13th December 2001, 19:06
#1
Administrator
BMW E39 M5, Carbon black
Drive train power loss?
My E46 M3 was dynoed recently it from the dyno graph I can read that in only has 10% power loss. That sounds a little bit to little.
Any ideas what could be reasonable and why the dyno show so little drive train loss?
Anyway my stock M3 had 310RWHP and 386,5Nm torque.
Cheers,
/Johan
14th December 2001, 02:08
#2
I was thinking about this.... don't you think the drivetrain power loss would increase over time as the clutch wears out?
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
14th December 2001, 02:57
#3
Administrator
Terrence,
If the clutch slips there will be a higher drive train loss than normal even if slips ever so little. Some of the power will be transformed into heat instead of pulling the car.
Cheers,
/Johan
14th December 2001, 03:15
#4
2008 M6 - Alpine White
Yep, true. But, thats only if the clutch is slipping badly. If it still grips the drivetrain loss should not increase.
I hear the drivetrain loss can be anywhere from 15-20%, Johann that is one powerfull M3 you got there, what type of dyno was it?
Pio
2008 AP M6 SMG (19" HRE C20's, Yellow Brembo's w/ Slotted Rotors , ASR exhaust & Intake)
Evosport Pulley & Headers NEXT!
2007 Black 750 Li
Notables no longer in the stable:
2001 M5 Dinan Stuff
2001 C5Z
2003 CL55
2005 C6
2006 C6Z (Sc'd 611 rwhp / 580 rwtq)
2003 C5Z (SC'd735 rwhp / 680 rwtq)
14th December 2001, 17:36
#5
Administrator
Pio, By every % the clutch slips you'll have as much drive train loss, right?
I think the Dyno is made by Bosch.
Cheers,
/Johan
14th December 2001, 18:00
#6
Tricycle
Those are strong numbers.... don't complain!
Duncan
14th December 2001, 18:07
#7
Administrator
M5Laser,
I am not complaining, just curious to know the fly wheel hp.
Cheers,
/Johan
14th December 2001, 19:15
#8
2000 Mustang Cobra R
15% is usually pretty typical... although many factors play a part in this ... like:
1) clutch
2) tranny
3) rear diff - not so much the gears, as much as how efficient the diff is at transferring torque and HP
4) and last but not least the dyno itself.
My M5 has been dyno'd at 335 RWHP which translates to about a 15% loss.
Using the same 15% logic my Cobra R has been dyno'd at 375 RWHP which translates to about 440 at the crank.
Andy
'00 Imola Red M5 - sold 4/02
'00 Mustang Cobra R - #155 of 300
'02 F-250 SD Powerstroke Crew Cab 4X4
'00 Honda Accord V6
Search this Thread
Linear Mode
