So I believe one or both of my M Audio subs is blown. I get that classic speaker farting with bass hits and even with just hard bumps in the road. As if the speaker cone is literally broken.
My car is in today getting a new dash cluster and I decided I wanted to laugh so I asked them if they could source a pair of OEM subs. Price quote $400 each, enter the laughing. So I went on real OEM and found that they were acually $89 a piece, told the dealer and they said I have the wrong part number
Does anyone have a solution for this issue? I just want to hear my bass and not the speaker farting! Im not looking to upgrade just fix this problem!
Ryan
2001 M5 Carbon Black/Black Extended
Hella Euro Headlamps/Umnitza LED Angel Eyes/UF IATS/MVIV NAV Computer/20% Tint all around
2008 Ford Explorer Eddie Bauer 4x4. Takes the bad weather beating for the beast.
1995 Ford Mustang Cobra
2006 SeaDoo RXP
Ryan
Since your crappy OEM subs are toast, you might take the opportunity to replace with a good aftermarket sub/subs. I went the BSW route and couldn't be happier, but there are a lot of options out there. Personally, I wouldn't waste my money on anymore OEM speakers. BMWs aren't generally known for their sound systems.
Brian
__________________ 2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar Super Sprint Headers Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around) Supercharged by ESS!! (Kit number 01)
Brian
Brian,
Did you remove the stock subs or just disconnect them? I have thought of doing the BSW route but they obviously don't have a replacement for their crappy open air OEM subs.
I still have a JL 8'' W7 from my old Audi that I have considered putting in. It hits 10x harder then both the OEM's combined.
-Ryan
2006 SeaDoo RXP
Would be interested to hear what others have done. I would like to remove my subs COMPLETELY, and put in replacements that would lack a little bass, but at least I would have a full-sized trunk at my disposal.
IMHO, the stock M-Audio subs aren't worth dragging them around with me all the time.
If someone has any suggestions, I'll happily sell you my subs for a good price .
Brian,
-Ryan
Hi Ryan,
In order to install the BSW sub enclosure, you completely remove the 10 inch OEM subs. The enclosure box then is affixed underneath the rear deck into the trunk with the woofer firing down. For what it's worth, I have seem many different configurations for subs on M5s. I am sure that one can get a "better" sounding sub than BSW for a lower price...the benefit to the BSW system is simplicity and ease of interaction with the stock system. The downside, is that with any sub enclosure, you do lose trunk space.
Cheers,
Brian
Ultimate Pedals
Hi Ryan,
Cheers,
Brian
Good to know. BSW does not indicate how to install their box on a M audio equipped car. I assumed it was similar to the DSP only system install but you verified it for me! Where did you mount your amp?
-Ryan
2006 SeaDoo RXP
-Ryan
Back of seat or under m-mobility kit. I did the latter.
I did the same...took out some of the foam molding used to hold the M-Mobility jobby, put the amp on a pad and used some of the original packing material for the amp to gently "wedge" it in to prevent movement (during high speed maneuvers ).
I found this easiest and provided quick access during tuning/calibration.
Brian
Ultimate Pedals
