6th April 2008, 20:09
#1 (permalink)
Rear Sway Bar Replacement Options
Started getting a clunking sound on slow turns. After inspection...it's broken. Should I go OEM or is there an upgrade option for this that you guys would recommend??
Thanks!
2001 BMW ///M5 - TiSi
Black Extended Nappa Leather
Active Autowerke Cold Air Intakes/Brake cooling ducts
Kelleners Exhaust
SSR GT3's 19's
H&R Springs
UUC SSK & DSSR
UUC E-brake handle
///M sport alum pedals
Carbon Kidney Grilles
Custom painted black rear diffuser area (Carbon Soon)
Carbon M Badge & BMW Caps
Carbon Front Lip Spoiler
IPod Integration DICE
Motorwerks Interior Xenon
6th April 2008, 20:11
#2 (permalink)
Are you sure that the sway bar is broken and not one of the brackets?
/// 00 Anthracite/Black
"Weeeeeeeeeeeeee!!!!!" - M5 Passenger
6th April 2008, 21:03
#3 (permalink)
Thoughts.
If its the sway bar, I have one with new stock bushings that can be had relatively cheap.
If its the brackets, upgrade them. I went with the TC Kline from Beastpower.
If you want to upgrade your swaybar, I think Dinan is good way to go.
7th April 2008, 00:23
#4 (permalink)
Sorry....misunderstood my indy. The sway bar is fine.. I just looked under the car. One of the links snapped... Wow. I just replaced the brackets since one had a visible crack. Now one of the links broke. I have the original sway bar on my car. With 62k on the clock it's probably just a matter of time before it goes, too. Wondering if I should go ahead and upgrade everything. Anyone, feel any noticeable difference with Dinan or other aftermarket replacements?
Kelleners Exhaust
SSR GT3's 19's
H&R Springs
UUC SSK & DSSR
UUC E-brake handle
7th April 2008, 00:48
#5 (permalink)
I have the dinan sway bar but I got it along with the front strut brace. I realy like the way the car corners now, especially wide turns at 50mph+. Very fun.
I also have the sway bar brackets from beast power. M5 deamon installed them on my car and it took him slightly less than 2 hours. The sway bar was more of a pain in the *** and it wouldve been great if we had a lift.
7th April 2008, 04:22
#6 (permalink)
Yeah... I may go the Dinan sway bar route along with the brackets. Might as well do it all at once. Thanks.
Kelleners Exhaust
SSR GT3's 19's
H&R Springs
UUC SSK & DSSR
UUC E-brake handle
7th April 2008, 09:30
#7 (permalink)
The links can break, too, but the brackets are the usual culprit. Sway bars themselves rarely break.
However, you will notice additional roll stiffness and less understeer with a Dinan rear bar, which has 3 sets of holes allowing you to mount links more towards ends (softer, but still more firm than stock bar) or more towards the middle (stiffer). Lscman argued convincingly that you could even adjust them in "half-steps" by using an outer hole on one side and one more in the middle on the other. (I don't recall the exact reasoning but it had to do with how the bar is just a torsion spring, where the length between the links matters but there is no "left side/right sided-ness" to it.)
Need4Spd
The Following User Says Thank You to Need4Spd For This Useful Post:
8th April 2008, 05:05
#8 (permalink)
Thanks, man.. I'm going to look into the Dinan upgrade.
Kelleners Exhaust
SSR GT3's 19's
H&R Springs
UUC SSK & DSSR
UUC E-brake handle
8th April 2008, 05:24
#9 (permalink)
See thread Dinan Swaybar adjustment strategies
8th April 2008, 06:18
#10 (permalink)
Dave
2001 TitaniumSiver
-Air intake system
-Supersprint cat-back exhaust
-Pure white LED Angel eyes by Umnitza...that failed.
- Dice iPod integration
-Stage one Rainbow speaker upgrade
-10" Kicker SolarBaric sub driven by an Elemental Designs NINe.2 amp
17th April 2008, 19:06
#11 (permalink)
considering the huge cost differential between upgraded and OEM, I'd stick with OEM. They are easy enough to change out.
If you upgrade the bar however, you should also upgrade the brackets.
