Originally Posted by RUFM5
DA/DA car owners,
Can you expand on what this "Custom D/A crank case breathing and oil separator system" is all about, how it is different from OEM and any advantages?
It has to be different because in the OEM setup the crank case is drawn (breathes) through the two oil separators directly into the lower plenum during vacuum and then there are valleys in the base of the plenum that allow any oil drawn in to be drained back to the sump however the lower plenum in the supercharged setup is sealed.
There are no significant advantages for an N/A gal however a requirement when supercharged and by doing so there is a secondary benefit being that there is no residual oil aka vapor within the throttle body area.
Takes care
Shadowman
