Old 18th April 2008, 09:16   #1
Terabass
Terabass's Avatar
Garage: M5 Black
Smog/Recall Problem: Peak Code: P0171 / P0174 -- MAF's/Dinan Software or Emissions Recall?
I just bought a 02 BMW M5.
I bought it through a dealer that I know well, the car was repoed previously but I got a good price. He told me to take it to smog myself.
It has the Dinan badge on the back.
I called the shop that installed all the Dinan and they said the car had the Cold Air Intake and Dinan Stage 1 and Stage 2 software installed, and more but irrelevant to this subject matter.
I popped the hood and it looks like the Dinan Cold Air Intake was removed by previous owner and stock has been installed.
I tried to get the car smogged, they reset all the codes and then got the following codes from the Smog Machine:
I am getting peak code P0174 and P0171 -- Bank 1 & Bank 2 Running too Lean.
Now could this be because the Dinan Intake was removed and the Dinan Stage 2 software is still installed?
The car also has a Emissions Recall that I need to do before Smogging the car, will this solve the problem?
I bought the car on Monday. All Wednesday the SES light was gone. I was running Gas Station 76 91 octane. I filled up at Chevron late last night, but I am not sure when the SES light came on. Today it has been on all day.
How come the SES light was gone for a whole day?
Guys help me out i really need your thoughts
Terabass is offline
Old 19th April 2008, 01:01   #2
Terabass
Terabass's Avatar
Garage: M5 Black
Any ideas?
Terabass is offline
Old 20th April 2008, 02:34   #3
Terabass
Terabass's Avatar
Garage: M5 Black
The SES dissappeared again, quick to smog shop before shows up again.
Terabass is offline
Old 20th April 2008, 05:33   #4
ard
ard's Avatar
Return the car to your buddy the dealer!
Have him smog it, THEN buy it.
I am not sure what the dina software (if it really is still installed) will do without the CAI.
ard is offline
Old 25th April 2008, 01:04   #5
Terabass
Terabass's Avatar
Garage: M5 Black
Ergh, prolly end up selling it out of state then. I still havent smogged it.
I need to get MAF's, and I haven't had the time to do so.
Not worth the problems definately.
Terabass is offline
Old 25th April 2008, 01:12   #6
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
Sales Feedback: (-1)
I know exactly what you need to do. I had a similar case.
1. Take the car to the dealer and have them do their emission upgrade. (this will clear your computer of any software upgrades you ever had.)
2. Smog the car.
3. Call Dinan and find out under the VIN what was installed on your car.
4. I would recommend purchasing the cold air because you can get the software uploaded for free.
Dinan policy states.. that if you already paid for a software once and for some reason it was removed or lost. Dinan authorized dealer can load it for free. The only thing you would have to pay for is service. Realisticly it takes 4 minutes to load the
/// 2002 Blue Water Metallic
Performance: | DINAN Strut Bar | DINAN Cold Air Intake | DINAN MAF | DINAN 3.45 Limited Slip Differential | DINAN Stage 3 Software| B&M Short Shifter | Kelleners Race Exhaust 83MM| Custom X-Pipe |
Interior/Exterior: | ACS Splitters | ACS Fog Light Inserts | ACS Diffuser | ACS Pedals | ACS Hand Brake Lever | UUC Shifter Knob RK6A-L height-Adjustable Shift Knob with Leather Covering | ACS Mid Spoiler | 6000K Xenon Headlights/Fog Lights | MKIV Nav |
Suspension/Brakes: | ACS Shock/Spring | Hamman PG3 3-Peice Front 245/30/20 Rear 285/25/20 | Wrapped with Vredestein | Brembo: Front GT Brake Kit 380x32 2-piece 8 piston - Monoblock | Brembo: Rear GT Brake Kit 345x28 2-Piece 4 Piston - Lotus| UUC Trans Mounts |
More coming soon.........
www.Need4SpeedMotors.com
rkhudave is offline
Old 25th April 2008, 02:12   #7
Terabass
Terabass's Avatar
Garage: M5 Black
I am getting the MAF's replaced. I just have not had time.
Afterwards I am smogging the car.
I went to Sterling BMW and they are Dinan approved, they did the re-call yesterday .
W/ the Re-call they put the stage-2 back Software back in.
So hopefully smog-pass is not far away.
The car has:
Dinan Clutch
Dinan Short-Shift
Dinan Stage 1/2 Software
It also supposed to have:
Dinan Front Strut Braces
Dinan CIA
But the last two have been removed before I bought the car.
I gonna re-install them later, but first I want to make sure everything else is running perfect on the car and I dont have time for it right now.
The car had enough points to get the Dinan badge.
...But not anymore w/ the
CIA. So the badge gotta go or CIA/Exaust/Strut Brace put back in.
Terabass is offline
Old 25th April 2008, 03:22   #8
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
The car has:
Dinan Clutch
Dinan Short-Shift
Dinan CIA
Good luck with it...
rkhudave is offline
Old 25th April 2008, 06:22   #9
evolved
Garage: Silver 2002 M5
Terrabase, I have a 2002 beast that went through a similar sequence as rkhudave described. Since I live in California and not Latvia, I don't know if my experience applies, but here goes (needed emissions upgrade certificate from BMW dealer for registration renewal):
Step 1: Went to BMW dealer for DME update. Made sure I got the receipt that I could mail to the Department of Motor Vehicles. This step over-wrote the Dinan software.
Step 2: Drove the car aggressively for a couple of hours, then got it smogged. It _just_ passed on the Hydrocarbon emitted reading.
Step 3: Went to Dinan and had them reflash the DME (stage 2 for me).
I have a 2002 Dinan Series 1 M5 that I bought two years ago.
I hope that helps. As I mentioned, I don't know the rules in Latvia -- if there are any!
evolved is offline
Old 25th April 2008, 08:23   #10
ard
ard's Avatar
TEra needs to update his location... clearly people need to know his state to help with issues such as state smog!
Pretty sure he is in the US, not Latvia...lemme guess... Irvine, CA?
ard is offline
Tags
dinan, emissions, maf, recall, smog
FAQ on Carbon Build-Up Issue (First Attempt) LLcoolM5 E39 M5 and E52 Z8 Discussion 928 2nd November 2009 01:09
M5 Tuning Software (DiscoveryAuto vs PowerChip)... SACM5 E39 M5 and E52 Z8 Discussion 11 22nd April 2007 18:21
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Did the BMW emissions recall software upgrade, today... em5464 E39 M5 and E52 Z8 Discussion 22 13th September 2006 17:49
Carbon Build-up Issue: SURVEY RESULTS wilsodh E39 M5 and E52 Z8 Discussion 15 16th December 2005 21:39
Page generated in 0.19186 seconds with 11 queries
