Clutch break in - Miles or shifts? - BMW M5 Forum and M6 Forums
Old 11th April 2008, 05:09   #1
Qship5
Qship5's Avatar
Garage: 2003 M5 Carbon Black, 2009 C63 AMG Black
Sales Feedback: (3)
I just had my new clutch installed and based on the posts I've read some people say to shift easy for the first 500 - 1000 miles and some say 500 - 1000 shifts. Which is my best bet? After the first 500 - 1000 miles or shifts can I just go straight from easy shifts to full on aggressive shifts? I have a local chapter DE/Club Race event in two weeks and am wondering if it is too soon after the new clutch to participate. Any thoughts? At the price of our clutch installs I don't want to shorten the clutch life unecessarily.
Thanks,
Qship5 is offline   Reply With Quote
Old 11th April 2008, 05:15   #2
jetblack01m5
jetblack01m5's Avatar
Garage: '84 911, '06 Cayenne TT
I've been told 500 miles or so of normal around the town driving before beginning to get aggressive with the shifting.
Current: 2006 Porsche Cayenne TT, 1984 Porsche 911 Carrera
Sold: 2001 BMW M5, 2007 Mazda Miata, 2004 Subaru Impreza WRX
jetblack01m5 is offline   Reply With Quote
Old 11th April 2008, 05:22   #3
badboypolar
Garage: 59 Austin Healey Bugeye Sprite
Sales Feedback: (3)
The point of "breaking in" a clutch is to get heat into the organic compounds and the bonding agents to "solidify" the mix. While I don't suggest using the break pads break in routine, you can break in a clutch without babying it around for 500 miles. If you can get some good heat into the clutch without being aggresive then it would be sufficent enough for your track day.
If nothing else, use the 500 miles rule of 70% city, 30% highway as best you can.
badboypolar is offline   Reply With Quote
Old 11th April 2008, 06:02   #4
Need4Spd
Need4Spd's Avatar
Shifts. Think about it. Yes, there is the heating issue, but if you get on the freeway and into 5th or 6th gear and drive 1000 miles w/o shifting there will be next to zero wear on the clutch. Drive 100 miles in a city with stop signs at every other corner and you will have lots of wear. In any event, I would not rip into the clutch even when fully broken-in, as it is a known weak point (uses same transmission/clutch as M3 6 cyl., which has far less torque).
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
Old 11th April 2008, 13:45   #5
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
First posted by XrayMD, per BMW it takes 800-1000 shifts as seen below. Note the info below also includes a process for the tech to take for M5/Z8 cars to help initial break-in prior to giving the car to the customer (which I'm essentially sure almost none of them follow).
Shoot for ~1000 shifts at moderate rev differentials, no high rpm upshifts, no hard starts, etc., would be my advice.
Chuck
BMW AG - TIS
RA: Breaking in SAC clutch
Issue status (03/2002)
Break in the friction linings of the clutch by applying light to medium loads, in the same way as for brake linings. This preconditioning creates a carbon layer between lining and metal friction surface which in the end generates the necessary coefficient of friction. Breaking in can take the form of either normal driving with many gearshifts or a specific breaking-in program on gentle gradients.
"Normal" driving will not damage the clutch. "Normal" driving conditions involve drive-off speeds of up to approx. 2500 rpm on a medium gradient, e.g. when driving onto a transporter. Normal driving off on a level surface at speeds up to approx. 2000 rpm are likewise sufficient.
Sporting driving maneuvers will destroy a new clutch! These include driving maneuvers at high differential speeds, overlaps or very high drive-off speeds, e.g. when driving onto a transporter.
When a vehicle is moved "normally", an empirically established figure of approx. 800-1000 gearshifts is applicable to an optimally broken-in lining.
Please conduct the following breaking-in program in order to avoid later customer complaints:
* specifically for M5 and Z8 vehicles
Breaking-in program for approx. 30 km on road
Vehicle subject to "moderate" shifting processes
Drive off at max. 2000 rpm; upshift 1->2, 2->3, 3->4; upshift at 3500-4000 rpm, downshift 4->3, 3->2, 2->1, downshift at 2000 rpm
Drive off 3 to 5 times on a gentle gradient up to approx. 12%, drive-off speed max. 2000 rpm
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
1996 Volvo 850R wagon
herd has been thinned, looking for some new acquisitions...non-sunroof E90 M3 = found
CSBM5 is offline   Reply With Quote
The Following User Says Thank You to CSBM5 For This Useful Post:
jclyman (11th April 2008)
Old 11th April 2008, 14:41   #6
ecalcagnino
ecalcagnino's Avatar
Garage: SOLD: '03 M5 Jet Black
Thanks for the official post CSBM5. Lots of up/downshifts at moderate revs (2k-4K) for 500-600 miles of mixed driving is what I was told by BMW.
By the way, isn't that new clutch smell scary and god-awful? Man...
Eric
SOLD: 2003 E39 M5 Jet Black / Black
ecalcagnino is offline   Reply With Quote
Old 11th April 2008, 16:13   #7
jetblack01m5
Just like breaking in the brake pads... yum yum chemical BBQ smell.
Old 11th April 2008, 16:36   #8
Need4Spd
Need4Spd's Avatar
If you think that's bad, you should try the Centric Posi-Quiet brake pads. Yow what a smell! But it goes away after bedding-in and a few hundred miles, and the pads are super. As I recall, my Tubi exhausts smelled pretty bad on break-in, too.
Old 11th April 2008, 18:30   #9
ecalcagnino
Glad to see that I am not the only one. My garage smells like a meth lab when I get home.
Old 11th April 2008, 19:11   #10
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Uh, how do you know what a meth lab smells like?
The Following User Says Thank You to gsfent For This Useful Post:
Replacing the E39 M5 Clutch and Flywheel with Original Equipment OldRanger M5 E39 and E60 tips & tricks 20 30th November 2012 05:04
just had clutch replaced and... m5jmh E39 M5 and E52 Z8 Discussion 30 21st October 2008 23:55
F/S: 2003 Dinan S2 pkg. 19,100 miles, Sterling Grey howler Cars For Sale or Wanted 6 19th April 2007 21:36
Clutch Failure 150 miles after service! gunslinger E39 M5 and E52 Z8 Discussion 11 20th November 2004 20:37
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 21:00
