Old 17th April 2008, 12:27   #1
bwherry
bwherry's Avatar
Garage: 2001 M5, Carbon Black
Sales Feedback: (4)
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D
Hi all,
I just did an iPod integration using the Intravee II and Alpine KCA-420i and I figured I'd share the process with y'all. (my car is a 2001 w/ digital DSP, so I'll also cover the necessary A/D conversion -- not needed on cars without digital DSP) I gathered a lot of information regarding this modification from right here on m5board, but in disparate locations. I'm putting this all together in one place, so if you're planning this exact iPod integration scheme, this should be very helpful.
For those that don't know, the Intravee II is basically a box that translates Alpine's AI-Net protocol into the BMW iBus, so it opens up a lot of ICE options with Alpine stuff. One such Alpine product is the KCA-420i iPod interface. The really nice thing about this combo for iPod integration is the iPod is completely controllable from the headunit -- you can browse artists, albums, playlists, etc. Meaning you don't need to be able to physically touch the iPod, so you can leave it in the trunk, out of the way.
Cars with digital DSP need one additional component, an analog-to-digital converter to take the analog audio signal from the Intravee II outputs and convert it to a digital signal that the audio amplifier needs. How do you know if you've got digital DSP or not? Loosen the two screws on the side of your CD changer and pull it up and out, then look at the back where the connections are. All of our cars have a 3-pin iBus connection. Digital DSP cars have a coaxial digital audio output (small plug with a single wire inside, pictured here) whereas cars without digital DSP use a 6-pin connection (using the 6-pin socket that isn't connected in this picture). The installation of the necessary A/D converter for digital DSP cars takes a little more effort/time/skill to DIY. You non-digital DSP guys should thank your lucky stars because the installation for y'all is a piece of cake.
Note: my digital camera apparently s$&t the bed during the installation, so a lot of the pictures have funky lines through them. Many apologies. Hopefully the important stuff is still visible...
Parts:
  • Intravee II - I got mine from bimmernav.com
  • Alpine KCA-420i - I got mine from crutchfield.com
  • DICE A/D converter (only needed if you've got digital DSP!!) - I got mine from bavariansoundwerks.com. There are other (and cheaper) A/D conversion solutions available, but this one is nice because it includes all the necessary wiring, so it's plug-n-play. Well, solder, plug, and play, anyway.
Signal Flow:
  • Audio comes out the iPod and into the KCA-420i via the included dock cable. The KCA-420i's AI-Net output (audio and communications) is routed to the Intravee II. For non-digital DSP cars, the analog audio output from the Intravee II goes to the amp, using the 6-pin connector that used to connect to the CD changer. The 3-pin iBus connector (also used to be connected to the CD changer) plugs into the Intravee II's "Bus" port. Here's the basic layout.
  • For digital DSP cars, the audio output from the Intravee II is routed to the A/D converter, which is then routed to the amp via the coaxial connection. Here's that basic layout.
Installation:
  1. Take your CDs out of the CD changer magazine! Once the CD changer is out, you can't get the CDs out!
  2. Disconnect the negative battery cable (10mm socket). This is located in the trunk under the "trap door". You can close the little cap and rest the cable on top to make sure it stays away from that terminal.
  3. Remove the CD changer. So glad to see that thing go! There are two screws on the right side that only need to be loosened a bit (not removed) and the CD changer can be lifted up and out.
  4. Disconnect the CD changer connections. One is a 3-pin iBus connector that we all have. The other one will either be a 6-pin connector (not digital DSP) or a coaxial connector (digital DSP).
  5. (Digital DSP cars only) Move the navigation CD or DVD drive out of the way (we'll need room in that area soon). Loosen three 8mm bolts (here, here, and here) and finagle it out, and set aside.
  6. Connect everything together like this. (digital DSP like this)
  7. Y'all without digital DSP are basically done. Skip ahead to step 10. Lucky bastids.
  8. Okay digital DSP dudes, all we need to do is get power to the A/D converter. Look for a purple wire with a white stripe -- that's switched +12V power. The fat brown wire going into the amp's big multipin connector is ground (you can also get ground of the chassis, using one of the tail light screw ends, etc.). Strip some of the insulation away and solder up your A/D converter's power wires. In the case of the DICE A/D unit, the +12V has the white stripe (and a big sticker saying +12V). You can also use tap-in connectors (which the DICE A/D unit comes with) but I prefer the smoke, awkwardness, and extreme heat of soldering. Then tape 'em up with some electrical tape.
  9. (still digital DSP only) Plug in the power connector to the A/D unit and route the audio output from the Intravee II (6-pin connector) to the A/D unit's stereo RCA connectors. Then connect the coaxial cable from the A/D converter's output to the coaxial input on the amp. It should now look something like this.
  10. Route the cable to the iPod through one of the vent holes so you can connect and disconnect an iPod without having to open the little cubby door. Like this. Unless you want to leave the iPod stowed away all the time, in which case you're on your own as far as mounting it securely...
  11. Arrange the boxes such that they're secured to the car somehow (I used velcro) and such that the cubby door will still close (shouldn't be that hard -- CD changer was much bigger than these guys). My arrangement looks like this.
  12. Close it up and figure out how to mount your iPod back there... I've got a 3rd-gen iPod that came with a little protective case. I put a couple pieces of velcro on the case, which sticks to the carpet quite nicely. Plug it in and win!
  13. Reconnect the cable to the negative battery terminal.
That's it! Now fire up the car and enjoy having your entire music libaray at your fingertips!
Cheers!
Brian
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-01_components.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-02_dsp_components.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-04_cd_changer_screws.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-05_neg_batt.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-06_neg_batt_covered.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-07_cd_changer_connections.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-08_nav_bolt1.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-09_nav_bolt2.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-10_nav_bolt3.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-11_nav_resting.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-12_power_connections.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-13_power_conn_taped.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-14_all_connected.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-15_nice_n_neat.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-16_through_the_hole.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-17_buttoned_up.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-18_velcro_on_case.jpg
iPod Integration w/ Intravee II, Alpine KCA-420i, A/D-19_connected_and_stuck.jpg
bwherry is offline
The Following 27 Users Say Thank You to bwherry For This Useful Post:
///m5e39 (25th October 2008), 155plus (25th June 2008), alquazi (20th May 2008), AN89AG (4th December 2008), AUTOG4 (28th April 2008), blackandgold (14th May 2009), Busta (18th February 2009), BuzzedHornet (8th June 2008), ccm241 (18th April 2008), Dan_G (17th April 2008), devilhunter (12th June 2009), doe (27th May 2008), Envisage0 (17th April 2008), fumando (11th September 2008), Hawkwind (10th May 2008), IanS (25th April 2008), IWantMyM5 (21st April 2008), julesandtrish (19th April 2008), Kmac (20th April 2008), Laidback (25th April 2008), Mike S. (25th April 2008), NorthernM5 (19th April 2008), psiggy (27th April 2008), rassi (2nd June 2008), razahyde (8th October 2008), Remove B4 Flite (22nd June 2008), RichardP (18th April 2008)
Old 17th April 2008, 12:30   #2
Envisage0
Garage: E39 M5 Avus Blue
That's one hell of a post Brian.......
Thanks for what must have taken a lot of effort to share.
Awesome!
**** it, let's do it - Australian proverb
Envisage0 is offline
Old 17th April 2008, 15:53   #3
b757236
b757236's Avatar
Garage: 2003 BMW M5 Silver
Any pictures of the Ipod screen on the Nav unit?
Adam
2003 M5
Shark Injector (Standard Software Version)
E60 SSK
Royal Purple Syncromax Fluid
ZHP Shift Knob
ATE Super Blue Brake Fluid
Matte Blackout Grille
MyCarr LED Angel Eye upgrade
35W HID Projector Fog Lights 4500K
DDM Tuning Xenon Interior lights
2007 Mercedes GL320 CDI
Filled up with Pure Dinosaur Diesel
b757236 is offline
Old 17th April 2008, 18:48   #4
bwherry
bwherry's Avatar
Sales Feedback: (4)
I didn't take any 'cause they'd have those purple lines through 'em. But check out this video to see the Intravee in action.
Oh, and I found an installation video (no DSP A/D, though) here.
Brian
bwherry is offline
The Following User Says Thank You to bwherry For This Useful Post:
b757236 (17th April 2008)
Old 18th April 2008, 01:37   #5
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
Great write up. One helluva product the IV. Lovin' mine.
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline
Old 18th April 2008, 01:44   #6
ccm241
ccm241's Avatar
Garage: Sold my baby!
Incredible write up! Thanks!
2002 Carbon Black/ Caramel lightly modded - SOLD to board member
Biding my time...
ccm241 is offline
Old 18th April 2008, 06:53   #7
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
I'm confused at the need for the Alpine KCA-420i in combination with the Intravee. Are you intending to add more components (like an Alpine CD Changer, DVD, etc)? Otherwise, isn't it a redundant component?
As an alternative installation method, you could choose not to use an A->D converter and instead buy the 6 pin harness which plugs into your radio unit.
Doug
DouglasABaker is offline
Old 18th April 2008, 07:04   #8
LFC09
LFC09's Avatar
Doug
the kca 420i is the necessary interface between the ipod and the intravee.
Black/Grey leather
AiB 3.0 angel eyes
BMW 545 shifter
Dinan rear sway bar
LFC09 is offline
Old 18th April 2008, 07:49   #9
BuzzedHornet
BuzzedHornet's Avatar
Garage: '02 M5
Sales Feedback: (4)
Doug,
The intravee speaks "AI NET" by alpine, you need the 420i to convert the BMW ibus language to ai net.
Rob
BuzzedHornet is offline
Old 18th April 2008, 20:15   #10
DouglasABaker
Originally Posted by LFC09 View Post
Doug
Thanks Scott - that makes more sense. I didn't realize the Intravee didn't have native support for an Ipod...
Doug
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav E39 M5 and E52 Z8 Discussion 115 23rd August 2009 19:55
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav ALPINABoard.com | BMW Alpina Discussion 27 18th April 2008 06:58
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 74 16th April 2008 00:04
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 12 20th September 2007 20:14
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
Page generated in 0.27046 seconds with 12 queries
