Underbody panels-How to tighten - BMW M5 Forum and M6 Forums
Old 17th June 2008, 02:28   #1
kosmo
kosmo's Avatar
Garage: M5 2002, LeMans Blue
While changing the oil I noticed that many of the screws holding the underbody panels were loose. After several attempts I gave up as the the screws wouldnt tighten, either because the screw is stripped or the nut backing the screw was missing. Any suggestions?
2002 M5 Lemans Blue
kosmo is offline   Reply With Quote
Old 17th June 2008, 04:07   #2
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
Their isnt a nut. Its a small clip that requires you to really push the screw to get it to grab. The problem is people (including dealers) half *** this part of the job. If it wasnt reinstalled correctly the clip maybe missing or you just may have to dick with it for a while to get it right. I had the same issue when i got my car. It is a pita.
Good luck
Ryan
rneedham1979 is offline   Reply With Quote
Old 17th June 2008, 10:16   #3
jclyman
jclyman's Avatar
Good luck
Ryan
They came from the factory with 4 10mm bolts and 4 of those screw thingys you mention (8 fasteners all together). Most dealers just don't replace them at all or replace them with all screw thingys. You're right they are difficult to tighten. There are also two lenghts of screw thingys ... long and short (black - long, and silver - short). And, trying to get a dealer to fix them isn't easy!
I got mine fixed properly once, and again it is not correct. This time I will fix it myself.
- Daniel Boorstin
jclyman is offline   Reply With Quote
Old 17th June 2008, 10:31   #4
Need4Spd
Need4Spd's Avatar
I believe they're called Dzus fasteners. They're supposed to be quick release fasteners; twist 1/4 to half turn to fasten/unfasten. But as others noted, they're a bit tricky, and one can easily not seat them correctly, in which case they can fall out. If enough of them fall out, you can lose the underbody panel. This doesn't seem as trivial as one might expect. The loons working on the cars often don't care, but the underbody panels are important for control of airflow under the car. Loss of panels can result in excessive noise or more importantly, lift or some other undesireable effect at high speeds. In fact, I have found things missing underneath after dealer visits such as the "door" leading to the oil pan drain plug.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline   Reply With Quote
WTB: Black E34 door panels (Delamination free) Mtechnik540i Parts / Other For Sale or Wanted 5 5th August 2007 22:19
Door Panels BuickGSBoy E34 M5 Discussion 1 2nd November 2006 13:18
Help! How to take interior door panels apart? ATLANTA M5 E39 M5 and E52 Z8 Discussion 2 8th January 2006 21:37
Black/gray with titanium trim door panels dmccrary90025 E39 M5 and E52 Z8 Discussion 2 13th June 2004 00:23
Ultralightweight Carbon Fiber Body Panels! marcb E39 M5 and E52 Z8 Discussion 7 4th October 2000 05:43
