• Latest threads
    • Custom feed
      • Updates
        Old 6th April 2008, 22:56   #1 (permalink)
        bdeutsch
        Battery Question
        I have a 2003 that has approximately 14,400 miles on it.
        Obviously I do not drive it much, but of late due to work travel, sometimes weeks (up to 3) elapse before I get a chance to start it. In the last month, after prolonged period of no use, again 2 to 3 weeks, the car's battery does not have enough juice to turn the engine over. The battery in question is one that came with the car when new.
        When this happens, I then connect the battery, via the connections under the hood, to my trusted Sears Battery Charger. In about 5-hours, the charge is brought up to about 12.75 volts and life is good again.
        Is it normal for a healthy battery to drain without any noticeable load while car is dormant? Based on the voltage reading, there does not seem to be a problem with the battery itself.
        As always, appreciate any insight fellow owners can pass this way.
        Thanks,
        Bob
        bdeutsch is offline
        Old 7th April 2008, 00:18   #2 (permalink)
        jclyman
        jclyman's Avatar
        Yes, there is a drain ... components that need power all the time are still on ... When the battery is new, it has enough charge for months without starting. Your battery is getting near worn out.
        I wouldn't use a regular charger, although many here do. I would hook up a trickle charger to keep the battery up ... a good $ 40 spent. Mine is on one now. If I know I am not going anywhere for a week or longer, on it goes.
        I have the original battery and it is fine.
        Also, BMWs have a threshold below which everything that uses power when the car is OFF is shut off to protect the sensitive electronics. If your battery won't turn the engine over, SLOW CHARGE it for an hour or so, and then try. The threshold voltage is set to avoid "shocking" delicate electronic when starting the car.
        - Daniel Boorstin
        jclyman is online now
        Old 7th April 2008, 01:16   #3 (permalink)
        El Diablo
        El Diablo's Avatar
        Send a message via Yahoo to El Diablo
        Despite the low mileage, the age of the battery along with many factors such as temperature and suphatation build-up in the plates will cause premature failure. I just recently replaced mine after 75 months. I will be buying a battery tender or trickle charger very soon because sometimes I do not drive her for up to 2 weeks due to travel. Not re-charging a lead sulfide battery will accelerate the formation of lead sulfide. Hope this helps.
        -Roberto
        '02 Dinan S2 M5 - Carbon Black/Black Nappa Leather/Sport Trim/M Audio/Rear Shades/PDC/Split Rear Seats. Performance mods include Stage 3 Dinan/JRZ suspension, Dinan SSK, Dinan Front Strut Bar, SS X-Pipe and Evosport UDD Power Pullies. Aesthetic but functional upgrades include ZHP Gearshift knob, AA Lower Grille w/Brake Cooling Ducts, Progressive Window Tint, AC Schnitzer Pedals, Chromed OEM Rear Wheels with PS2's all around, Predator Ice, HID Fog Lights, TEC Cup Holder, Hardwired V1 Detector, Gen13 Bluetooth Module, MkIV Nav.
        El Diablo is offline
        The Following User Says Thank You to El Diablo For This Useful Post:
        jclyman (7th April 2008)
        Forum Jump
        Car won't start - dead battery again? C43///M5 E39 M5 and E52 Z8 Discussion 37 Today 00:29
        Charging battery question GregC E39 M5 and E52 Z8 Discussion 13 6th February 2007 03:40
        Douglas Battery Replacement Research V-10 4 Me E39 M5 and E52 Z8 Discussion 4 11th October 2003 02:15
        Really Stupid Battery Removal Question !! IvanDias E34 M5 Discussion 2 9th February 2002 19:16
        Battery question Bluewater M5 E39 M5 and E52 Z8 Discussion 1 5th February 2002 06:20
        Page generated in 0.18964 seconds with 11 queries
