Old 6th March 2008, 03:37   #1
Kmac
Kmac's Avatar
Garage: Alpine White E39 M5; Carbon Black E46 M3
Whats the best way to correct the speedometer?
The delta between my actual speed (GPS derived) and my speedo is annoying. I have read that the BMW speedo reads between 8 and 10% high. I also read Alex Roy's book where he installed a sensor (wheel something) and it had a digital readout of his actual speed.
Is there a way to correct the speedo or do you need to go aftermarket and use the wheel speed sensor?
E39 M5 MY'00 (FOR SALE)
Rogue Engineering SS Kit/Rogue Clutch Stop/M Aluminium Pedals/Hardwired V1/TEC Cupholder/Titan Trim & door handles/Bimmian Knob & E-brake/Euro Arm Rest/Alutec Strut Bar/M3 Steering Wheel/35% tint/Centric Rotors/Axxis ULT's/SS Brake lines/16:9/MKIV/IntraveeII/Tubi Exhaust/AA Cai/Conforti Shark Injector/TC Design Brackets/Dinan Stage 1 Suspension/Bavarian Auto Poly Trailing Arm Bushings
E46 M3 MY'01/100k miles
TCKline Double Adjustable Coilovers/TCKline Adj Camber Plates/Delrin bushings/TCKline Racing wheels (18x10 - 19lbs)/Bridgestone RE01A 265/35r18's/Wheel Studs/Goodrich SS Lines/UUC SS Kit/ZHP Knob/Hardwired V1/XM Radio/CF Hood/CF Fenders/Dust cover delete\Dinan Front strut brace/GC Sway Bars/Superprint Stepped Headers/Rougue Midpipe w/dump valve/Random Cats/Supersprint Race pipe/Rogue Diablo Exhaust/Rugue Pullies/CSL CF Airbox/Alpha N software/StopTech BBK
E90 M3 MY '08
Bone stock
"For Sale: 20th Century French Rifle - never fired, dropped twice."
Kmac is offline
Old 6th March 2008, 04:11   #2
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
I have been looking into this also, I don't know if its possible to adjust it in the dash cluster test 07.3 or 07.058(one of those two).
First the mars lander calculations and now BMW speeds, It must have been the same NASA employee.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
Old 6th March 2008, 04:58   #3
Kmac
Kmac's Avatar
lol - and you are waaaay farther into this than me. I assume that the input is digital?
E90 M3 MY '08
Bone stock
Kmac is offline
Old 6th March 2008, 07:12   #4
6spd
6spd's Avatar
I will try to find the instructions again, I had to run off to a softball game so I couldn't look for them earlier.
E39 Instrument cluster test functions
Test functions
MenuSub menuSampleMeaning
Test 1: Vehicle specific data1.012345VIN
1.14812Body number
6_1.2834762Part number of cluster
1.3010203Coding/Diagnosis/Bus index
1.43495Manufacturing data (calender week/year
1.504_600Hardware/software number of cluster
3_1.6415_06Injection status, number of cylinders, engine factor
Test 2: Cluster system testActivates test for gauge drivers, indicators and LEDs
Test 3: SI data3.01500Litres
3.10Periodic inspection days (not applicable for US)
Test 4: Fuel consumption data (current)4.0026726.7 litres/1000km
4.100737.3 litres/hour
Test 5: Fuel consumed/distance travelled5.0019519.5 litres/100km
5.1226Momentary distance to go (22km)
Test 6: Fuel level sensor input in litres6.0237415Fuel level averaged.
LH sensor input = 23.7 litres - RH sensor input = 41.5 litres
6.10652Total tank level averaged = 65.2 litres
1_6.20667Indicated value and tank phase.
1 = Both sensors OK. 2 = One sensor fault.3 = implausible input
Test 7: Temperature and speed7.0032Coolant temperature input 32C (90F)
7.1245Outside temperature input 24.5C (76F)
7.25283Engine speed 5,283 RPM
7.3085Vehicle speed 58 km/h (36 mph)
Test 8: Input values in HEX code8.0-8.3XXXHex code, instrument cluster inputs
Test 9: battery voltage9.012512.5 Volts
Test 10: Country coding10.002US 02
Test 11: Cluster code11.0000003Cluster code
Test 12: Not used
Test 13: Gong test13.0GONGActivate gong by pressing button (gong response is delayed)
Test 14: Fault memory (not used for diagnosis)
Test 15 - 18: Not used
Test 19: Lock/unlock19.0L-On L-OffLock/unlock specific test functions
Test 20: Average fuel consumption correction factor20.0XXX9Press button when correct 1s position is attained
20.1XX5XPress button when correct 10s position is attained
20.212XXPress button when correct 100s position is attained
Test 21: Software reset21.0resetReset software
Instrument cluster, self testing
Perform the following steps to access the instrument cluster self test functions:
  1. Remove and insert ignition key (ignition OFF)
  2. Press and hold RIGHT cluster button. “CHECK CONTROL OK” is displayed.
  3. Without releasing button, turn ignition switch to first dent (RADIO position). “TEST-NR. 01″ is displayed.
  4. Press LEFT cluster button for the test sub-menus.
  5. Press RIGHT cluster button to scroll to next test.
Note:
Test 1 and 2 are always unlocked
Test 3-21 are only accessible after unlocking using TEST-NR. 19 lock/unlock function. See Instrument cluster self test, unlocking.
To unlock a specific test:
  4. Use RIGHT cluster button to scroll to TEST-NR. 19 (lock/unlock)
  5. Press LEFT cluster button once to access TEST-NR. 19 submenu. “LOCK : ON” is displayed
  6. Use LEFT cluster button to scroll to test you wish to unlock.
  7. Press RIGHT cluster button once to unlock desired test. Display returns to TEST-NR. 01.
  8. Scroll to unlocked test using RIGHT cluster button.
  9. Press LEFT cluster button to perform desired test or access that tests submenu.
  10. Repeat unlock sequence for each test required.
  11. Switch ignition OFF to cancel self test mode.
Note: Display shows no visual confirmation of test unlock.
Instrument cluster, software reset
To reset instrument cluster software:
  6. Use LEFT cluster button to scroll to TEST-NR. 21. “LOCK : 21″ is displayed
  7. Press Right cluster button to unlock TEST-NR. 21. Display returns to TEST-NR. 01.
  8. Use RIGHT cluster button to scroll to TEST-NR. 21.
  9. Use LEFT cluster button to access TEST-NT. 21 sub-menu. “REST ?” is displayed.
  10. Press LEFT cluster button again to perform reset.
Thank you to KinMak for having posted this else where.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
The Following 4 Users Say Thank You to 6spd For This Useful Post:
2strokecoldsmoke (3rd July 2008), Kmac (6th March 2008), rroberrto (1st July 2008), Terabass (30th June 2008)
Old 6th March 2008, 10:47   #5
Alin10123
Alin10123's Avatar
Garage: 03 LMB M5, 05 TSX
Could it be possible that there's a difference between the nav and speedo speeds because of the up and down grades of the roads? The GPS probably doesn't know if you're going up a grade or down a grade, would that make it possible there's a difference in speed, along with the wearing down of the tires decreasing the outer circumference of the tires?
Alin10123 is offline
Old 6th March 2008, 15:19   #6
Kmac
Kmac's Avatar
Good thought, but its a known fact the speedo is off. At least according to the wheels that are on your car, which are rather important in determining speed. And you are right, if the circumference of the wheel changes, it has more revs per mile and I have no idea if the wheel speed sensor adjusts for this.
Maybe I should try a wind speed gauge on top of the car
E90 M3 MY '08
Bone stock
Kmac is offline
Old 7th March 2008, 07:23   #7
Kmac
Kmac's Avatar
That speed in 7.3 must be a calculated item. I wonder if its using a pre-determined wheel revolutions per mile, that changes depending on the tires, etc. If it bases the number on a tire that we no longer use, that could cause an inaccuracy. Next, you have to wonder if it could be changed. The number that is in there would look like 788 or something to that effect give the standard tire sizes.
I wonder what the standard tire sizes are for european models?
Also, did you see that in speedo accuracy ratings, BMW was dead last!!!
E90 M3 MY '08
Bone stock
Kmac is offline
Old 7th March 2008, 07:45   #8
Kmac
Kmac's Avatar
Found the answer.
http://www.atrol.com/era.htm
E90 M3 MY '08
Bone stock
Kmac is offline
Old 7th March 2008, 07:53   #9
E55AMG2
E55AMG2's Avatar
The error is programmed into the cluster itself. Mine is a constant 3mph. The OBC "average speed" reading is dead on accurate when compared to GPS.
E55AMG2 is offline
The Following User Says Thank You to E55AMG2 For This Useful Post:
jclyman (30th June 2008)
Old 7th March 2008, 08:18   #10
Kmac
Kmac's Avatar
Nice - I just read that somewhere else also. I wonder if they are reading from two different sources (one from the tranny, one from the wheels?) or if there is a build in + function between the OBC and Speedo.
My guess is two different sources. You also had to convert from m/s to mph correct?
E90 M3 MY '08
Bone stock
Kmac is offline
Page generated in 0.21779 seconds with 10 queries
