Old 5th June 2008, 19:22   #1
Stamper1
Stamper1's Avatar
Garage: 2000 M5 silver
O2 Sensor Failure? symptoms?
I need some help here guys, need to know what the symptoms are for o2 sensor failure?. Would it induce limp mode?, and what would cause it to fail?. How much labor is involved to replace them and what are the costs involved?. Whats the primary function of the o2 sensors?. Thanks in advance.
Stamper1 is offline
Old 5th June 2008, 19:39   #2
Neil.D
Neil.D's Avatar
Garage: E39 M5 - Titanium Silver
Hi Stamer,
the O2 sensors read the fuel/oygen levels from the exhaust and adjust the mixture accordingly.
Symptoms can be poor fuel consumption, black soot from the exhaust, poor accelleration, hesitancy - to name just a few.
Im not sure but it could induce limp mode if one is on its way out.
The engine may do so in order to protect itself as mixture is important.
Mine were replaced recently, the parts were £130 each (there are 2) and about 20 mins fitting. In total all was about £330. Sorry dont know conversion rate.
If you have a ramp/pit all you need is a screw driver and a spanner really. I think there are instructions in the FAQ area...
Neil
2000 M5 Titanium silver
Neil.D is offline
Old 5th June 2008, 19:48   #3
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Failure in O2 sensor would throw a SES light, whose code correspondes to an O2 sensor failure. Each sensor is about $100 off of pelicanparts.
everycredit is offline
Old 5th June 2008, 21:10   #4
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 Titanium Silver
Send a message via AIM to Mike S. Send a message via MSN to Mike S. Send a message via Yahoo to Mike S.
This post might help you out a little bit if you decide to replace them:
http://www.m5board.com/vbulletin/sho...6&postcount=25
The info is almost a year old, so the prices might have gone up.
This is an easy DIY. Extremely easy.
"Bugslayer" 2003 M5 - Powertrain: Magnaflow 14816, E60 545i Short Shifter Exterior: Xenonmatch Lamps, Stealth Auto Black Kidneys Interior: Hardwired V1, Ultimate Cupholders, OEM AUX Audio Input.
Mike S. is online now
Old 5th June 2008, 21:49   #5
jclyman
jclyman's Avatar
Originally Posted by Neil.D View Post
Mine were replaced recently, the parts were £130 each (there are 2) and about 20 mins fitting. In total all was about £330. ...
Neil
I believe there are 4 (2 pre-cat, and 2 post-cat). The pre-cats are the ones you speak of in your post, Neil.
The post-cat sensors compare their readings with the pre-cat ones. Too much difference, MAY trigger an SES light.
At least, that's the way I understand it.
- Daniel Boorstin
jclyman is offline
Old 5th June 2008, 22:31   #6
everycredit
ja, just make sure the car is cold first.
Old 5th June 2008, 23:20   #7
Neil.D
Neil.D's Avatar
Such attention to detail...
indeeed there are. 2 pre and 2 post. The Post just measure the emissions post cat to ensire the CATS are working correctly.
I hear that should your CATS, and therefore your emmisons be ruined then the SES light flashes at you...
Neil
Neil.D is offline
Old 6th June 2008, 11:28   #8
Stamper1
Stamper1's Avatar
THANX FOR THE HELP GENTS
Stamper1 is offline
Old 6th June 2008, 14:21   #9
RUFM5
Garage: M5 modded
I bought the pre CAT O2 Bosch#13477 sensors for $57 each at Rockauto. Not a bad deal.
http://www.rockauto.com
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
Evosport Under-Drive Audiophile Pulley Kit
Braille B3121 21lbs Racing Battery (OEM 64.5lbs)
Braille Premium Power Protector
Custom Magnaflow High Flow Metallic CATS (#59926)
Perma-Cool High Performance Electric Fan
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Custom HD Sink Drain brake duct cooling mod
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
Armano Vanquish Chrome 18inch Wheels
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, ///M oil cap
CNS Racing 3.62 Differential Upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators
UUC RK6A-L knob
DENSO Iridium Plugs
Alutec Strut Bar
RUFM5 is offline
Old 3rd August 2008, 19:24   #10
hailey198
Garage: E39 M5 - green
O2 sensors
Bimmer Specialist
I found this company that sells before cat sensors OEM for $60. This is the best price I could find. Post cats at $95.
When I replaced mine, the car had significant improvement in performance. The car had been misfiring a bit and definitely hesitating.
It runs great now. Cleared sensor codes and SES light is gone. Hopefully for a while. I have a 2000 M5 with only 36,000 miles. The car sat idle for some time and I think no matter what these sensors go bad with time. MAF sensors were replaced just prior! - Hailey
hailey198 is offline
o2 / Oxygen Sensor Test How-To nathanielbrown E39 M5 and E52 Z8 Discussion 7 30th December 2007 19:23
O2 Sensor(s) questions when removing Headers keang24 E60 M5 and E61 M5 Touring Discussion 36 18th October 2007 19:44
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
MAF+ O2 Sensors = Consummables? chunpng E39 M5 and E52 Z8 Discussion 11 25th November 2005 15:44
BMW DME post-cat O2 sensor connections XrayMD E39 M5 and E52 Z8 Discussion 21 15th September 2005 05:04
Page generated in 0.16970 seconds with 11 queries
