17th March 2008, 18:45
#1 (permalink)
EvoSport - Power Pulley Kit - belt size?
anyone familiar w/ the EvoSport Power Pulley Kit?
Back several weeks ago, I had a local Indy replace the serpentine belts. It was their recommendation as they noticed some standard wear on the belts. Given my extended warranty, I gave them the thumbs up.
They installed 7 PK 1629 belts. I've had it in their shop 4 additional times since, as the belts are squeeling/howling upon cold start or after the car sit for an hour or more. it's become a real pain to listen to.....cars sounds like a hoopty.
I've also had my local BMW dealer check it out. They said given the smaller diameter of the pullies vs. OEM pullies, there's NO WAY that OEM belt size 7PK 1629 would fit.
can any1 please confirm? I've spoke w/ a Dale @ EvoSport on 2 occassions, and he emphatically says that both the Audiophile & Power kit use the 7PK 1629 belt.......what gives?
17th March 2008, 19:08
#2 (permalink)
IIRC, when I bought it, the evosport kit came with a new serpentine belt which I installed with the kit. While I was doing it, I installed a new AC belt as well. The AC belt was the stock size purchased from the dealer, but I assumed that the serpentine belt was different from stock since they supplied it with the kit. But unfortunately I cannot tell you what size it was. Good luck!
03 Titanium Silver/Black Luxury/Burl Walnut
Supersprint headers and Race cats, Dinan CAI, High Flow air mass meters, 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Powerchip 93 software, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
17th March 2008, 20:24
#3 (permalink)
well, I'm glad to see I'm not the only one with this problem.
For the Evo pulley owners
19th March 2008, 20:48
#4 (permalink)
kinda OT
For the guys that have installed these themselves are there any special tools required, just bought the kit and haven't taken a look at it yet.
Aidan
00' Dinan S2 M5
07' GSXR 750 Blue/White
Kill your doubt with the coldest of weapons, confidence ~Incubus~
19th March 2008, 22:05
#5 (permalink)
You have to remove the fan so you would need a 32mm wrench for that. Rememer: righty loosey, lefty tighty for the fan. Other than that, just the normal metric sockets, etc.
19th March 2008, 22:37
#6 (permalink)
Wirelessly posted (BlackBerry8310/4.2.2 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
Will I need any special tool to remove the belt?
00' Dinan S2 M5
19th March 2008, 22:45
#7 (permalink)
you do not any special tool other than a dremel or a grinder to grind the tensioners.
removing the alterator pulley can be difficult while the alternator is in the car. i used a deep socket a pair of vice grips and an allen wrench.
with regards to the belt. just take the belt to any autoparts store and compare sizes. get one slightly smaller and install it. very simple fix
ryan
Aidan
FORSALE:
Stock MY00 E39 M5 w/ JB LTW Fly and Ctuch, PROJECTOR39 Lights, Stainless brake lines. Silver with gray two tone interior. $18,000
$350.00 BF DR's 275/35/18's rear
$200.00 SPAL Electric fan, no mechanical fan
$400.00+MY00 navscreen= 16.9 nav screen
$400.00 VIS carbon fider deck lid
$150.00 3k mile VW MAFs (perfect)
$30.00 slightly used slave cylinder
$125.00 11.3lb braille battery
$100.00 2x toyo 275 35 18 (used, plenty of TRACK life left)
$100.00 2x Nitto 285 35 18 (used, plenty of TRACK life left)
[b][size=1]
if it is not listed, its sold
19th March 2008, 23:04
#8 (permalink)
ryan
Aidan
Thanks.I will attempt to install them this weekend.
00' Dinan S2 M5
19th March 2008, 23:10
#9 (permalink)
I used info on these threads to help:
Serpentine Belt Replacement
Evosport Under-Drive Pulley Installation
I did not remove any of the air intake parts. I put the car on jack stands, removed the fan and the belly pan and did part from below and part from above. I left the stock alternator pulley in place because it looked like it might be a PITA to remove it. Good luck!
12th November 2008, 03:55
#10 (permalink)
I'm installing a set in the next week or so. How did the install go?
12th November 2008, 04:12
#11 (permalink)
I was running the Evosport audiophile power pulley kit and did develop a slight noise from the AC belt - replaced my tensioner and that helped, replaced the belt with the OEM size belt, didn't help - changed from an OEM conntinental belt to a Goodyear gatorback belt in the stock size and that fixed and noise issues - the goodyear belt has a grippier design on the belt - helps prevent squealing - you can buy at Autozone or summit racing online.
02 M5 LSB/Caramel - Sold :]
TMS Shark Injected
IATS
Euro Ducts / Stoptech Lines
Tubi Regular
Evosport Pulleys
E60 SSK w/ZHP
BSW Stage 1 and BSW Sub
Intravee II
V1 + StealthOne
Euro Hellas @ 55w / Fogs @ 35w HIDs
