Old 9th March 2008, 18:51   #1
RUFM5
Garage: M5 modded
Cracked clips on the MICROFILTER AIR CHANNEL - engine bay air entering cabin
Has this ever happenned to anyone? Many people may just not have noticed that the air we are breathing might be coming in from the engine bay. The clips cracked from the MICROFILTER AIR CHANNEL (pn:64318379621) allowing a gap to the interior cabin duct.
#7 on realoem.com;
http://www.realoem.com/bmw/showparts...73&hg=64&fg=10
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
Evosport Under-Drive Audiophile Pulley Kit
Braille B3121 21lbs Racing Battery (OEM 64.5lbs)
Braille Premium Power Protector
Custom Magnaflow High Flow Metallic CATS (#59926)
Perma-Cool High Performance Electric Fan
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Custom HD Sink Drain brake duct cooling mod
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
Armano Vanquish Chrome 18inch Wheels
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, ///M oil cap
CNS Racing 3.62 Differential Upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators
UUC RK6A-L knob
DENSO Iridium Plugs
Alutec Strut Bar
RUFM5 is offline
Old 9th March 2008, 23:55   #2
Vason
Vason's Avatar
Garage: '03 M5 - Carbon Black/Caramel
Sales Feedback: (4)
I recently checked my air filters and happened to notice how the air channels secured in place. Mine are fine but I can see how this might happen if the clips were to brake causing a not so tight fit. Expensive pieces those are...ouch!
'03 M5 Carbon Black/Caramel
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
Old 10th March 2008, 03:58   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
I have a broken clip as well, but unless you break them all there is little chance of air leaking in in significant quantities...
d-
DouglasABaker is offline
Old 10th March 2008, 04:41   #4
RUFM5
Garage: M5 modded
d-
Correct. I had one of three clips broken on the right side with no leaks however I had two of three clips on the left side causing a leak.
UFM IATS Relocator
UUC RK6A-L knob
DENSO Iridium Plugs
Alutec Strut Bar
RUFM5 is offline
Old 10th March 2008, 08:02   #5
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
I noticed mine were not properly locking into the firewall, was getting very hot air feeding into the cockpit during heavy traffic driving.
Damn BMW technicians lack of attention to detail ! The other day they had an E39 M5 in the work bays, true enough, both ducts not properly clipped in.
On mine, one clip was damaged, but as you say, it locks into place properly.
AfricaOffroad is offline
Old 10th March 2008, 08:40   #6
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
I had a weird noise coming from my car about a month after I bought it. It was related to the air speed of the cabin blower. I pulled one of those out and reached in. Sure enough, one of those clips had snapped off and was dancing on the fan blades.
everycredit is offline
Old 25th August 2009, 15:22   #7
beast27
beast27's Avatar
Garage: M5 Lemans Blue
I have the same issue on one side and will try and take pics. I'm going to mess around with it after the engine cools down to see if it's a broken clip or just not snug into place....
beast27 is offline
Old 25th August 2009, 20:08   #8
WaldoM5
Garage: 03m5 black
my drivers side one is broken.
WaldoM5 is offline
Old 25th August 2009, 21:22   #9
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
These are famous for breaking on the E39. I've got through a few in my time with this car, and in city traffic you can definitely notice the difference with just 1 clip broken. All that oil I've spilled over the years burns off and gets sucked straight into the cabin. It's a very poor design and it drove me nuts for ages. I don't think BMW took into account just how often they need removing for various maintenece jobs!
I recently learned the secret though, and it's made their removal and refitting as easy as taking off the oil cap...... Just cover the 3 lugs in WD40 before refitting...... As with so many things in life, if you lube it up properly, it'll just slide straight in. No problem.
100%Cocoa is offline
The Following User Says Thank You to 100%Cocoa For This Useful Post:
RUFM5 (26th August 2009)
Old 26th August 2009, 01:25   #10
beast27
beast27's Avatar
Fixed mine. Appearantly it wasn't secured properly to the firewall and simply screws and snaps into place. (part number 7 in above realoem link). Glad this didn't result in a parts purchase...
beast27 is offline
Page generated in 0.15314 seconds with 10 queries
