27   #5
H8Rain
H8Rain's Avatar
Garage: Silver E39 Beauty
Dude.... thats a lame response . The should be tighted to 10lb - 12lbs.
Just busting on you a little bit ya know
MINE: Garage Queen with way to many mods to list.
HERS: X5 4.4
GONE: 1985 318i
H8Rain is offline
Old 24th July 2008, 19:41   #6
M540i
M540i's Avatar
Garage: 2001 540i, Jet Black
Send a message via AIM to M540i
Really and truly it is actually quite difficult to overtighten them. I spoke to a Master Technician about this and his response was that since there is a shoulder at the tops of the bolts it is impossible to overtighten if you are being gentle in the first place. Make sure to use a high temperature gasket sealer as well over the area that where it seats againts the cylinder head.
If you are torquing on things like a Wal*Mart tire gorilla ("mechanic") then it would make sense that you would break a bolt off. "Snugging" it up is acceptable. I am no tech, but I do know that a little common sense should help the situation.
M540i is offline
Old 25th July 2008, 20:27   #7
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
I thought it was 15ft/lbs, but it may be 10-12ft/lbs as stated. I'd take care to use the correct torque on anything that goes into an aluminum part. Think especially about the amount of effort involved in fixing a stripped thread in a head.
verhagke is offline
Old 26th July 2008, 19:51   #8
JeffYoung
Garage: 2000 M5 Imola
Snug up is right. You would be very surprised at how "little" torque 15 ft lbs is. You can hit it before your torque wrench even clicks.
JeffYoung is offline
Old 27th July 2008, 00:07   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Originally Posted by M540i View Post
Really and truly it is actually quite difficult to overtighten them..
are you kidding? THese bolts are incredibly easy to strip. "snug" is a good answer. My torque wrench starts at 30ft lbs, and my other one is in inch lbs, for which i'm not sure of the conversion.
Must be why we hear of dealership techs always stripping these!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Where do the valve cover gaskets leak? derck_mullin E39 M5 and E52 Z8 Discussion 17 21st April 2009 23:06
Valve Cover Gasket Leak hadas4 E39 M5 and E52 Z8 Discussion 12 11th January 2007 01:23
Is this a genuine Alpina Valve cover or reproduction?? GaAlpinaowner ALPINABoard.com | BMW Alpina Discussion 5 23rd April 2005 08:43
Valve Cover Gasket Replacement Ronin M5 E39 M5 and E52 Z8 Discussion 4 4th March 2005 15:59
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Page generated in 0.13302 seconds with 11 queries
