• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 7th April 2008, 21:34   #1 (permalink)
          Emmasis
          Emmasis's Avatar
          Outside temp gauge reads -40 f
          I live in Arizona so I know that it is obviously screwed up.
          Any ideas how to fix?
          Thanks all!
          Originally Posted by BmwNut
          Drag racing a BMW is like taking a prostitute fishing; sure it is fun but that isnt what you got her for.
          Emmasis is offline
          Old 7th April 2008, 21:50   #2 (permalink)
          azaytsev
          azaytsev's Avatar
          Check the outside temperature sensor
          ___________________
          BMW CCA MEMBER#409490
          Previous BMWs
          1997 528i
          1990 535i
          1977 320i
          azaytsev is offline
          Old 7th April 2008, 21:57   #3 (permalink)
          E55AMG2
          E55AMG2's Avatar
          sounds like the sensor is broken or has come unplugged.
          E55AMG2 is offline
          Old 7th April 2008, 23:05   #4 (permalink)
          Emmasis
          Emmasis's Avatar
          Where is it located?
          Emmasis is offline
          Old 7th April 2008, 23:09   #5 (permalink)
          gsfent
          gsfent's Avatar
          I think lower right hand corner tucked under the front bumper/lip. A spin to realoem.com might prove helpful.
          Dinan Stage3 suspension and CAI, SS jet coated headers, Evosport UD pulley kit, IATS, PC Gold 93, open brake ducts, Hamann front splitters, TEC cupholder, Euro tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, 2.65 diff w/40% lockup/2x dynamic, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit
          gsfent is offline
          The Following User Says Thank You to gsfent For This Useful Post:
          Emmasis (7th April 2008)
          Old 7th April 2008, 23:10   #6 (permalink)
          Diny
          Diny's Avatar
          On the front, passenger side. Look under the car in front of the wheel. The plastic cover has setup where the sensor is. It would be best to jack the car so that you can work on it a bit better and actually see what you're touching.
          /// 00 Anthracite/Black
          "Weeeeeeeeeeeeee!!!!!" - M5 Passenger
          Diny is online now
          The Following User Says Thank You to Diny For This Useful Post:
          Old 8th April 2008, 05:32   #7 (permalink)
          BMW x 2
          sensor reads -40 when it is "open". You can actually see it and get to it laying on your back just toward the engine from the pass. front tire. Can't miss it. Only sensor visible from under car w/o removing anything.
          /// 2000 M5 black on black (sold)
          /// 2002 540i Sport Topaz blue
          2000 540i Sport Orient blue
          BMW x 2 is offline
          Old 8th April 2008, 05:36   #8 (permalink)
          Diny
          Diny's Avatar
          So how do you "close" it?
          I've had mine like that since I bought the car and was never able to fix it. When that area gets wet, it shows all kinds of numbers but then it goes back to -40 when it's dry. I tried shorting the wires and doing some dinan magic (their suggested procedure for resetting it) but then instead of -40, it shows +122. Then when it gets wet, it shows weird numbers and then back to -40 it is.
          Diny is online now
          Old 8th April 2008, 05:49   #9 (permalink)
          iconoclast
          2nd.
          iconoclast is offline
          Old 8th April 2008, 10:09   #10 (permalink)
          Haha Bye
          Banned
          Haha Bye's Avatar
          I forgot which part this ismon realoem but it sounds pike the sensor is bad all together. I had the same prob on my c32 Benz
          Haha Bye is offline
          Old 8th April 2008, 16:08   #11 (permalink)
          BMW x 2
          An "open" wire will read -40. A shorted wire will read +122. It sounds to me like your connection right at the sensor is corroded. When it gets wet, it starts to conduct partially and the reading would go up and down...eventually, settling back to -40 again when it dries out. I doubt a new sensor is your issue, but they are cheap. I would clean the hell out if the connector first-both ends should be shiny clean. Harder with the female plug. Try WD40 and a tooth pick with sand paper on it. Or, get a new plug and sensor. Lightly coat the connection with dielectric grease seal it up. If it reads correctly, use a little heavy grease around the outside to keep water out.
          Bill
          BMW x 2 is offline
          Old 8th April 2008, 16:32   #12 (permalink)
          Diny
