1st April 2008, 07:36
#1
'03 M5
ground control coilover owners... step inside
i'm finally going to pull the trigger on suspension this week but i'm still a tad on the fence between ground control and bilsteins. what i'd like to hear from are ground control owners. i've found a ton of threads on the pss9's but very little usable info on the ground control stuff.
price is pretty much a wash - 1899 vs. 1999.
components - not sure who has the edge here. i'm thinking GC just based on what i've read but again that's minimal.
install - GC hands down. they come pre-assembled and can just be installed. the bilsteins require either purchasing all new hardware to do the same thing or disassembling the current stuff and swapping parts. this is a huge one for me because i HATE screwing with spring compressors.
ride/handling - again, i've heard good things about the pss9's but nothing really about the GC stuff. not sure here.
my end result i'd like to acheive is to tighten up the 'floppiness' of the car and obviously improve overall handling. i autocross but i'm also realistic that i'm not going to get a 2 ton m5 to handle like a lister. i'd like to drop the car a little but by no means want to slam it like a 16 year old with a civic.
i also am concerned about fitment issues in the front with the GC stuff... i have 19's - 8.5 up front and 10 in the rear. i don't want fitment/rubbing issues.
thoughts from GC owners? or anyone else?
1st April 2008, 07:53
#2
I've got a GC suspension and for the track it's wonderful. I don't know anything about the Bilstein except what I've read.
The GC suspension kit is built for you based on what you want to do - call GC and talk to them and they'll give you springs that are tuned for your needs. Bilstein doesn't do that.
As for clearance in the front, NOTHING has as much tire clearance as GC. You can run 9.5" wide rear rims in the front without spacers on the newest GC setup. You have to be careful on spring choices if you want to drop the car - the lower perch has to sit above the tire. I'm not sure the Bilsteins will clear your rims (they might) because they have a tender spring that comes down into the tire clearance zone of the damper.
1st April 2008, 21:26
#3
'03 M5
thanks. what spring rate did you go in for? track, i'm assuming? does your car see much street driving? i'm curious as to the ride during everyday driving.
i did call GC and talked with someone(forget who) and they said the majority of people seem to go for the track spring rates... the others who have gone for street seem to regret it and end up swapping for the higher rate springs.
thanks for the comments.
2nd April 2008, 07:13
#4
I got 430#/inch front, 380#/inch rear springs - the track package, but not the "race" package.
It's a firm ride, magic on the track, and manageable on the street. I don't know about auto-x though - it might be too soft.
2nd April 2008, 08:31
#5
Super Moderator
You should make sure you talk to Jay. There have been reports of less that concise telephone support at GC by others. Jay is the master of suspensions.
Good luck- good choice
A
3rd April 2008, 08:39
#6
-Interesting. I am running 500/600 f/r springs on my Z4 MC, which is a much lighter car than the M5, and it's ok for street use if you don't mind a firm ride. I would think similar spring rates would have a good ride in a 700lb heavier car. But I admit this is just hypothesizing on my part.
www.ebsart.com
2011 X3 35i, Alpine White with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe, Titanium Silver with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
3rd April 2008, 20:01
#7
2001 M5 LeMans Blue
You can't just go by spring rates when comparing two different cars. You must compare the effective wheel spring rate (taking into account the leverage ratios). I think jaj has the leverage ratios for the M5 fwiw.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
1996 Volvo 850R wagon
herd has been thinned, looking for some new acquisitions...non-sunroof E90 M3 = found
3rd April 2008, 20:17
#8
It's good to search back on the board for posts by member "stever" because he had the GC "race" setup with 550F/425R springs. He said much the same thing as Palantirion - firm but nice, handles like its on rails. From memory, the Bilstein PSS9 springs are around 500F/400R (you'll have to search) putting them about half-way between the two GC setups.
The correct lever ratios for the M5 are 1:1 at both front and rear so the wheel rate is the same as the spring rate. The E36, 46 and 9x chassis have a less-than-one lever in the rear suspension so the wheel rate is lower than the spring rate. The front of all these vehicles is a McPherson strut, so it's 1:1.
According to posts by Lscman and confirmed by my own experience, on an E39 chassis the front spring rate and damping has less effect on the perceived "ride quality" than the rear rate and damping. At various times I was partway through an install and I had to put the car on the road for a day or two so I ran the GC fronts with stock rears (on the street...) and it rode like stock. The car only rode stiff after the stiffer GC rear springs and dampers were installed.
3rd April 2008, 21:38
#9
-Very good point. I knew I was missing something.
4th April 2008, 07:03
#10
'03 M5
thanks for the input guys. i've decided on ground control and i'm going to order tomorrow.
i'll take pics of the install, etc.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
