Old 6th June 2008, 20:42   #1
michael9218
michael9218's Avatar
Garage: 2002 M5 Sterling Gray
Outside temp sensor
I've done a brief search and found nothing, so I'll just ask:
Has anyone experienced problems with their outside temp sensor?
Mine is accurate until the outside temps climb north of the mid 80's. Then it reads wildly high temps. For example, today it's 92 and the outside temp in the car is reading 111. A full 19 degress off. At lower temps, it's fairly accurate.
michael9218 is offline
Old 6th June 2008, 20:51   #2
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
Could it be that the asphalt is hotter? Keep in mind that the sensor is only a few inches from the ground, and right in front of the car.
Cristian
Anthracite///Black
For Sale: Sumitomo HTRZ III for 19s
For Sale: 2 GoPro Motorsports Wide Cameras
Diny is offline
Old 6th June 2008, 20:52   #3
badboypolar
badboypolar's Avatar
Garage: '02 M5 Carbon Schwarz Metallic
Send a message via AIM to badboypolar
Haven't seen that. I have seen that when sitting in traffic and it's hot out the temps climb fast though. I've seen +120 on mine while sitting in traffic on a day that the temp was said to be 99.
You can't not be home before you haven't left.
2002 M5
M5Board.com Stickers Now Available
Crackberry E39 M5 Theme Ver 1.0
badboypolar is offline
Old 6th June 2008, 21:28   #4
Panos
Panos's Avatar
Garage: 1999 540i 6-speed Biarritz Blue/Sand Beige
I think its a combination of hot asphalt under the sun and hot exhaust from bumper to bumper traffic, plus at this point the heat coming off of your radiator way reach the sensor.
To check this theory pull into a peice of concrete that has been in the shade for a while and sit there. I bet the temp reading equalizes closer to the ambient air temp.
Panos
1999 540i.6 Biarritz Blue/Sand-Beige
M5 Grills, 17" Staggered Radial Spoke Style 32 Wheels, M5 Rear Stabilizer Bar, Rogue Transmission Mounts, Rogue Short Shifter & Wieghted Selector Rod, CDV Deleted, Stop Tech Stainless Steel Lines, Dinan Engine Software, Bluetooth Telephone, Valentine One Radar/Laser Detector, StealthOne Interface, Debadged.
R. I. P.
2002 M5 Carbon Black/Caramel
Retired: 1997 540iA, 1994 540iA
Panos is offline
Old 6th June 2008, 22:00   #5
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
In my experience, the outside temps are very inaccurate when temperatures get past 100 degrees. I think this has been discussed, but I didn't search. I do think the asphalt has something to do with it given the location of the sensor.
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 6th June 2008, 22:44   #6
michael9218
If it was the asphalt, then the temp should normalize while driving at speed due to the airflow mitigating the radiant effect of the asphalt and the engine components, yet this isn't the case. My car sits in a covered garage. While taking it for spin, the temp shows this high reading. The car is moving, not in stop and go traffic, maybe a traffic light or two.
Old 7th June 2008, 00:45   #7
IslandS62
IslandS62's Avatar
Garage: 88 M3, 01 M5, 02 MCoupe, 03 X5 4.4i
Mine does the same. Air temps hover in the mid-eighties here, and my temp reading will easily hit 110 degrees or greater. I think its probably a combination of the road temps and maybe some engine heat hitting it. The external temp gauges in my other cars all seem pretty accurate.
Maybe some shielding would help, though I think the factory tried that at one time without much success.
BMWCCA Chapter President, HI (fmr)
88 M3, 01 M5, 02 MCoupe (S54), 03 X5 4.4i
IslandS62 is offline
Old 7th June 2008, 02:23   #8
jclyman
jclyman's Avatar
Can't really speak for your car. But, if you were NOT the original owner, and the original owner had the panel (they crack easily), or sensor replaced, they may not have gotten the tinfoil that is on the newer panels to insulate the temp gauge from the engine heat. You might look, and if there is NO tinfoil, wrap some around the inside portion of the temp gauge. (It should also cover a small portion of the sensing wire.)
My gauge, even when it is hot, seems fairly accurate with the temps rising slightly from the asphalt heat radiation when in traffic.
- Daniel Boorstin
jclyman is offline
Old 7th June 2008, 04:20   #9
J Irwan
J Irwan's Avatar
Garage: 02 CB M5
++1... I would check that too.
Mine seems to be pretry accurate so far.
Regardz,
J Irwan
02 Carbon Black ///M5
J Irwan is offline
Old 7th June 2008, 05:55   #10
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Ever since the dealer removed my front bumper to replace the aux fan, the temp sensor is acting up. They replaced it the sensor and made sure the foil was in place. It still is inaccurate. I think there is a way to reset the sensor by shorting some wires but I need to search for more instructions.
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Knowledge base on Peake codes for E39 M5 kees E39 M5 and E52 Z8 Discussion 322 30th October 2009 02:51
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Replacement/removal of exhaust temp sensor (EGT) Johannesp E39 M5 and E52 Z8 Discussion 1 21st June 2006 20:56
UFMotorsport intake air temp. sensor installed! XrayMD E39 M5 and E52 Z8 Discussion 144 29th April 2005 01:24
Page generated in 0.16868 seconds with 11 queries
