Old 18th April 2008, 23:08   #1
xom
xom's Avatar
Garage: 2002 M5 Carbon Black
Clutch slipping sanity check.
Ok I'm pretty sure that my clutch is slipping but just wanted some confirmation.
Yesterday I had it in sport and DSC off, turned left and gave full throttle which caused the rear to briefly brake traction. I shifted to 2nd and full throttle and engine rev'd to 6k and I wasn't really moving anywhere close to what I should have. Shifted 3rd and same. It is fine around town and on the highway. It just seems at 8/10ths or so the slipping happens.
thanks.
xom is offline
Old 18th April 2008, 23:30   #2
Bigbenny
Bigbenny's Avatar
Garage: 2000 M5 Carbon Buildup Black :)
Sounds like you glazed your clutch.
But this does not mean it's the end of the clutch you have in there right now. From the sound of things, prepare to get a new clutch disc, pressure plate, and either a new flywheel, sand yours down lightly or get it resurfaced.
How many miles are on your clutch? When you go 8/10ths what gear are you in?
I know that sometimes if a clutch is glazed you can just drive it very gently for a while and the glazing wears off, but if yours is slipping in higher gears at 80%, it may be time for a replacement. I'd look up more on the glazing to see if anyone else has encountered this. I'm betting you're not the only one. Luckily the clutch is easy to replace and won't make you broke doing it.
Bigbenny is offline
Old 18th April 2008, 23:35   #3
xom
xom's Avatar
Clutch has 72k and I'm in 2nd and then 3rd and it slips.
I've made an appointment to get it replaced. Thank you for the confirmation.
xom is offline
Old 18th April 2008, 23:42   #4
Bigbenny
Bigbenny's Avatar
72K is not bad at all for a clutch on a M5. Especially good in hilly San Fran. These cars do take a bit of punishment lugging around 4000 pounds and by throwing 400 hp at it. When it's done at least you won't have to worry about your clutch, right.
Oh, when you get it done please tell me how much it put you back and where you got it done, dealer vs. and indy shop. I might be replacing mine sometime just to get it out of the way. Thanks.
Bigbenny is offline
Old 19th April 2008, 23:20   #5
Fitz
Fitz's Avatar
Garage: 2003 E39 M5, black
You say you got 72K miles out of a stock (OEM) clutch? That's amazing. I only got 25K from mine.
Are you replacing with another stock one?
FASTFitz
Virginia
Fitz is offline
Old 21st April 2008, 06:16   #6
RUFM5
Garage: M5 modded
thanks.
Sounds like you have glazed the organic clutch disk. Very common issue on the OEM clutch.
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
Evosport Under-Drive Audiophile Pulley Kit
Braille B3121 21lbs Racing Battery (OEM 64.5lbs)
Braille Premium Power Protector
Custom Magnaflow High Flow Metallic CATS (#59926)
Perma-Cool High Performance Electric Fan
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Custom HD Sink Drain brake duct cooling mod
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
Armano Vanquish Chrome 18inch Wheels
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, ///M oil cap
CNS Racing 3.62 Differential Upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators
UUC RK6A-L knob
DENSO Iridium Plugs
Alutec Strut Bar
RUFM5 is offline
Old 21st April 2008, 06:29   #7
tstaples
tstaples's Avatar
Garage: '02 Sterling Gray M5
Sales Feedback: (4)
Fitz,
My M5 is pushing 75k on the original clutch, and it is still quite strong. The previous owner didn't abuse it. (Thanks PilotMike!) The stock clutch is actually quite good, but will not tolerate excessive slipping. if you match revs while shifting, and don't mat the gas fully until the clutch is fully engaged (i.e. proper manual transmission shifting techniques), then the clutch will be quite durable.
When i was 10, my dad taught me to drive on an ancient '46 Willys surplus army Jeep with a non-syncromesh tranny. You HAD to shift correctly or you went nowhere!
-Tony Staples
'05 SL65 AMG - Designo Espresso Edition - OMFG! Torque!
'02 M5 - Sterling Gray/Black - New Commuter Pod!
'02 530i Manual Sport - Better Half's
'02 Lexus IS300 Sportcross - Daughter's new Rizzide!
'88 911 Carrera Cab - Indischrot/Cashmere - Canyon Carving GoCart!
'04 X5 4.4i Sport - Commuter Pod - Sold!
"There is a fine line between a hobby, and a mental disorder." - Dave Barry
tstaples is offline
Old 21st April 2008, 07:10   #8
ard
ard's Avatar
Uh, I replaced mine at 94k... and it didn't need it! (Had a rear main seal replaced under CPO warranty, so I went and did the clutch.) I looked at the disc and there was still meat on it.
I drive way too fast, but I rarely (perhaps never?) 'break the tires loose'... in any gear. (Uh, why? You actually go slower when your tires are spinning...) You can wring alot of performance out of an M and not destroy the clutch that we hear about so often....
ard is offline
Old 21st April 2008, 15:52   #9
Fitz
Fitz's Avatar
This is the first I've heard of long-lived SAC clutches - and very good to hear. Mostly I've heard the horror stories. As I was the second owner, I can't say how the first drove the car, my OEM failed catastophically at 25K miles. Didn't start slipping, just disintegrated like nothing I've ever seen.
As they say down under, "Good on ya!"
FASTFitz
Virginia
Fitz is offline
Old 21st April 2008, 16:10   #10
slayer1974
slayer1974's Avatar
Garage: 2001 M5 in Metallic Carbon Black & 1992 E34 M5 in Avus Blue.
Tyres?
Hi, was it wet when your did this? How are your rear tyres for wear? Sounds like you either spun the tyres OR you floored the accelarator before fully disengaging the clutch and just slipped the clutch yourself, it does'nt necesarely mean your clutch is smoked, regards, Ste.
///M5
slayer1974 is offline
Replacing the E39 M5 Clutch and Flywheel with Original Equipment OldRanger M5 E39 and E60 tips & tricks 11 31st August 2009 20:58
Slipping Kevlar Spec 2 clutch after 25000 miles? 12sec4dr E39 M5 and E52 Z8 Discussion 2 3rd June 2007 18:47
# 2 inspection rebel1 E39 M5 and E52 Z8 Discussion 14 8th March 2004 03:00
Help!! Clutch is slipping..... MThis E39 M5 and E52 Z8 Discussion 2 13th October 2003 04:03
slipping clutch fais2000 E39 M5 and E52 Z8 Discussion 9 28th September 2000 04:34
Page generated in 0.14672 seconds with 11 queries
