Old 29th December 2001, 00:44   #1
DarkStar
DarkStar's Avatar
Garage: 2003 E55
Moonroof wind noise?
I seem to get a lot of wind noise from the moonroof on my car. If the roof is closed, but I leave the sun "screen" open, the wind noise really picks up on the freeway and it sounds like I have a window open. With the screen closed it is significantly quieter. I thought this was normal, however I recently had a 530i as a loaner (nice car, by the way), and the sunroof on that car was dead silent.
Anyone else have this problem? Maybe have the seals replaced by the dealer?
TIA,
-Alex
DarkStar is offline
Old 29th December 2001, 00:48   #2
JFB
JFB's Avatar
Garage: 2001 M5 Royal Red / Caramel / Burl
Problem
Sounds like your seals are not working properly. Mine does not generate wind noise like you describe. More noise leaks through my roof with the moonroof exposed than when the headliner slide is shut, but that's just because there's less insulation.
Jim
2001 ///M5 Royal Red / Caramel
JFB is offline
Old 29th December 2001, 02:37   #3
basil
basil's Avatar
Garage: Anthracite
Alex,
After experiencing four E39's I've found that there is a sunroof adjustment issue at the factory. You need to have it adjusted or, less lilkely, have the seal replaced. I was told by a service advisor (not an honest one however) that it's not easy to get it right. He could have been right since the first adjustment made on my 540 was noticeably worse than before. Second time was perfect and has lasted. Two of the four E39's had this issue when new.
Good luck.
basil is offline
Old 29th December 2001, 03:39   #4
livenupe
livenupe's Avatar
Garage: 2000 M5-Titanium/Black
My last E-39 developed that problem around it's 2nd birthday. Like you, I noticed it when I had a loaner. I broght it to the attention of my service advisor and they took care of it.
reggie c.
Los Angeles, CA
Current = 2004 40th Anniversary Porsche 911
Past = 2000 M5
livenupe is offline
Old 29th December 2001, 05:23   #5
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
Only 4500 miles on my '02, but no wind noise.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Wind Noise? ycchan E39 M5 and E52 Z8 Discussion 8 28th December 2002 21:45
new windshield - more wind noise? tfung E39 M5 and E52 Z8 Discussion 11 29th October 2002 20:09
FIX for wind noise from around the windshield area. Mattar E39 M5 and E52 Z8 Discussion 2 14th February 2001 16:52
wind noise nascar E39 M5 and E52 Z8 Discussion 10 25th September 2000 01:01
Page generated in 0.13048 seconds with 11 queries
