Old 15th March 2008, 01:24   #11
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
Originally Posted by wilsodh View Post
So when is the next foray??? Let's see how that UUC clutch holds up to rompin stompin 'I-never-break-anything' lead foot Harry....
D
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline
Old 15th March 2008, 01:27   #12
THRILOS5
THRILOS5's Avatar
Sales Feedback: (3)
waiting for Ray to break in the clutch in NYC traffic, then if everything is well we will give it the ultimate test at the track,
so far Ray loves the UUC clutch
THRILOS5 is offline
Old 15th March 2008, 01:49   #13
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Which UUC clutch are you going to? I have the Ultra-Smooth CeraMetalic in my car. It seems to grab and bit very strongly. I did a 1st gear 5 mph rolling punch-it-to-the-floor. I got a lot of wheel hop in 1st, rpm's came up so quick that I shifted to second in the red zone. Then I got so much vibration up the shift lever in second that I thought I missed the gear. No miss-shift, more wheel hop and vibration. Later that day under moderate accelleration, I would get the vibration. All smooth at cruseing speed. I started to smell some rubber. I but the car on the lift... the flex disk looks like there were hot spots on the metal disk at each bolt location. I have not taken it out yet for a closer inspection, but I did order a new one. Seems that you strengthen one point and another point lets go.
Good luck with the UUC and at the track!!!!!!!!!!!!!!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 15th March 2008, 02:03   #14
THRILOS5
THRILOS5's Avatar
Sales Feedback: (3)
thanks,
I think it is the ultra -smooth CeraMetalic also but with a pucked disk, so far Ray says it feels fine but no hard accelaration tests yet, have to break it in nice and smoothly
THRILOS5 is offline
Old 15th March 2008, 02:50   #15
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Originally Posted by 00M5MD View Post
Correct me if I'm wrong ... but shouldn't S3's be trapping more than 122mph?
How much power are you S3 guys putting down? I would think you guys should be trapping closer to 130, no?
No, the traps speeds are about spot on for the power/weight. You need more than 100+hp more to get to 130 trap.
See: Performance Modeling: Dinan S2,S3 and D/A SC
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 15th March 2008, 17:49   #16
wilsodh
wilsodh's Avatar
Ray/Harry - Any idea how much the car weighs with the S3 hardware?
D
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
Old 15th March 2008, 18:26   #17
THRILOS5
THRILOS5's Avatar
Sales Feedback: (3)
with 1/2 tank of gas it was 4,020 at Englishtown's scale(NHRA approved),
my car for comparison was 3,921 with about 1/3 tank of fuel
THRILOS5 is offline
The Following User Says Thank You to THRILOS5 For This Useful Post:
wilsodh (15th March 2008)
Old 15th March 2008, 19:11   #18
wilsodh
wilsodh's Avatar
Weight... er, wait... what about all the junk in Ray's trunk?
Let see, if your beast is stock, and Ray's car would have had about 20 lbs more fuel (assuming 6.2 lb/gal), the S3 weighs only about 80lbs more than a stock beast. Not bad. The weight of the s/c & cooler hardware being offset somewhat by the weight savings of the lighter wheels, brakes, and exhaust.
Dave
wilsodh is offline
Old 15th March 2008, 19:17   #19
THRILOS5
THRILOS5's Avatar
Sales Feedback: (3)
well I also have lighter wheels, brakes and my exhaust set up is much lighter than Ray's, so I think the difference is about 100lbs
THRILOS5 is offline
Old 15th March 2008, 19:39   #20
MCarRacr07
MCarRacr07's Avatar
Garage: 08 Space Grey M3
Sales Feedback: (4)
Impressive Driving!
Very nice Harry!...you should give lessons....
Now that the S3's prowess in a straight line has been established....how about we bring it to a road course Ray???.....say Thunderbolt in NJ...or the Glen???...I would love to see how the car handles all that amazing power when the weight gets shifted. Did you get new dyno numbers after MWW addressed the earlier issues with the car??...
How that car pulls not from the dig but from mid-range is impressive...it just walked away from the E60.
Anybody going to the Autoshow Sat.???...hope to see some guys there.
Regards
S
MCarRacr
89 M3 (Track Car)SOLD
95 M3 (Track Car)SOLD
08 M3 (lil Beast)
00 M5 (BIG Beast)R.I.P
00 540 Sport (Gone)
03 330xi (Gone)
06 330xi (Gone)
08 328xi(New Arrival)
04 325xi(New Arrival)
MCarRacr07 is offline
Page generated in 0.17899 seconds with 10 queries
