• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 16th December 2001, 04:11   #1 (permalink)
          Cerberus
          Help! Installing SS resonator pipe
          Has anyone installed the pipe on themselves?
          I have my exhaust off from the header downpipe which connects to the catalytic convertor pipe.
          The problem I am having is getting the resonator pipe to fit over the pipe just after the O2 sensors. They are too close in diameter to slip together.
          Is there a tool that can widen or spread open the diameter of the resonator pipe slightly? Thanks.
          Sandy
          Cerberus is offline
          Old 16th December 2001, 04:25   #2 (permalink)
          TCM
          TCM's Avatar
          Sandy:
          Yes, there is a tool that you can use. Most muffler shops have different sized cylinder shaped metal cones that are pounded into the end of the pipe to make it wider. Sounds very old school but it works. Bring it to an exhaust shop and see if they can do it for you. You could also get out a torch and heat the end of one of the pipes and then try to fit it over the other pipe. Good luck.
          T.C.
          '01 Silverstone M5
          SuperSprint:X-pipe
          TCM is offline
          Old 16th December 2001, 05:48   #3 (permalink)
          Cerberus
          T.C.
          Thanks again for the advice. I just went to my local Autozone shop and borrowed a "tailpipe enlarger".
          Hopefully, this will do the trick tomorrow when I put it back together.
          Sandy
          Cerberus is offline
          Old 17th December 2001, 01:49   #4 (permalink)
          Bart Carter
          Bart Carter's Avatar
          The cone is used to make pipes round. You can use it on the inside or the outside.
          What you want, if you want a slip fit, is a pipe expander. It fits inside your pipe and you expand it with a wrench. Turn it slightly and reapply so the pipe ends up really round.
          Now, the best way to join pipes, and be able to take them apart, is to weld flanges to each pipe and bolt them together. If you go this route, have one tube extend past its flange so it actually goes into the 2nd flange, even with a gasket. No leaks!
          A good shop should be able to do anything you want.
          -Bart
          2002 Bluewater/caramel
          Any other car is a compromise
          Bart Carter is offline
          SS exhaust/X pipe Ny owners tmacsilverm5 E39 M5 and E52 Z8 Discussion 20 7th January 2003 00:07
          SS with x-pipe install & dyno! XrayMD E39 M5 and E52 Z8 Discussion 44 26th December 2002 17:58
          1st impressions: SS exhaust + x-pipe vs. B&Bs (long) Teutonaddict E39 M5 and E52 Z8 Discussion 17 6th May 2002 22:18
          MY FIRST RACE AGAINST A Z28 SS CAMARO.. HBRAMSTEDT E39 M5 and E52 Z8 Discussion 32 17th May 2001 08:15
          Page generated in 17.77982 seconds with 11 queries
