Old 10th March 2008, 04:37   #1
vics
vics's Avatar
Garage: 99 HayaBusa & BMW K1200RS
Can't install rear pads
OK, can't expand the piston in far enough to get the Axxis deluxe advanced pads around the rotors... Have ruined original pads & rotors with breaker bar which is ultimately OK as I've got new rotors as well - but had to button her back up & submit to temporary failure....
More than enough leverage with 2 foot bar- figured perhaps something with ABS? Started the car up, opened the bleed screw as well - NOTHING....
OK, tell me WTF I'm missing to get that additional 1/16th"
00 M5 (8/1/00); 130K, Anthracite/black/fold-down rears/Dinan exhaust/Dinan Stage II software/cold air intake.
99 Copper HayaBusa; 19K, (unrestricted, 196 mph )
98 BMW K1200RS; 110K, The Ultimate BMW K1200/ K1300 Portal
vics is offline
Old 10th March 2008, 04:58   #2
Blockdoc
Blockdoc's Avatar
Garage: 2003 Sterling Gray M5
I'm curious too...since I will be tackling this myself in the near future. FWIW, the BMW TIS describes one of their many "special tools" to expand the piston.
Can this be done without the special tool?
Brian
2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Supercharged by ESS!! (Kit number 01)
Blockdoc is offline
Old 10th March 2008, 05:23   #3
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
I just used a regular pad spreader with the piston attached pad left in place to push the piston back. No issues.
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 10th March 2008, 05:32   #4
Stika
Stika's Avatar
Garage: E39 M5/Jet Black on Black
Did you try it with the reservoir cap off?
...i wanna go fast...
Stika is offline
Old 10th March 2008, 05:37   #5
E55AMG2
E55AMG2's Avatar
any $5 brake piston tool can do the job in 30 seconds...the right tools make the job that much easier
E55AMG2 is offline
Old 10th March 2008, 05:38   #6
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
maybe the piston is frozed or the brake hose was twisted or colapsed... also you don't need a special tool to do bmw brakes... i wouldn't be able to diagnose the problem without more info or seeing it myself...
kindanutz is offline
Old 10th March 2008, 05:39   #7
kindanutz
kindanutz's Avatar
or a c-clamp, or large pair of channel lock plyers...
Old 10th March 2008, 05:46   #8
kindanutz
kindanutz's Avatar
i don't understand why you used a pry bar in the first place... a three pound sledge or an air hammer would have gotten it off without damaging the stoping surface... you could have easily gotten the job done without damaging the rotors... also when you opened the bleeder screw did you leave it open, so it could gravity bleed... there is also a possibility that now that you opened the bleeder you are going to have to bleed the brakes...
Old 10th March 2008, 05:51   #9
TCM
TCM's Avatar
Were the rear brakes draggin before swapping? You may have a frozen caliper piston or a busted seal. Have done countless M5 brake jobs and never ran into this issue. Usually piston slides right back with the proper tool. Please keep us updated.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 10th March 2008, 06:18   #10
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
There's something wrong with the caliper - I've had mine apart probably 10 -12 times over the last five years and they're easy. If the piston won't go back in with leverage, then it's frozen in place (rusted, probably) and needs professional help.
jaj is offline
Page generated in 0.13540 seconds with 10 queries
