Old 16th April 2008, 20:17   #1
twhitestone
Garage: 2001 E39-S62 M5 (jet black), 2008 E92-N54 335xi (black sapphire)
Send a message via AIM to twhitestone
Rear camber looks off... or is it supposed to be?
When I squat down behind my M5 and look at the rear wheel as compared to the front (on either driver or passenger side of the vehicle) the bottom of the rear wheels seem to not be parallel to the front wheels. The bottom of the tire seems to be further out from the vehicle than the top, maybe by an inch or more as compared to the front wheels. Is this normal? I was considering getting an alignment to have this checked out, but wanted to see if this was typical of M5s. Thanks!
Tom
twhitestone is offline
Old 16th April 2008, 20:33   #2
Ben Carufel
Ben Carufel's Avatar
Garage: 2000 Estoril Blue M Coupe
Send a message via AIM to Ben Carufel
That is completely normal for E39 BMWs.
BMW builds most of their cars with a high level of negative camber (that is, when the bottom of the wheel is sticking out farther than the top). It improves handling at the expense of tire wear.
http://en.wikipedia.org/wiki/Camber_angle
Ben
2000 Estoril Blue M Coupe [Garage Queen]
2000 Biarritz Blue 528i Touring [Hauler]
1991 Alpine White 318i Sedan [Daily Driver]
1989 Alpine White S50 325i [Fun Machine]
2002 Chevrolet Silverado 1500HD [Tow Vehicle]
Ben Carufel is offline
Old 16th April 2008, 21:08   #3
twhitestone
Thank you! Glad to know it's normal. Just saved 3 hours of time + $129.95!
Old 16th April 2008, 21:30   #4
beast27
beast27's Avatar
Garage: M5 Lemans Blue
Obviously be careful with rear tire wear, i just checked my rear tires and noticed a couple of spots wearing through the rubber. Tires are on the way...
beast27 is offline
Old 16th April 2008, 23:04   #5
Ben Carufel
As the gentleman above you said, the rear tires tend to wear rather quickly on their inner edges due to the extreme negative camber. What you saved on an alignment will be spent on new tires in no time at all .
The one thing you can do to prolong the life of the tires (other than adjusting the rear camber to a less negative position, which will influence handling) is to have the two rear tires swapped every few thousand miles. This doesn't involve just putting the left wheel on the right side and vice versa, but rather having each rear tire removed from it's rim and then moved to the other side of the car, maintaining the directional rotation of the tire.
That will even out the wear somewhat by way of making what was the inside edge of the tire the outside edge, etc. If you do this every 5,000 miles or so you should maximize tire life.
Ben
Old 22nd April 2008, 00:39   #6
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
also check the toe setting on the tires. A combination of negative camber with lots of toe will chew up tires quickly.
verhagke is offline
Old 17th June 2008, 19:29   #7
gt40mki
Garage: 2001 Jet Black M5
my driver side is wearing quicker than the passenger side...thoughts?
gt40mki is offline
Old 17th June 2008, 21:49   #8
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
it shouldn't be that much, get the allignment
MarkQC is offline
Need help w/3 things. Rear Seal, Clutch, Building a case. g9s8r E39 M5 and E52 Z8 Discussion 2 16th February 2008 20:44
BMWNA pressrelease on 6-speed manual M5 kees E60 M5 and E61 M5 Touring Discussion 10 9th February 2008 07:50
Big brake kit options for front and rear? jester5675 E39 M5 and E52 Z8 Discussion 11 10th October 2006 17:35
Is The Castor and Camber Adjustable Front And Rear On The M5? If So..... Anita E39 M5 and E52 Z8 Discussion 4 14th April 2004 03:21
Camber Plates or Rear Sway Bar? V-10 4 Me E39 M5 and E52 Z8 Discussion 37 26th September 2003 04:18
Page generated in 0.12195 seconds with 11 queries
