18th April 2008, 23:04
#1
Silver 2000 M5
Fuel consumption for MAF testing is high?
I'm hitting 160L per hour using the information on this thread,
How to test the MAFs yourself and How MAFs work
i assume im running rich since the FAQ says 140L per hour is what should be normal
.: 2000 BMW M5 ::
HRE C21 19x8.5 and 19x10, Toyo Proxes T1R 255/35/19 (f) 285/30/19 (r), Bilstein PSS9 coilovers, Britalman X-pipe and Exhaust system, Britalman intake system, Exotics Tuning carbon fiber front lip, Range Rover 16:9 Nav screen, Dice ipod adapter, Ecode Angel eyes Xenon, LED rear tail update, black vinyl roof
Van Wilder : You shouldn't take life to seriously. You'll never get out alive.
Old::
2002 Audi A4 Avant
19x8.5 BBS RS-GT, Toyo T1R 245/35/19, GT27RS turbo kit, Revo software, Sportec front and sideskirts, S4 rear bumper, custom exhaust, Topspin Design sport seats, H-Sport S4 swaybars, AWE boost gauge
www.dogparktalk.com
18th April 2008, 23:18
#2
01 M5 Black/caramel
Originally Posted by
bugzy
No, that is just considered the minimum acceptable flow. 160 is excellent!
18th April 2008, 23:24
#3
Silver 2000 M5
but im having hesitation issues
and i got check engine light with MAF code and bank 1 and 2 are running rich codes
.: 2000 BMW M5 ::
Old::
2002 Audi A4 Avant
www.dogparktalk.com
19th April 2008, 00:16
#4
01 M5 Black/caramel
bugzy
Perhaps there are problems, but based on your flow numbers, it does not point to MAF's. However, they are cheap enough to replace, less than $200 a pair. Worst case is you have a spare set for when you really do need to replace.
MAF failures do not usually cause running rich, usually bad MAF's result in not enough fuel, so if anything, I would expect lean. However, if you have an air leak after the MAF's then you will run rich as all the air the MAF "sees" is not getting to the engine. Check the plumbing from the MAF housings back to the plenum, including the little gasket where the tubes go into the plenum housing.
19th April 2008, 01:12
#5
Didn't you just replace your O2 sensors and your cats?
19th April 2008, 02:26
#6
Silver 2000 M5
i havent replaced my o2 or cat's yet
.: 2000 BMW M5 ::
Old::
2002 Audi A4 Avant
www.dogparktalk.com
19th April 2008, 03:52
#7
I thought you needed to? That'd be my thought as to why you are running rich. If the O2's or Cat's aren't working correctly then you'd run rich. And if your Cat's are bad then something else went bad that you need to fix as well. Cat's don't go bad for no reason under 500k.
24th April 2008, 03:01
#8
Silver 2000 M5
Well got my SES cleared last week, and cars been running beautifully so far
new spark plugs, new MAFS, coolant temp sensor ...
so far so good
.: 2000 BMW M5 ::
Old::
2002 Audi A4 Avant
www.dogparktalk.com
Search this Thread
Linear Mode
