• Latest threads
    • Custom feed
      • Updates
        Old 7th April 2008, 02:56   #1 (permalink)
        Michael William
        Any interest in a tech writeup covering water pump replacement?
        I could not find any tech procedure for the water pump replacement in this forum. I just finished and could write if anyone is interested...
        Also went through the secondary air system while I was in there, but there is coverage of this issue...
        Cheers;
        Michael William is offline
        Old 7th April 2008, 03:23   #2 (permalink)
        Need4Spd
        Need4Spd's Avatar
        Up to you whether you think it's worth the write up. I'm sure it will be appreciated but probably <10% of the board would actually do the job themselves. I'm more curious about what you found/did looking at the secondary air passages.
        Need4Spd
        Need4Spd is offline
        Old 7th April 2008, 04:03   #3 (permalink)
        Michael William
        Secondary air system findings/action
        History: I have never had codes related to the secondary air system. Car is a 2000 with roughly 80K miles, moderate oil use (1 liter per 2000 miles), I do a lot of backroad driving in New Hampshire, car is never driven in winter - sits in garage for 5 to 6 months per year.
        I removed the airtube to find hard carbon deposits on the drivers side of the tube. Deposits roughly represent 50% cross section blockage. Passenger side was black but much less blockage (about one third of the driver side blockage). The valve was black with carbon, but no appreciable buildup. I have attached pictures of the air ports to both heads. I also added a picture of the driver side head air port post cleaning (using a dremmel cone shaped wire bit and a round file - sorry about the quality of this picture).
        I replaced the airtube and the valve just for grins. I was able to get the original tube clean by directing the stream of my parts cleaner (kerosene) into the tube with the valve port blocked. I let it run for nearly 12 hours, clean as new...
        Cheers;
        any-interest-tech-writeup-covering-water-pump-replacement-clean-driver-side-air-port.jpg   any-interest-tech-writeup-covering-water-pump-replacement-driver-side-air-port.jpg   any-interest-tech-writeup-covering-water-pump-replacement-pass-side-air-port.jpg   any-interest-tech-writeup-covering-water-pump-replacement-dremmel.jpg
        The Following User Says Thank You to Michael William For This Useful Post:
        Need4Spd (7th April 2008)
        Old 7th April 2008, 05:57   #4 (permalink)
        KevinM
        KevinM's Avatar
        While I agree that only a small minority of the board would ever do the job themselves (myself included in the majority who would likely not), if you are willing to do the write-up, please do! Even those of us who won't do it ourselves may learn from the information and at the very least these type of threads give those of us without much car engineering knowledge some advantage when we seek help at the dealer (or indy).
        Kevin
        2007 M Coupe, Silver/Black
        KevinM is offline
        Old 7th April 2008, 08:41   #5 (permalink)
        ard
        ard's Avatar
        If you do a write up- on either- PM me and I can link oit in the FAQ sticky.
        Always appreciated!
        A
        ard is offline
        Old 7th July 2008, 01:12   #6 (permalink)
        mr_bock
        mr_bock's Avatar
        Please do the write up!!!! I am in the midst of the disassembly and am stuck... the bolt behind the crank dampener. Any pix and step by step proceedure.
        PM me if you have some tips, etc...
        Thanks!!!!!
        2002 Sterling Gray, Black and Aluminum interior
        UUC Short Shifter & DSSR
        UUC Clutch Stop
        UUC Transmission Supports
        UUC UltraSmooth CeraMetallic Clutch/LWF
        Active Autowerks Cold Ram Air Intake - Modified
        Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
        Alpine amp for JL Audio Sub Woofers
        UFMotorsport S62 Intake Air Temp Sensor Relocation
        Dinan Stage II Suspension
        Dinan 3.45 Rear Diff. Gear Set
        Dual JL Audio 10" Sub Woofers
        K40/Laser Defuserplus, hidden install
        K-Mac Adjustable Caster/Camber Plates
        Kelleners Aluminum Sport Pedals & Foot Rest
        MB Quart speaker replacement
        NAV MKIV DVD
        StopTech SS Brakelines
        Axxis Ultimate Brake Pads
        EvoSport Performance Underdrive Pulley Set
        TubiStyle Cat-Back Exhaust
        Power Chip 93 Gold - Modified & Sport 'On'
        Perma-Cool Electric Engine Fan (no mechanical fan!)
        Michelin Pilot Sport II Tires (front/rear stock sizes)
        Royal Purple Synchromax Transmission Oil
        Red Line 75W90 Differential Gear Oil
        Sirius Radio receiver
        SS Headers, EVO High Flow CATS
        Zionsville Aluminum Radiator w/ Dual Speed Fan
        My latest toy... a 2001 360 Modena Ferrari
        My 'other' car is a supercharged 1996 911 C2 993
        mr_bock is offline
        Old 7th July 2008, 03:29   #7 (permalink)
        badboypolar
        badboypolar's Avatar
        Send a message via AIM to badboypolar
        Wirelessly posted (XV6700: Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 6.8))
        as the ownership of the E39 M5 changes, I think into the hands of people the would do it themselves. I know I would, but I hate the stealership.
        You can't not be home before you haven't left.
        2002 M5, Gretchen.
        M5Board.com Stickers Now Available
        Crackberry E39 M5 Theme Ver 1.0
        badboypolar is offline
        Old 7th July 2008, 05:12   #8 (permalink)
        Michael William
        Getting to the last water pump bolt....
        You must take the crankshaft pulley off. To do this you simply remove the 5 - 13mm bolts you can feel on the middle of the pulley. Off comes the pulley, the nut plate, and the crankshaft end cover. No need to mark the pulley before removal as it is keyed.
        Sounds like at least a couple of folks would find the writeup useful. I will put one together. Can't get to it until August now, way too much going on this month...
        Cheers,
        Old 7th July 2008, 05:35   #9 (permalink)
        rroberrto
        rroberrto's Avatar
        Please do, for all these DIY suckers' sake!
        - Robert
        rroberrto is offline
        Old 7th July 2008, 13:51   #10 (permalink)
        mr_bock
        mr_bock's Avatar
        Cheers,
        Michael, thanks for confirming what I need to do to get to that last bolt on the water pump.
        I will take my time and do this right. The TSI (did the search) for purging air from the cooling system seems very clear and easy. Should have everything back together by the weekend. Thanks again!!!!!!!!!!!!!!!!!!
        George B.
        UUC Clutch Stop
        NAV MKIV DVD
        mr_bock is offline
        Old 7th July 2008, 22:18 <
