Old 6th June 2008, 21:25   #1
Kleintje
Kleintje's Avatar
Garage: E39 M5 Dark Green
Third Brakelight Broken
Ok...LEDS can't be broken all at once. So what could it be? A fuse? Electronics?
The displays gives a German message.... But it suddenly stop working.
Anybody?
Kleintje is offline
Old 6th June 2008, 21:34   #2
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
Third brake light? Are they all LEDs? Even the one in the middle (out from the back window)?
Cristian
Anthracite///Black
For Sale: Sumitomo HTRZ III for 19s
For Sale: 2 GoPro Motorsports Wide Cameras
Diny is offline
Old 6th June 2008, 21:57   #3
Kleintje
Kleintje's Avatar
Ehh....I ment...the one in the middle
Kleintje is offline
Old 6th June 2008, 22:06   #4
IslandS62
IslandS62's Avatar
Garage: 88 M3, 01 M5, 02 MCoupe, 03 X5 4.4i
Its not LED is it? There are bulb changing instructions in the owner's manual and there is a little access door back there. (at least on my 01')
BMWCCA Chapter President, HI (fmr)
88 M3, 01 M5, 02 MCoupe (S54), 03 X5 4.4i
IslandS62 is offline
Old 6th June 2008, 22:10   #5
Kleintje
Kleintje's Avatar
It looks like led's... Hmmmm I will check again.
Kleintje is offline
Old 6th June 2008, 22:12   #6
Gustav
Administrator
Gustav's Avatar
The bulb
Gustav is offline
Old 6th June 2008, 22:25   #7
M5Piojo
M5Piojo's Avatar
Garage: MY 95 Avus Blau
Originally Posted by Gustav View Post
The bulb
Indeed, originally the E39 has just a normal light bulb in there which, upon replacement, should work again as ever before
-10/1989 Sebring Grau (R.I.P.)
-07/1991 Macao Blau (Sold)
-03/1992 Brilliantrot (Sold)
-09/2002 Carbonblack (Sold)
-12/1994 Avus Blau Touring
M5Piojo is offline
Old 6th June 2008, 23:07   #8
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
yes like everybody says, its with a lightbulb..
see picture,to be clear how to remove it
khoop dat je er wat mee bent doei.
with kind regardes
nerio02/dominique
nerio02 is offline
Old 6th June 2008, 23:11   #9
Kleintje
Kleintje's Avatar
Hahahahahah, en ik maar denken dat ik LED lampjes heb...
(Hahahahahah, and I was under the impression I had LED lights...)
Kleintje is offline
Old 6th June 2008, 23:17   #10
nerio02
nerio02's Avatar
hehe..
by the way , i quickly had a look in my car, and the bulb can be replaced trough the trunk..
so its a 5 second job
open your trunk, and look inside(above) and you will see a black cover sitting there.open it up and then you can pull out the bulb socket.replace it and close the thing.then your good to go
with kind regardes
nerio02/dominique
nerio02 is offline
The Following User Says Thank You to nerio02 For This Useful Post:
Kleintje (6th June 2008)
Oil filter housing rubber mount broken (also steering servo fluid reservoir) DavidS E39 M5 and E52 Z8 Discussion 15 16th January 2008 16:38
Broken sway brkt and loose wheel! olis1 E39 M5 and E52 Z8 Discussion 24 21st April 2006 07:59
Broken Sway Bar Brackets x703jko E39 M5 and E52 Z8 Discussion 2 21st September 2003 18:58
FYI... Broken bolts found on transmission bracket Bob Uenaka E39 M5 and E52 Z8 Discussion 1 7th August 2003 04:21
My BiTurbo has broken down, and more... Thor ALPINABoard.com | BMW Alpina Discussion 12 10th June 2002 14:50
Page generated in 0.13452 seconds with 12 queries
