Old 8th June 2008, 01:29   #1
Dr Pooface
Dr Pooface's Avatar
Garage: Silver 95 M3, Silver 01 M5
Any way to deactivate the tire monitoring system?
Mine is driving me bananas, it continually gives me false alerts.
Dr Pooface is offline
Old 8th June 2008, 02:22   #2
jclyman
jclyman's Avatar
I trust you reset it.
- Daniel Boorstin
jclyman is offline
Old 8th June 2008, 03:11   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
No.
+1 on jclyman
DouglasABaker is offline
Old 8th June 2008, 04:14   #4
jonsmiff
jonsmiff's Avatar
Garage: e39 m5 silverstone blue
mine did the same till i reset it
jonsmiff is offline
Old 8th June 2008, 07:00   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
wasn't there just a thread on this?
You press the button on the dash, it will say "tire pressure inactive" on the MID, and then it's off.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th June 2008, 06:19   #6
Dr Pooface
Dr Pooface's Avatar
Yes, I tried to reset it and nothing happens. Turn the key to #2 position and then hold the button for 15 seconds? I could hold it for 15 hours and nothing happens.
Pushing the button to deactivate it every time I start the car is annoying. I hate how the display on the cluster has the fault arrows on it.
Thanks anyways.
Old 9th June 2008, 10:25   #7
J Irwan
J Irwan's Avatar
Garage: 02 CB M5
Thanks anyways.
I don't remember if it is 15 second or not,
but the procedure is:
Turn the key to #2 position and then hold the button until the message "SET TIRE PRESSURE" appear on the display. (check page 82 on the manual book).
Regardz,
J Irwan
02 Carbon Black ///M5
J Irwan is offline
Old 9th June 2008, 14:02   #8
IRISH M5
IRISH M5's Avatar
Garage: 03 M5 LeMans Blue
Sales Feedback: (4)
Pretty sure you need the seat belt engaged before you start the TPM process.
IRISH M5 is offline
Old 9th June 2008, 14:31   #9
jonsmiff
jonsmiff's Avatar
i went to the local garage to use their compressor, pushed the button till "set tyre pressure" came up, i the set the tyres to the correct pressure and i havent had a error from it since, i did not have my seatbelt on .
jonsmiff is offline
Old 9th June 2008, 14:39   #10
IRISH M5
IRISH M5's Avatar
Sales Feedback: (4)
Maybe it's a US spec car thing? The fasten seat belt message will not go away on my car until I engage the belt.
IRISH M5 is offline
295/35/ZR18 on stock rear wheel? M5girl E39 M5 and E52 Z8 Discussion 40 27th March 2009 18:26
Tire Pressure Monitoring System - Hella whatheheck E39 M5 and E52 Z8 Discussion 2 30th September 2007 17:15
Hunter has a New way to balance tires... Ocean's M5 E39 M5 and E52 Z8 Discussion 7 24th July 2007 03:42
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Tire Pressure Monitoring Systems Luke@tirerack E39 M5 and E52 Z8 Discussion 0 13th December 2006 22:36
Page generated in 0.15020 seconds with 11 queries
