Suggestion......
Originally Posted by jrhaile
The money I would get for selling my beast which has 117k is just not worth it. Seeing the market almost hitting the teens just reassures me it's not worth selling. So, with 117k on the clock and being that I DD my car during the nice months, how worried should I be about a rebuild? Let me state that I will NOT give my money to the Stealer. $20k for a rebuild is redicalous. I'm more then capable of pulling the engine and getting it to a shop for a rebuild. But my question is, does it take a "special" engine builder to rebuild the whiney S62? Does anyone have any experience in this matter and know off hand how much parts will roughly run?
1) You will probably get at least 150k from your motor; assuming good maintenance has been practiced since new. If you proactively replace rod bearings ( only known common weakness in S62), you'll most likely get ~200k before rebuild is necessary.
2) Another thought is to buy a complete motor out of a wrecked M5 with a lot lower miles (Tranny, too). You'd have to "hunt" a little, but they're around. Have it tested on an engine dyno to verify it's condition. 'Think this would be less $$$ than a rebuild; and certainly less time.
3) If you decide on a rebuild, pick your indy shop wisely. S62's are NOT the same as most engines. For starters, they're all aluminum. A much different experience and skill level is required.
Dan
______________________________________________
Daily Driver
'02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
The "Predator"
'02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
EVOMS Stage 4 (640hp/615tq)
PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
Sachs clutch and Porsche SSK
Mich PSC's 235/18 fronts; 295/18 rears
