Beast reached 100K miles, still feels powerful, what do I need to be concerned with? - BMW M5 Forum and M6 Forums
Old 16th April 2008, 01:01   #1
CWY_M5
CWY_M5's Avatar
Garage: '00 M5 Silver; '91 M5 white; '01 525iT white; '94 525ia Black
First of all, I have put 36k miles in the last 2-1/2 years, and this is NOT my daily driver.
Needless to say, I love driving it anytime I can.
This past weekend, it reached 100,000 miles, and while it still feels great, I need to start worrying about issues that can get me stranded.
10k ago, I already got stranded from a failed fuel pump
I just got brand new suspension components and struts last summer
Clutch is also brand new
I will be getting new fluids (brake, diff, purple royal transmission).
I'm thinking about getting water pump and thermostat since my car runs cool - so I'll get coolant done then.
Anything else I need to worry that has happened to you?
CWY_M5
E39 M5
'00 Titan Silver
112k miles (since 64k)
Koni FSD with Stock Springs and Vines arms
Intravee iPOD adapter
Clear Headlight w/ angel eye (CCFL)
Rear CELIS LED lights
BlueTooth Retrofit (LOVE THIS)
V1 direct wire w/ Blinder Extreme M20
MK-IV DVD Nav upgrade w/ 16x9 wide screen monitor
M-Sports Steering Wheel upgrade
E34 M5 '91 White
115k miles (since 110k)
Bone Stock - make your suggestions!!!
Dinan stage 1 suspension with rear SLS delete
Other BMWs:
E34 525ia '94 Black (227k mi since 83k)
- Power chipped
- Bluetooth (Motorola)
- V1 direct wiring
- HID projector headlight
- Updated suspension (DIY)
E39 540iTa '00 White (74k mi)
- V1 direct wiring
E39 525iTa '01 White Sold...
CWY_M5 is offline   Reply With Quote
Old 16th April 2008, 02:26   #2
Chuckc
Garage: 2001 Dinan 740i
I would replace all coolant hoses in the front and rear of the motor while you are doing the water pump, coolant chg etc.
"The richest people in the world build networks. Everyone else is trained to look for work" - Robert Kiyosaki, Rich Dad Poor Dad
Chuckc is offline   Reply With Quote
The Following User Says Thank You to Chuckc For This Useful Post:
CWY_M5 (16th April 2008)
Old 16th April 2008, 11:31   #3
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Its difficult to say for sure you will have to wait and see, I know thats not much help but to give you an example, BMW changed the belts and a day later my air con compressor packed in.
andy777 is offline   Reply With Quote
Old 16th April 2008, 14:27   #4
intrepid one
intrepid one's Avatar
Garage: '01 M5 Carbon Black
If you have done all the routine stuff, and it sounds as if you have, you may look at brakes, etc..I've just past 100K, and had to do a wheel brg, MAFS, plugs and a CPS in the last 3 months..The car runs top notch..best wishes with it
intrepid one is online now   Reply With Quote
Old 16th April 2008, 15:27   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
At 100k, I would change out the radiator. 90k seems to be average useful life. YMMV.
gsfent is online now   Reply With Quote
Old 16th April 2008, 16:03   #6
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
cooling system overhaul is a good idea. (hoses, water pump, thermostat, radiator/expansion tank)
You may also want to take a close look at the suspension bushings and ball joints.
there are also those who would say to change out the crankshaft to rod bearings, but that requires a significant amount of effort.
verhagke is offline   Reply With Quote
Old 16th April 2008, 17:09   #7
rassi
rassi's Avatar
Garage: '11 Mercedes C300 CDI 4Matic
MAFs, depending on what kind of reading you get in Test 6 on the OBD. CPS might be something to look out for too.
Anders
'11 Mercedes C300 CDI 4Matic Avantgarde (black / beige leather)
ex '08 BMW M5 (Silverstone II / Black merino leather)
ex '08 BMW X3 xDrive 35d (Titan silver / Nevada beige leather)
ex '09 Mercedes C220T CDI Avantgarde (black / black leather)
ex '02 BMW M5 (Carbon black / black leather)
ex '95 BMW 320i Touring (black / black cloth)
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline   Reply With Quote
Old 17th April 2008, 01:25   #8
tranck
tranck's Avatar
Garage: 2000 M5 - Silverstone Metallic
I've replaced every nut and bolt on my car EXCEPT the radiator- car has 161,000 miles - Imho, just change the coolant and hoses.
tranck is offline   Reply With Quote
Old 17th April 2008, 01:42   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
has anyone actually seen an e39 m5 rad failure like we'd see all over the boards with 540's? I can't remember reading about one. I put a thermostat and water pump in at 75k prophylactically when my car was at the dealer a couple years ago to fix an oil leak, figured they were in there, would pay for the part. Of course the tech didn't want to do the job correctly and replace the seal in the thermostat housing, which failed this last summer, causing cool running conditions so that was revisited. I think hoses on a modern car are ok for 150k, i replaced all of the hoses on my e34, which has about 148k on it now, the cooling hoses were actually still in quite good condition, the vacuum hoses were trashed, they, and the crankcase vent hoses crumbled in my hands.
The big debate at 100k is do we replace the rod bearings, like the e34 3.8L guys do. If i had a local shop that i trusted who would do this job reasonably, i would do it, but have yet to find a shop, other than dinan, to tackle something like this.
mottati is offline   Reply With Quote
Old 17th April 2008, 02:18   #10
wentouch
Garage: 03 E39 M5 JB/B/Al
alternator, starter, battery & respective terminals.
wentouch is offline   Reply With Quote
MMMach5 is complete. The beast is here. MMMach5 E60 M5 and E61 M5 Touring Discussion 35 6th May 2006 21:50
Approaching 100k miles, what should I consider servicing??? lemansmiami E39 M5 and E52 Z8 Discussion 7 29th March 2006 04:49
my new interlagos blue beast wants an oil change at 450 miles Scott Z E60 M5 and E61 M5 Touring Discussion 3 20th February 2006 16:23
How many miles on your beast? BD 997 E60 M5 and E61 M5 Touring Discussion 34 17th December 2005 00:41
Should I be concerned with purchasing a higher mileage 01? HDClown E39 M5 and E52 Z8 Discussion 3 26th June 2004 11:37
