Old 11th May 2008, 06:45   #1
Jim Green
Jim Green's Avatar
Garage: 428bhp Cosworth Sapphire
Rear Wheels on Front......Extended Wheel Lugs...???
Managed to get a pair of rear wheels to put on the front and organised 5mm spacers........What length wheel studs/bolts do I need to get....???? I'm not with the car at the moment, so cant take off a stud and measure it up to see what the standard size is and then plus 5mm.......Help.
Jim Green is offline
Old 11th May 2008, 07:34   #2
Vason
Vason's Avatar
Garage: '03 M5 - Carbon Black/Caramel
Sales Feedback: (4)
Standard is 25mm which is the threaded length. You would need 30mm bolts.
'03 M5 Carbon Black/Caramel
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
Old 11th May 2008, 08:07   #3
Mike (Austin)
Mike (Austin)'s Avatar
Garage: Jet Black 2001 M5
Sales Feedback: (4)
I used a 30mm, but with a 3mm spacer. Luke @ TireRack.
2001 Jet Black M5
-OEM Brake Duct mod +Foglight Covers w/Vents for Custom 3" Polished CAI w/AEM Dryflo filters
-9.5" OEM wheels all around (265F w/3mm spacer & longer studs/275R)
-Dinan FSTB
-OEM TV Tuner w/Camera Input + DVD
-Rear Alpine 6.5" widescreen monitor (TME-M760/BMW OEM rear screen)
-Phoenix Gold ZX500 Amp +BSW single 12" enclosure w/Alumapro sub + Optima Red Top 34R
-Misc satin black and carbon fiber trim
1991 Aztec Red 300ZXTT - 600rwhp @ 21psi
2004 Obsidian Black Infiniti FX35 daily driver #1
2003 Starlight Silver Honda Odyssey daily driver #2
Mike (Austin) is offline
Old 11th May 2008, 08:08   #4
Mike (Austin)
Sales Feedback: (4)
Plus don't forget the black stud covers if you want them to match the OEM rears...
Old 11th May 2008, 17:09   #5
exigtis4m5(?)
exigtis4m5(?)'s Avatar
Garage: LMB 2002 M5
Sales Feedback: (5)
if you seach for this topic, you will find my post, where someone on the board (I forget who) got me extended lugs in black (w/s putting caps on). If you would like that and cant find my thread, pm me. thanks
exigtis4m5(?) is offline
Old 11th May 2008, 17:38   #6
Mike (Austin)
Sales Feedback: (4)
I'd like to know that, too. I had looked to no avail. Keep me in the loop!
Thx
Old 11th May 2008, 17:44   #7
britm3
britm3's Avatar
Garage: 02 M5 LSB/Caramel
The OEM bolts are 25mm long, for 3mm spacers I used 28mm bolts from Turner Motorsport.
02 M5 LSB/Caramel - Sold :]
TMS Shark Injected
IATS
Euro Ducts / Stoptech Lines
Tubi Regular
Evosport Pulleys
E60 SSK w/ZHP
BSW Stage 1 and BSW Sub
Intravee II
V1 + StealthOne
Euro Hellas @ 55w / Fogs @ 35w HIDs
britm3 is offline
Old 11th May 2008, 18:23   #8
graffix000
graffix000's Avatar
Garage: Jeep GC, 03 M5, 05 Yukon Denali
I'd like to know as well as I plan to do this as well in the near future.
thanks
graffix000 is offline
Old 11th May 2008, 18:30   #9
Need4Spd
Need4Spd's Avatar
You should use 3mm spacers, not 5mm. The extra 2mm will prevent your wheels from indexing properly on the hubs, leading to wobble and vibration. Do a search on this. Widely documented.
Need4Spd
Need4Spd is offline
Old 13th May 2008, 06:56   #10
INDIVIDUAL 5er
INDIVIDUAL 5er's Avatar
Garage: '03 Aegean Blue/Champagne 540i (Sport/M-Tech)
Send a message via AIM to INDIVIDUAL 5er
HELP a newbie...
Would I need extended wheel lugs when upgrading from my stock M-Pars to bored out "Style 101 M's" in the size 20x9 (fronts) & 20x10 (rears) with ET24mm all around ?
INDIVIDUAL 5er is online now
BMW M3 - english pressrelease (with lots of pictures) kees E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 43 18th May 2007 15:09
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
Stock Rear Wheels on The Front? Need4Spd E39 M5 and E52 Z8 Discussion 13 27th November 2003 09:31
M5 wheel and tire dimension survey stever E39 M5 and E52 Z8 Discussion 0 15th April 2001 00:21
Page generated in 0.16501 seconds with 11 queries
