• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 10th May 2008, 06:27   #1 (permalink)
          murph550
          murph550's Avatar
          Painted the Kidney Grills
          My friend and I were bored earlier so I talked him into spray painting the grills on his m3 to see whether or not I wanted to go through with painting mine. In the end I did and am extremely happy with how mine turned out, however I think I may spray a clear coat over them to make them a tad bit more glossy.
          Before:
          After:
          I used rustoleum (sp.) professional enamel. I was considering using the high heat, but when I test sprayed it it appeared to dry much grayer than this did. All in all cost me $2, split the cost of the can with my friend.
          '02 LeMans Blue/Caramel V1 Hardwired, e60 SSK/ZHP Knob
          murph550 is offline
          Old 10th May 2008, 06:51   #2 (permalink)
          malexgcab
          malexgcab's Avatar
          I was gonna bring my grills to a body shop to have it painted.
          Did u have to prep the grills such as sanding it prior to painting? What's (sp.)? So, without the clear coat, how does the black look (matte, deep black, grayish)?
          Do u think the paint will withstand the road debris?
          malexgcab is offline
          Old 10th May 2008, 07:04   #3 (permalink)
          murph550
          murph550's Avatar
          I painted them at like 8 - 9 o'clock so I really have no clue as to how well they will hold up. I didn't prep them at all so I have a feeling they may chip over time, but If that happens ill just sand em down and use a primer next time. Spray paint is so cheap and they really aren't to hard to pop out so re-doing it isn't a huge concern for me. As for the color it is a matte black, slightly lighter looking than the black trim on the bumper. However, this was under fluorescent light so under the sunlight they may appear a bit less matte due to the glare. I will see how they look in the morning though. The paint I used was "industrial strength" and after about 2 hours of drying seemed rock solid (i sprayed on coats in 5 minute intervals so it was pretty thick), so who knows maybe they will last. As for going to the body shop If you take your time doing them yourself I see no reason to pay a shop to do it. It took me about an hour tops, so if you decide to take your time with prepping them I would say spend the 4 dollars and 2 hours and do it yourself. Also, be sure to spray too closely as to avoid drips, and don't let any dust/particles get on them, cause it is a bitch to fix without restarting from the beginning. Oh, and (sp.) meant spelling since I was unsure how to spell Rustoleum. The paint I used is this, http://www.mclendons.com/item.asp?sku=10953096 and I got it at Home Depot. It was $4.75.
          murph550 is offline
          Old 10th May 2008, 16:22   #4 (permalink)
          malexgcab
          malexgcab's Avatar
          Thanks for the info. I might just do it instead of having the body shop.
          Old 10th May 2008, 17:51   #5 (permalink)
          Blockdoc
          Blockdoc's Avatar
          They WIll chip
          FWIW,
          I did the same thing for a year or so to save a couple of bucks...despite sanding/priming, and using very good paint...the rocks will chip and the silver will show through. FInally got tired of repainting and bought some aftermarket black ones...no more chipping. I figured I spent way too much time refinishing them to justify not buying some black ones.
          I do think the look is SO much better tho.
          Brian
          2003 Sterling Grey M5
          Dinan Stage 1 Software, Dinan Free Flow Exhaust, Dinan Rear Sway Bar
          Rogue Octane SSK and WSR
          DICE Ipod connectivity
          Bimmian Black Kidney Grilles
          Predator Ice V2 Angel Eye 6000k LED Upgrade
          Ultimate Pedals
          Rear Wheels Up Front (275s all around)
          ESS Supercharger...COMING SOON!
          Blockdoc is offline
          Old 10th May 2008, 18:00   #6 (permalink)
          Diny
          Diny's Avatar
          Looks good for now but don't be surprised if they start to chip.
          I got some black grills from ebay and got them painted glossy black for 50 bucks each. Now I have a set of black and the factory chrome in storage, so I can swap whenever I feel like a change.
          /// 00 Anthracite/Black
          "Weeeeeeeeeeeeee!!!!!" - M5 Passenger
          Diny is online now
          Old 10th May 2008, 18:41   #7 (permalink)
          m5hor
          m5hor's Avatar
          you guys might want to try a self etching primer.. i used it on i bike i am building..i couldn't get the rims to get back to chrome/polished so i painted them black.. i am not finished with the bike yet so i don't know how well it holds but might want to look into it..
          2001 m5 (rosie)
          m5hor is offline
          Old 10th May 2008, 19:59   #8 (permalink)
          iconoclast
          if youre going to use 'rattle-can' paint, plasti-dip is the way to go... its a satin finish that is still black, doesnt have a grey tint/hue to it.
          iconoclast is offline
          Old 10th May 2008, 21:10   #9 (permalink)
          155plus
          155plus's Avatar
          Originally Posted by murph550 View Post
          Before:
          You need some HID fogs...
          '03 LMB/Caramel
          Dinan 3.45, JRZ stage 3, swaybars, short shifter, sf
          V1/Stealthone and Lidatek - when V1 won't help...
          Black kidney's, iBright V3 angel eyes, HID fogs, and tint
          Illuminated M5 door sills (now that's very, very cool!)
          Magnaflow 14816s, euro brake ducts
          To come:
          Nothing - the mod itch has been scratched enough...
          155plus is offline
          2007 m5 being painted today brainblade E60 M5 and E61 M5 Touring Discussion 13 15th April 2008 04:05
          Kidneys Getting Painted -Need Advice BD 997 E60 M5 and E61 M5 Touring Discussion 17 17th October 2007 04:07
          Painted Kidneys Semi-Gloss Black COMA E39 M5 and E52 Z8 Discussion 30 15th August 2007 05:29
          Light tinting & painted trim VetteRacer E39 M5 and E52 Z8 Discussion 0 8th March 2007 08:35
          Kidneys black chrome any Carbon ? Carrera2RS E39 M5 and E52 Z8 Discussion 6 11th April 2005 23:10
