Old 2nd July 2008, 02:27   #1
boostinb18c1
Garage: 01 M5 SILVER
Advice on using Mobil1 0W40?
IS THIS SAFE TO USE FOR TOPPING OFF?
http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx
boostinb18c1 is offline
Old 2nd July 2008, 04:14   #2
supratony
supratony's Avatar
Garage: 2002 BMW M5 Sterling Grey | 1997 Supra Turbo 6sp
Sales Feedback: (5)
Yes.
supratony is offline
Old 2nd July 2008, 04:56   #3
malexgcab
malexgcab's Avatar
Garage: M5 CB
+1. I use it.
malexgcab is offline
Old 2nd July 2008, 05:39   #4
Fuguar
Garage: 2001 M5 Dk Blue
I use it and gained 1.4 mpg over 5W30 and cut oil consumption by 50%. Granted, I was using the incorrect 5W30 (regular Castrol synthetic).
Fuguar is offline
Old 2nd July 2008, 08:47   #5
SSense
SSense's Avatar
Garage: '03 M5 Blue Water Metallic
Yes its safe
/// M5 ’03 - Blue Water Metallic
SSense is offline
Old 2nd July 2008, 09:43   #6
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Depends on what's in your crankcase and how you drive it.
I use Mobile 0W40 fully synthetic in the winter and Castrol TWS 10W60 in the summer. Get better gas mileage with the Mobile and less shear during cold start ups in the winter.
I use it as a replacement oil--don't like to have a potpourri of oils in the crankcase. However, that said, you should be fine.
everycredit is offline
Old 2nd July 2008, 18:04   #7
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 Titanium Silver
Send a message via AIM to Mike S. Send a message via MSN to Mike S. Send a message via Yahoo to Mike S.
I use it and have had no problems with it. You should be fine, depending of course, on what is in there now.
"Bugslayer" 2003 M5 - Engine: Magnaflow 14816, Driveline: E60 545i Short Shifter Suspension: TCDesign Rear anti-roll bar brackets Exterior: Stealth Auto Black Kidneys, 30% Ceramic Tint Interior: Hardwired V1, Ultimate Cupholders, OEM AUX Audio Input, Diny custom radio knobs.
Mike S. is offline
Old 2nd July 2008, 19:01   #8
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I have been using it for about 20-25k miles, no issues, no consumption.
gsfent is offline
Old 5th July 2008, 02:44   #9
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
If you already have a Mobil product in your vehicle, then yes, feel free to top off with it. Alternatively, feel free to change over to it at a later date.
As far as topping off goes, priority (assuming a synthetic in the crankcase) is:
1. A synthetic of a different weight from the same manufacturer,
2. A Dino oil from the same manufacturer,
3. A synthetic from a different manufacturer.
Why same brand dino over different brand synthetic? Additive packages and possible incompatabilities.
d-
DouglasABaker is offline
Old 5th July 2008, 04:02   #10
ard
ard's Avatar
What are (some of) you people talking about?!?! It is never OK to mix oils, period. Unless you KNOW, for a fact, that they are compatible. One oil in a 5-30 may be entirely different than a 10-60 or even a 5-40...same mfg, etc
Doug has it right above^^^. Additive packages may be very different- nobody really know what is in these either. (Unless you live over on BITOG)
You 'top off' with the oil you put in when you changed it. If you don't know what is in it, then you really DO need to change it.
Of course, in an emergency, it is OK to add ANYTHING. Just change it ASAP.
ard is offline
Financial Advice (401k, IRA, Profit Sharing Questions, etc.) dmcgibbo Off Topic Forum 4 19th September 2008 19:16
Noob Beast Owner, US Navy Sailor run aground needs some advice! Squid E39 M5 and E52 Z8 Discussion 23 1st April 2007 03:12
Some advice on tires for new wheels. esp1976 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 19 9th September 2006 18:15
Advice on resolving uneven tire wear (rear)? vvanherk E39 M5 and E52 Z8 Discussion 7 16th March 2006 21:31
Odd advice re: break-in Bryan E39 M5 and E52 Z8 Discussion 8 8th April 2001 07:08
Page generated in 0.17140 seconds with 11 queries
