Old 13th March 2008, 22:31   #1
Jack Fishman
Jack Fishman's Avatar
Garage: 2003 Alpine M5 & 1972 2002 Tii Inka
Rear tires and wheels up front
Many threads have discussed the handling advantages of putting the rear tires and wheels up front. BUT, no one has discussed the disadvantages. WHY NOT DO IT??
Jack Fishman is offline
Old 13th March 2008, 22:37   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
more weight, more tramlining (not sure if that is spelled correctly), more expensive tires, probably worse aerodynamics, fuel economy and top speed.
oh, the obvious, less understeer, so if you're a bozo in the corners you have more opportunity of exiting backwards.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 13th March 2008, 22:42   #3
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
Oh man you're gonna get nailed by the search police!
Diny is offline
Old 13th March 2008, 23:02   #4
Jack Fishman
In my defense( I am an attorney) I just re researched the subject. The only post on the subject I can find is this one.
Old 14th March 2008, 03:26   #5
Lscman
Garage: E39
Understeering cars are safer for poor drivers. They serve as an effective speed governor/limiter in corners. A teen kid who's used to driving mom's minivan or some other plowing machine will wrap a neutral-handling car around a tree before they realize they aren't gonna hear tires howling, squealing and scrubbing.
Another issue that hasn't been mentioned is road feel and steering sensitivity. Both are compromised a bit with brute sizes.
If you are looking for better max performance on M5, the wider wheel & tire combo always is the best choice. The modest 8" front wheels are grossly overworked for the 2 ton V8 application.
Resolve never, screw genuine.
Lscman is offline
Old 14th March 2008, 07:49   #6
Need4Spd
Need4Spd's Avatar
Try different search terms!
Need4Spd
Need4Spd is offline
Old 14th March 2008, 15:09   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I would add extra strain on the front wheel bearings also. All relatively minor trade offs IMHO.
gsfent is offline
Old 14th March 2008, 18:06   #8
mottati
mottati's Avatar
good point, also on the various bushings etc. You'll go thru thrust arm bushings faster.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 15th March 2008, 01:20   #9
Jack Fishman
THANKS to all with a positive answer. Since I do not plan to track the beast, it seems the stock wheel and tire size and configuration are the best.
Old 15th March 2008, 02:26   #10
Lscman
Garage: E39
Forget track. Handling has everything to do with street performance use. Switching from stagger to non-stagger setup is one of the best street modifications you can make to the M5. The increase in cornering capability is substantial and the front tires will last longer.
For street only, the performance advantages offered by the 9.5" front wheel setup far outweigh the disadvantages.
Lscman is offline
Page generated in 0.13858 seconds with 10 queries
