Rear Wheels On Front........... - BMW M5 Forum and M6 Forums
Old 2nd May 2008, 09:02   #1
Jim Green
Jim Green's Avatar
Garage: 428bhp Cosworth Sapphire
Can someone remined me what's involved in fitting a pair of rear wheels to the front of my E39 M5. I read that it improved turn in, and reduces front understeer.
I seem to remember reading that I need to fit a spacer, but obviously want to keep this to the minimum. Car has standard brakes and suspension....
I'm in the UK, so if someone knows where to get hold of a quality spacer that would be great, or might have to get one from the US.
Jim Green is offline   Reply With Quote
Old 2nd May 2008, 15:39   #2
RoundelM5
RoundelM5's Avatar
Garage: 2003 M5 - LeMans Blue
Sales Feedback: (12)
Tons of posts on this that a search should pull up. Need 3mm spacers (from Luke at Tirerack) and longer wheel bolts (also available from Tirerack). Otherwise, they should install flawlessly.
'03 Lemans Blue/Black
Suspension: Ground Control coilovers 550F/400R, Dinan adjustable rear sway bar, TC Design Rear Swaybar Brackets
Drivetrain: Dinan 3.45 differential and LTW flywheel, Rogue SSK w/ WSR
Wheels/Brakes: Dinan LTW wheels, TMS 75mm Wheel Studs
Intake/Exhaust: AA CAI and brake ducts with IATS relo, Supersprint headers with Tubi Regular cat-back exhaust
Cooling: Gulf oil filter housing and Setrab 16 row oil cooler
AngeliBright v2.0 w/ matching fogs and highbeams
BMW Bluetooth, Sirius, First Aid Kit
'95 M3 Track Car CosmosSchwarz
Motor: stock S54; VAC rod bears and high-volume competition oil pump; Dr. Vanos cryo-treated exhaust hub
Suspension: BW/JRZ DA coilovers 800F/950R, TMS sway bars, camber arms, monoballs, solid mounts and bushings
Drivetrain: BW strapless clutch/flywheel, AKG race shifter w/ WSR, DiffsOnline 3.64 variable ramp, polished gears
Wheels/Tires/Brakes: APEX ARC-8, Hoosier R6, BW 92mm/75mm wheel studs, BMW OE calipers, PFC06 pads, PFC DD rotors, BW brake cooling
Intake/Exhaust: VAC carbon fiber race intake, Epic race headers and AA 3" race exhaust
Tune: Epic alpha-n custom software
Cooling: Bimmerworld/C&R aluminum race radiator and oil cooler; Spal 2-speed fan
Safety: Full cage, Cobra Evolution driver seat and Cobra Imola passenger seat, Schroth Hybrid-II HANS harnesses, SPA fire system, Schroth window/center nets
Aero: BW splitter and wing
Data: AIM Pista MXL and SmartyCam
RoundelM5 is offline   Reply With Quote
Old 3rd May 2008, 06:03   #3
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Yep. Roundel just gave you all the info you need.
I did this mod in the fall, love it. Do it, you won't regret it.
Lancefitzgiben is offline   Reply With Quote
Old 3rd May 2008, 06:14   #4
Jim Green
Jim Green's Avatar
Many Thanks............
Jim
Old 3rd May 2008, 07:16   #5
ard
Super Moderator
ard's Avatar
Spacers are available all over the world! H&K,. beastpower, etc, etc.
3mm spacer, 5mm longer bolts are fine (the extra 2mm on the bolt isn't an issue)
A
Old 3rd May 2008, 07:41   #6
Jim Green
Jim Green's Avatar
Tks Ard.....appreciate that info. Just wanted to make sure I knew where to go to get a "quality" spacer.
Old 3rd May 2008, 08:47   #7
Stu @ M Developments
Stu @ M Developments's Avatar
Garage: 2001 BMW E39 M5
Quite interested in this myself actually but have literally just bought a fresh set of PS2's yesterday so will wait till they have worn out i guess, but the ring trip next week should accelerate that nicely.
Not fancy coming with us Jim? I know of a cheap crossing and room on offer due to a dropout... .
Best Regards,
Stu
Drives: A 2001 Silver E39 M5.
Stu @ M Developments is offline   Reply With Quote
Old 3rd May 2008, 17:10   #8
ard
Super Moderator
ard's Avatar
The term "spacer" freaks some people out... once you actually LOOK at a **3** millimeter spacer, you'll realize how little is really there. Bascially the only think that they can screw up is making it the wrong thickness or drastically thick and thin. Even if the holes are in the wrong position, as long as the bolts go through it should be fine. That said, you should have no problem sourcing them over there... and it's "H&R" ... H&K is for different hardware.
Old 3rd May 2008, 18:59   #9
Super-saloon
Super-saloon's Avatar
Garage: e39 M5, Carbon Black
Hey Jim, please post some pics when you are done and of course, a full write-up...Thanks!
2002 Carbon Black e39 M5 Super-Saloon
Miltek Cat Back exhaust system
Miltek Racing 100 cell CATs
De-limited
Re-mapped (Superchips/Thorney stage 2)
AP Racing BBK
KW Variant 3
Super-saloon is offline   Reply With Quote
Old 3rd May 2008, 19:41   #10
Lancefitzgiben
Hahahaha!
- Tim
BMW M3 - english pressrelease (with lots of pictures) kees E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 43 18th May 2007 14:09
F/S OEM wheels ( chromed) 2 front 1 Rear + 2 PS2 tires Lohe Parts / Other For Sale or Wanted 1 29th March 2007 03:18
Rubbing issues with SSR GT2 9" wheels & 275/35 tires front and rear jcrist E39 M5 and E52 Z8 Discussion 8 18th March 2007 07:32
Parting out a e39 540. HUGE LIST of parts. OEM and Aftermarket 525iT_Feen Parts / Other For Sale or Wanted 37 12th September 2006 17:52
Anybody Run 18 Inch front and 19" rear wheels? Jayson E39 M5 and E52 Z8 Discussion 1 26th February 2005 06:51
