• Latest threads
    • Custom feed
      • Updates
        Old 7th April 2008, 03:00   #1 (permalink)
        M5KIKO
        M5KIKO's Avatar
        Californa Smog Issues
        Looking for assistance, recently gave my son my 93 325i. In prep for the CA smog, I changed the plugs, oil, filters, cleaned mafs, ran a tank of additive that ensures you will pass, then filled up with 91 oct and ran it hot prior to having it smogged. It failed the 2nd part of test @ 25 mph, below are the results;
        Test M1: 15 MPH Results = Passed
        rpm %co2 %02 hc(ppm) co(%) no(ppm)
        meas meas meas max ave meas max ave meas max ave meas
        1842 14.6 0.2 86 21 51 0.50 0.06 0.18 697 150 263
        Test M2: 25 MPH Results = Failed
        1813 14.0 0.6 51 13 183 0.48 0.05 0.59 724 136 1050
        No mod's done to exhaust system, didn't know if I should chng out the 02 sensors. Appoligize in advance for posting it here, but it's where I trust the information received. Fyi my 00 M5 passed with flying colors. Any assistance would be much appreciated. Located in the east bay of the sf bay area.......thnx Kiko
        M5KIKO is offline
        Old 7th April 2008, 03:27   #2 (permalink)
        Need4Spd
        Need4Spd's Avatar
        Either tired cats or marginal or failed O2 sensors, I would guess. Changing out O2 sensors is cheaper and what I would try first. If they've never been done, that's most likely the cause, though I thought bad O2 sensors would throw a code. '93 and you didn't say how many miles but that's what, 15 years, so we can't expect O2 sensors to last quite that long (of course if they were replaced in the last few years, that's a different story). Hope it's not the cats.
        Need4Spd
        Need4Spd is offline
        Old 7th April 2008, 06:18   #3 (permalink)
        El Diablo
        El Diablo's Avatar
        Send a message via Yahoo to El Diablo
        +1 Bad O2 sensors will make you run lean or rich and will cause high CO or high NOx. But since you failed in both, I will guess that your cats will most likely need to be replaced IMHO. Let us know what it was. I'm also due for a smog test in June . Good luck!
        -Roberto
        '02 Dinan S2 M5 - Carbon Black/Black Nappa Leather/Sport Trim/M Audio/Rear Shades/PDC/Split Rear Seats. Performance mods include Stage 3 Dinan/JRZ suspension, Dinan SSK, Dinan Front Strut Bar, SS X-Pipe and Evosport UDD Power Pullies. Aesthetic but functional upgrades include ZHP Gearshift knob, AA Lower Grille w/Brake Cooling Ducts, Progressive Window Tint, AC Schnitzer Pedals, Chromed OEM Rear Wheels with PS2's all around, Predator Ice, HID Fog Lights, TEC Cup Holder, Hardwired V1 Detector, Gen13 Bluetooth Module, MkIV Nav.
        El Diablo is offline
        Old 7th April 2008, 06:30   #4 (permalink)
        M5KIKO
        M5KIKO's Avatar
        The 02's and the cats are both orginal equipment, the car just turned over 200,000 miles, thinking I may have gotten my money out of them. I'll give the 02's a shot first, then the cat's if it still fails. Thanks for the feed back Need4Speed & El Diablo, I do appreciate it. Anyone know where the best deals are for both the O2 sensors and the Cat's?
        M5KIKO is offline
        Old 7th April 2008, 07:09   #5 (permalink)
        tstaples
        tstaples's Avatar
        As a fuel systems and engine calibration engineer, with quite a bit of experience, including the BMW M50 engine in your 325i, I can assure you the original O2 sensors stopped functioning long ago, and your car has been running a little rich for a while (i.e. the calibration goes to something safe, but not optimal.) Running rich will slowly degrade your cats. You almost assuredly need to replace both.
        I would never run O2 sensors longer than 70-80k miles. They are consumables, like spark plugs. They slowly degrade with use. Once they stop functioning, the ECU will still run the motor, but with slightly rich settings to ensure you don't burn up valves. On OBD or OBDII equipped vehicles, it will set the SES light once that happens. Since yours is pre-95, hence pre-OBD, you get to drive in total oblivion to the problem, and unless you are very sensitive to how your car runs, you most likely won't notice the slight degradation in performance.
        FWIW, it's a 50-50 chance that your car has fuel injectors in it that I had a hand in designing and manufacturing. I previously worked for an OEM supplier, one of two injector suppliers for the M50 engines back in the early-late 90's. Good luck!
        -Tony Staples
        '02 M5 - Sterling Gray/Black
        '04 X5 4.4i Sport - Commuter Pod
        '02 530i Manual Sport - Better Half's
        '88 911 Carrera Cab - Indischrot/Camel
        "There is a fine line between a hobby, and a mental disorder." - Dave Barry
        tstaples is offline
        The Following 5 Users Say Thank You to tstaples For This Useful Post:
        ard (7th April 2008), DRM (7th April 2008), El Diablo (7th April 2008), Laidback (7th April 2008), Need4Spd (7th April 2008)
        Old 7th April 2008, 07:45   #6 (permalink)
        alijonny
        alijonny's Avatar
        "Since yours is pre-95, hence pre-OBD"
        pre 95 OBDI, 96+ OBDII
        i've got nothing better to do.
        alijonny is offline
        The Following User Says Thank You to alijonny For This Useful Post:
        Old 7th April 2008, 08:18   #7 (permalink)
        tstaples
        tstaples's Avatar
        alijonny,
        You are technically correct. However, most people who work in the industry refer to OBD-II as just OBD. Sorry for the confusion. Prior to the OBD standard, which came to be know as OBD-II, there were multiple schemes used by various ECU's or OEM's as On Board Diagnostics. The OBD-II standard became mandatory in the US starting with the '96 model year, in the 1995 calendar year. The earlier systems have become known as OBD-I or OBD 1.5, but technically, there was no overall standard, as these various schemes are proprietary. They have one thing in common, they generally won't set the Check Engine, or SES, light for much of anything short of a major problem.
        -Tony Staples
        tstaples is offline
        Old 7th April 2008, 10:27   #8 (permalink)
        M5KIKO
        M5KIKO's Avatar
        Tstaples & alijonny thank you both for the information you've shared. True, I didn't know the O2 sensors were alike the plug's in that they do ware and now I understand the impact that they have on the cats. I did notice the reduction in performance, but I assumed it was do to the age and the mileage of the car. Also since my normal tune ups provided me only a slight improvement in mile per gallon verses overall performance. I've never had a check engine light come on, execpt in the early days. Again thanks! I'll begin my seach for O2s and cats.
        M5KIKO is offline
        Old 7th April 2008, 11:38   #9 (permalink)
        paypalbid
        paypalbid's Avatar
        do you need to go to smog only place ? if not you should approach the local racers and see where they get their cars smogged and slip the cash and get your car passed.
        paypalbid is offline
        Forum Jump
