Old 16th April 2008, 20:17   #1
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
Sales Feedback: (-1)
Light Bulbs
Does anyone know if the E60 ds2 xenon bulb will fit on the E39 (M5) .
/// 2002 Blue Water Metallic
Performance: | DINAN Strut Bar | DINAN Cold Air Intake | DINAN MAF | DINAN 3.45 Limited Slip Differential | DINAN Stage 3 Software| B&M Short Shifter | Kelleners Race Exhaust 83MM| Custom X-Pipe |
Interior/Exterior: | ACS Splitters | ACS Fog Light Inserts | ACS Diffuser | ACS Pedals | ACS Hand Brake Lever | UUC Shifter Knob RK6A-L height-Adjustable Shift Knob with Leather Covering | ACS Mid Spoiler | 6000K Xenon Headlights/Fog Lights | MKIV Nav |
Suspension/Brakes: | ACS Shock/Spring | Hamman PG3 3-Peice Front 245/30/20 Rear 285/25/20 | Wrapped with Vredestein | Brembo: Front GT Brake Kit 380x32 2-piece 8 piston - Monoblock | Brembo: Rear GT Brake Kit 345x28 2-Piece 4 Piston - Lotus| UUC Trans Mounts |
More coming soon.........
www.Need4SpeedMotors.com
rkhudave is offline
Old 17th April 2008, 20:38   #2
Gamite
Gamite's Avatar
Garage: Alpine White E39 M5 & Calypso Red E34 535
D2S is the bulb type, it shouldn't be different.
www.gamite.net
PSS9 | BBS LM | EISENMANN SPORT | SUPERSPRINT X-PIPE | ZHP SHIFT KNOB | MKIV NAVI | INTRAVEE II | VORSTEINER DIFFUSER | 6000K HID | EUROPEAN HELLA HEADLIGHTS
Gamite is offline
Old 18th April 2008, 01:00   #3
lsuslu
lsuslu's Avatar
Garage: 01 Imola Red M5
just make sure the e60 bulb is not bixenon
2001 Imola Red M5 on black
6000k HID fogs
6000k Headlights
HD DIY Sink drain CAI
Gloss Black Kidneys and Sink Drains
Thermal Wrap Intake (105*F outside as of 7/16//08)
x-pipe and magnaflow 14816
Who Dat!!
lsuslu is offline
Old 18th April 2008, 01:49   #4
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
what do you mean? Isnt e39 bulb a bixenon d2s
rkhudave is offline
Old 18th April 2008, 08:40   #5
Gamite
Gamite's Avatar
as far as I was concerned, Bi Xenon doesn't have anything to do with the bulb. It's the cut off piece in the actual headlight assembly that does the work. It moves away when you turn your high beams on.
www.gamite.net
Gamite is offline
M6 (e64) LED Tail Light DO-IT-YOURSELF installed FINALLY DoctaM3 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 1st June 2008 06:21
Another SES light question... E39 MFIVE E39 M5 and E52 Z8 Discussion 6 6th July 2006 06:07
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
Bright Lights. Advice on non-HID bulbs. IvanDias E34 M5 Discussion 2 25th January 2002 04:16
Page generated in 0.09705 seconds with 11 queries
