Instructions for Thermostat Replacement? Any With Pics? - BMW M5 Forum and M6 Forums
post #1 of 26 Old 7th March 2008, 07:12 PM Thread Starter
Anita
Anita's Avatar
I would appreciate you all referring me to your favorite thermostat replacement instructions and any pictures/diagrams that could be of use (I have the one from RealOEM of the waterpump-thermostat). I saw what seems to be a very detailed set written by everycredit here post #11. I'm hoping to have my friend who is a non-BMW tech do the work and was hoping to give him as much info to do the job as possible. As you might guess, I got an estimate from the dealer and it came in at $818 including parts and labor!!
I came into the dealer with a solidly lit SES on my '02 M5 (89K miles). They read the codes and found it to be a failed thermostat.
Here are my "symptoms":
-Solidly lit SES (stayed on for about 10 start cycles then went off, now back on)
-Temp gauge does not budge beyond the left white dot
-Hesitation upon acceleration (computer making a/f adjustments due to failed thermostat?)
-Code found by dealer--sorry don't have it!
Recommended replacement parts:
-BM11-53-7-835-558 Thermostat
-BM11-53-1-312-287 Seal Ring
and of course
-BM82-14-1-467-704 Antifreeze
The dealer has been good to me in other ways but this price seems really high!! I did check with an alternative shop and I think they wanted in the mid 600's to do it. The friend I want to do it works on track cars so he should have a field day working on an M5
Thanks so much!
(Hey I have to tell you all that it's very embarrassing to have your 16 yr old drive your M5 and tell you it accelerates worse then his car. So yeah I really need to get this fixed!)
Anita is offline
post #2 of 26 Old 7th March 2008, 07:25 PM
undfined
undfined is offline
post #3 of 26 Old 7th March 2008, 08:24 PM Thread Starter
Anita
Anita's Avatar
Anita is offline
post #4 of 26 Old 7th March 2008, 08:51 PM
ReflexGTI
ReflexGTI's Avatar
I would suggest also buying the 4 o-rings for the aluminum transfer pipes. They tend to get pinched and break.
Steve
ReflexGTI is offline
post #5 of 26 Old 8th March 2008, 12:54 AM Thread Starter
Anita
Anita's Avatar
Thank you for that bit of additional advice! Do you happen to know the part number for the O-Rings?
Anita is offline
post #6 of 26 Old 8th March 2008, 01:08 AM
captainsin
captainsin's Avatar
When I changed mine, instead of getting under the car to drain off coolant, I took a small hand fluid pump (like the kind you pump gear lube with) and simply drained down the fluid to below the thermostat. Made the whole job take less than an hour.
captainsin is offline
post #7 of 26 Old 8th March 2008, 01:14 AM
ReflexGTI
ReflexGTI's Avatar
11531406249
There are 4 of them.
post #8 of 26 Old 8th March 2008, 07:34 PM Thread Starter
Anita
Anita's Avatar
Thanks so much undfined, Steve and captainsin! I'll get the additional O-Rings ordered, print off all this and show my tech so he can how much time (and effort) this job should take which will help him with scheduling!
Anita is offline
post #9 of 26 Old 8th March 2008, 09:37 PM
britm3
britm3's Avatar
Just replaced the thermostat - yesterday
I would say follow that link above for a very good guide. Take a quick look at the TIS if you have access.
The TIS recommends replacing all of the O Rings on the tubes going into the thermostat housing:
4 larger O-Rings
2 smaller O-Rings
It can take some effort to get those metal tubes out of the housing, don't be afraid to use a rubber mallet to loosen them up.
The TIS also says to replace the gasket seal inside of the therostat housing, this is not easy, I did it, but would say, skip this step if your mileage is moderate (mine is 67k). I did this by tapping the gasket ring with a small screwdriver through the hole where the temperature sensor screws in. This allows you to hit the gasket from the back side, forcing it out.
The new gasket seal with not just slide in, it needs "pressing" in, I set it in place and placed the end of a 2x4 over the new seal inside of the housing, and then hit that 2x4 with the rubber mallet - pressing it in place.
Finally, after experiencing leaks with my 0-rings the first time around, and draining my coolant - TWICE - I have a few recommendations.
1. You can get away with draining the coolant from just the radiator and the passenger side plug, no need to remove the heat shield and go after the drivers side coolant plug.
2. You could also use an oil extractor to draw out coolant until it is below the thermostat housing level.
3. Make sure the gasket housing o-rings and tubes are well seated in the housing and the cooling passages going into the engine block, I used a small amount of Mercury 321 marine grease to allow the rings to slip in and fully seat, the second time around. First time around I used nothing and had a coolant leak from the o-rings all over the floor - not fun as you essentially start from scratch to remove the housing and check the o-rings.
4. Buy more coolant than you need from BMW as you may be driving to the dealer twice when you have to redo the job.
5. Remove the temp sensor before pulling the thermostat housing out, makes it easier to maneuver past the Vanos lines and fan.
6 . Be patient, this is not complicated, but requires attention to detail.
SL
02 M5 LSB/Caramel - Sold :]
TMS Shark Injected
IATS
Euro Ducts / Stoptech Lines
Tubi Regular
Evosport Pulleys
E60 SSK w/ZHP
BSW Stage 1 and BSW Sub
Intravee II
V1 + StealthOne
Euro Hellas @ 55w / Fogs @ 35w HIDs
britm3 is offline
post #10 of 26 Old 10th March 2008, 10:10 AM
everycredit
everycredit's Avatar
This job took me 4 hours to do--of which 3 hours was spent looking for the lug from the engine block drain. Some how it was in the subframe above the hole. Subscribing to the theory of gravity, I didn't initially look up there. Provided you don't lose the lug, it takes a minimum of an hour, but plan an afternoon-evening doing this. Also, if you do the coolant drainage scheme, you must properly vent the coolant described in the procedure above. It's easy to do (car is self-venting), but if overlooked, you can develop "hot spots" in your engine due to air bubbles. This is not a good thing.
everycredit is offline
