Old 21st March 2008, 19:42   #51
wilsodh
wilsodh's Avatar
Interesting.. first I've heard of it. Did you say your idle is bumped up a notch or two? Mine is around 700 rpm. No lash noise and silky smooth idle.. really a perfect set up.
Of course a higher idle and the drag of spinning a supercharger doesn't do gas mileage any favors..
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 21st March 2008, 19:48   #52
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
Whats the Gas milage like on a SC beast S3,Other......
2000 Silverstone M5 extended Leather
BBS LMs 19s ,StopTech BBK,Dinan Headers Dinan CF -CAI,Dinan light weight flywheel,Dinan stage 3 suspension, Dinan stage 4 software ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
2009 135 Space gray Black Boston Extended Leather
mods-
Bmw Performance Black kidney grills
Dinan Stage 2 software(to be installed in April after winter)
1988 10th anniversary Rx7 turbo-mods... 93 rotors 3mm seals streetported lapped and balanced 6 puck non organic clutch Turbo back exhaust blah blah blah
1972 Corvette Stingray 454 4 speed man. Show car condition Frame off Restoration -FOR SALE make offer...
http://www.brecus.com/
mfizzlenyc is offline
Old 21st March 2008, 19:55   #53
wilsodh
wilsodh's Avatar
Mines about 2-3 mpg less than my stock beast, driving normally...
Dave
wilsodh is offline
Old 21st March 2008, 20:02   #54
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #23 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (3)
Dave
I have to believe it's an idiosyncrasy having to do with the Dinan air-fuel map for the S3. I'm sure it could be corrected but it would take (a) some one with the technical know-how and (b) an interest in doing it. This would be way down on the list of priorities compared to their current star project, the 5.7 liter V-10. I have no illusions of getting help from that source but maybe they will surprise me. At the moment she's idling at 800 rpm, exactly where she was with the S3 flywheel/clutch set up. She's been behaving a bit better after returning to her 100 octane Sunoco diet. Gas mileage - what's that?
Ray
2003 Jet Black lllM5 Dinan S3
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Stage 3 Dinan/JRZ Suspension, Dinan/Brembo Brakes, Rennline Pedal Set w/ throttle heel/toe ext,, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Subframe Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Winter: 275/35ZR-18 Michelin Pilot Sport PS2; Drags: 2 Nitto NT-555R Drag Radials 285/35R-18; Blinder-M45-X-treme, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder
1/4 mile: 11.795 @122.20 mph, 60' - 1.819
Kelster is offline
Old 21st March 2008, 21:25   #55
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
good old sunoco 100, it will make the power it is supposed to compared to the junk 93 we have nowadays...
Ryan
Ray
rneedham1979 is offline
Old 21st March 2008, 21:45   #56
wilsodh
wilsodh's Avatar
Hmm... maybe reset adaptations? To reset, disconnect battery cables, touch the pos to the neg, and give it 20-30 min. Reconnect and . Put some miles on her and see if she smoothens out....
Dave
wilsodh is offline
Old 21st March 2008, 21:49   #57
Kelster
Kelster's Avatar
Sales Feedback: (3)
Hmmm... We'll have to give that a try. Probably not until Tuesday though. Thanks.
Ray
Kelster is offline
Old 21st March 2008, 21:58   #58
wilsodh
wilsodh's Avatar
As I understand it, there may be a capacitor or series of them that hold memory for a given period of time as well as being used as a filter to eliminate surges. Hence the 20-30 min.
Dave
wilsodh is offline
Old 21st March 2008, 22:42   #59
phillym5
Garage: 01 Area 51 M5 Le mans.
'Misfire' is probably the wrong term to use since it doesn't trigger a code. It's more of an intermittent ragged idle/light throttle-low rpm transition phenomenon (<2500). Both Azevado and MWW tell me this is not an uncommon occurrence with light flywheels in this application. Let me also stress that while this is a bit of an irritant, the trade-off is going to be in the benefit gained in launch and shifts in the 1/4 mile. But unless someone comes up with a solution, a new S3 clutch will be going back in after this drag racing season is over and we retire from competition.
R
Does this throw a SES light? Or is it just the feel and sound?
phillym5 is offline
Old 22nd March 2008, 01:35   #60
Kelster
Kelster's Avatar
Sales Feedback: (3)
We don't have an SES light now and never have had one through all our trips to the drags. The same holds true for codes - with one 'old' exception. MWW confirmed this yesterday when I took the S3 to their shop had them check her out. It is just a feel and sound thing as you're suggesting.
The next step will be to follow Dave's recommendation of disconnecting the battery for 20 minutes. We will then connect the S3's positive and negative cables to drain off any residual capacitance charge. Hopefully this will trigger the relearning cycle and eliminate this problem.
This problem is unequivocably tied to the UUC flywheel/clutch. When the S3 still had the old heavy Dinan S3 flywheel and clutch (albeit slipping) it idled at 800 rpm and purred like a cat and drove perfectly. The moment the UUC flywheel and clutch were installed the rough idle and surging rpm under no/light throttle manifested themselves. Go to WOT and the problem goes away while you are at WOT.
If you have any other thoughts I'd love to hear them. Thanks.
Ray
Kelster is offline
Page generated in 0.18765 seconds with 10 queries
