Angel Eye Bulb gone - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 21 Old 23rd March 2008, 07:21 PM Thread Starter
100%Cocoa
100%Cocoa's Avatar
Angel Eye Bulb gone
One of my angel eye side light bulbs went today, leaving the indicator on permenantly. (which I thought was rather strange??)
I got the holder out ok & unplugged it, but it looks like the bulb is captive and I'll have to buy a whole unit from BMW, rather than a 50p bulb. Can anyone confirm if this is true?! (The money grabbing b@s***ds!)
(PS - it's definitely a dead bulb rather than anything more serious as swapping the units over caused the fault to swap sides too.)
Cheers & happy Easter!
Barney.
100%Cocoa is offline
post #2 of 21 Old 23rd March 2008, 11:26 PM
Need4Spd
Need4Spd's Avatar
Good excuse to swap in something like Umnitza Predator Chromiums or AngeliBrights! These are a bit pricey (esp. the AngeliBrights), but what with the exchange rate and all, buying these from the U.S. is almost like getting them 1/2 price (though I don't know what happens with customs, etc.).
AngeliBright
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now
post #3 of 21 Old 25th March 2008, 01:06 PM
2strokecoldsmoke
2strokecoldsmoke's Avatar
I just had the same problem. You have to buy the whole unit, which here in the states costs about $25.
The bulb socket appears to be made of two plastic pieces that are plastic welded together. What happened to mine is the plastic weld started to fail, giving intermittent failure. I found that wiggling the body caused the light to come on. The solution? (at least temporary until I could get a new bulb and socket) was to shove a cotter pin in the space between the two parts of the socket to force the connector side of the socket over to the side that made the bulb stay on. Worked great. A bit ghetto though.
2strokecoldsmoke is offline
post #4 of 21 Old 25th March 2008, 02:29 PM
MAH
MAH's Avatar
Arrow NO NO NO!
You actually have nothing wrong here. I have dealt with the same issue many times. What you have is a loose wire connection into the socket to the angel eye. If you move the wires around close to the back of the socket, you will see the angle eye come on and the turn indicator go out.
The wiring is the issue and not the angle eye. I would imagine you also have a message showing up that there is a side marker failure. Play with the wires until this goes away and secure the wires into a position that keeps it from occurring again. Easy and cheap fix.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Red (angry eyes) Angel Eyes
MAH is offline
The Following User Says Thank You to MAH For This Useful Post:
Mike_Rock (2nd September 2013)
post #5 of 21 Old 25th March 2008, 02:54 PM
TGS2
Mark
German wiring. I had all sorts of trouble with wiring in my Audi and my mom has had the same in her A4. If these cars have one big short fall it's wiring.
TGS2 is offline
post #6 of 21 Old 25th March 2008, 05:34 PM
S62M5
S62M5's Avatar
the plastic housing can come apart, you see two melted plastic tabs break one and the piece will come out (pull out). the bulb can come out without breaking the tabs as well, you just have to push in and turn, need very small fingers or use a needle nose pliers and a cover the bulb with a piece of cloth don't apply too much pressure. this is the way it was on my hella OEM euro version headlights...
2000 M5, Avus blue
2005 GSXR 1000
http://www.youtube.com/watch?v=abo5aLzSRms
S62M5 is offline
post #7 of 21 Old 26th March 2008, 01:37 PM Thread Starter
100%Cocoa
100%Cocoa's Avatar
Cheers for all the replies guys. The bulb was gone - you could see the filament had disintegrated. I bought the new bulb complete with holder from BMW Battersea for the not inconsiderable sum of £12! (for a tiny bulb that's an outrage). Angel Eyes back to normal.
Mark - I did get a 'Check Parking Light' message, yes.
Anyone know why the orange indicator lamp comes on (solid, not flashing) when the side light bulb goes?
Cheers,
Barney.
post #8 of 21 Old 26th March 2008, 11:42 PM
MAH
MAH's Avatar
Arrow
Cheers,
Barney.
Not sure exactly what causes the turn indicator to light constantly. It is not on full brightness when it stays on. Prehaps the lack of resistance with the bulb missing, this would also explain the warning message.
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
361RWHP
425HP and growing!
MAH is offline
post #9 of 21 Old 27th March 2008, 12:08 AM
Wildstar
Wildstar's Avatar
The turn signal bulb is a dual filament bulb. The car is lighting the low power filament, which would be the running light, or parking light in a car without Angel Eyes. If is lighting even when the other running lights are not on, I have no idea why it is doing that.
I'm over 30, I can't trust myself!
2002 M5 LeMans Blue
2000 Z3 Roadster Topaz Blue
1990 Taurus SHO Oxford White
Wildstar is offline
post #10 of 21 Old 27th March 2008, 04:11 PM
AngeliBright.com
Company representatvie for AngeliBright.com
AngeliBright.com's Avatar
If you are interested in replacing the dull yellow AE with something a little nicer, give us a look!
Angel iBright.com | Angel Eye Upgrades for your BMW
CustomAngelEyes.com | Angel Eye Headlights for your BMW
email: sales@angelibright.com
web: http://www.AngeliBright.com / http://www.CustomAngelEyes.com
phone: 800.6200.BMW
"Your ANGEL EYES are not bright, unless they are... Angel iBright"
AngeliBright.com is offline
Predator Ice - a great angel eye upgrade whatheheck E39 M5 and E52 Z8 Discussion 2 25th February 2007 05:40 AM
New mod: Angel iBright HDClown E39 M5 and E52 Z8 Discussion 84 18th June 2006 11:58 PM
What kind of light bulb does the angel eye light use GZero604 E39 M5 and E52 Z8 Discussion 4 10th September 2003 09:58 PM
angel eye ring builbs mjlandy E39 M5 and E52 Z8 Discussion 2 25th May 2003 11:03 AM
? about angel eye light bulb Dr.Larry E39 M5 and E52 Z8 Discussion 0 15th April 2002 04:23 AM
